01-17-2011, 11:28 PM | #226 |
Re: Header Solution
funny, i was told i was the only one with an issue!
1967 SWB (small window) original 1970 4x4 STEP 1970 CST SWB FLEET 1972 SWB FLEET ORIGINAL |
01-18-2011, 12:59 AM | #227 |
Re: Header Solution
That's 2 for 2 with aluminum heads.
What's "funny" is both of you JUST received your headers and both happen to be using aluminum heads. |
01-24-2011, 10:05 PM | #228 |
Re: Header Solution
I've put a set of these on my 4x4 K5. Great quality header. However, these will not clear a stock 4wd engine crossmember without modification. Ultimately, I ended up modifying a DIY4X engine crossmember to make them work. FWIW, I am also running aluminum heads. Details of the mods I made can be found in my build thread (see link in my sig)
01-24-2011, 10:17 PM | #229 |
Re: Header Solution
will they work with angle plug heads?
01-29-2011, 11:53 AM | #230 |
Re: Header Solution
Are there any pics of the BB Stainless pics available yet. Also, what size
collectors are being used with them. I'm ready to pull the trigger on a set. Thanks, S.T. |
02-01-2011, 04:34 PM | #231 |
Re: Header Solution
Just mounted my headers on the 72 402/th400. They do not fit with the stock linkage. What after market shift linkage do you run with the headers?
Thanks again, mike chopp |
02-01-2011, 05:02 PM | #232 |
Re: Header Solution
lokar is what they are using haven't tried mine yet
02-01-2011, 05:38 PM | #233 |
Active Member
Re: Header Solution
We are using lokar linkage part# aca-1800
02-01-2011, 05:55 PM | #234 |
Re: Header Solution
what length header bolts you run with the big block
02-01-2011, 06:02 PM | #235 |
Re: Header Solution
and torque specs on headers? torque from center out?
02-02-2011, 01:21 PM | #236 |
Active Member
Re: Header Solution
03-27-2011, 07:34 PM | #237 |
Re: Header Solution
ok so i noticed today that my headers are really close to my tranny cross member and exhaust is prolly not clear anyone have this problem
03-27-2011, 07:38 PM | #238 | |
Re: Header Solution
Any plans to make a set for the 3 pedal crowd? Last edited by lakeroadster; 04-08-2011 at 05:53 PM. |
03-27-2011, 07:57 PM | #239 |
Re: Header Solution
Any pictures?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-27-2011, 07:59 PM | #240 |
Re: Header Solution
not at the moment was hoping someone would chime in with 7000r4 im thinking aftermarket cross member will fix the problem
03-27-2011, 08:06 PM | #241 |
Re: Header Solution
That's what I did with mine, but I'm running a small block...
03-27-2011, 08:10 PM | #242 |
Re: Header Solution
what cross member are u running still looks like could be an issue how much room before header hits cross member 2-4-6 inches. using stock cross member and 700r4 i have like 2-3 inches before it hits
03-27-2011, 08:14 PM | #243 |
Re: Header Solution
I've got about 15".....
03-27-2011, 08:18 PM | #244 |
Re: Header Solution
which member do u have ccp? does it sit back farther than stock one? im running big block
03-27-2011, 09:53 PM | #245 |
Re: Header Solution
I used ECE's. It doesn't sit further back, but the design makes room for the exhaust to go over top. Looks like the BB headers are longer and go further back.
03-27-2011, 10:14 PM | #246 |
Re: Header Solution
thanks for the help
03-28-2011, 12:46 AM | #247 |
Re: Header Solution
Hmmm...same problem here Weircc. Just installed mine today..BB/w 3'' ball
collector. After the initial shock ...I thought I could solve the problem by ordering the ECE trans mount. But now, after seeing Hart Rod's with the mount installed, I don't believe that will fix the problem (could be wrong) I only have about an inch and a half before the ball of the header touches the tranny mt. The headers sit just low enough that it is questionable if the ECE mt. will fix the issue. I have attached a few pics so maybe someone can help with a solution. Only thing I know to do at this point is to have a custom trany mt. made |
03-28-2011, 12:51 AM | #248 |
Re: Header Solution
By the way...this is a great set of headers. Just hope we can get around
this fitment issue without to much hassel. |
03-28-2011, 06:13 AM | #249 |
Re: Header Solution
hmm i was thinking mine had a little more room but never went back out too see last night i think the ece cross member will probably get it though
04-08-2011, 12:31 PM | #250 |
Re: Header Solution
whats the chances of another group buy???
