Old 04-11-2012, 04:18 PM   #226
made2drag
made2drag's Avatar
Re: 75 C10 shortwide driver
man you're doing that thing right my brotha.....can wait for future pics
made2drag is offline   Reply With Quote
Old 04-20-2012, 01:26 AM   #227
mcboomport
mcboomport's Avatar
Thanks man! Yours is turning out awesome!
I took mine apart again... I cut out my fenders and set them on and... I won't be able to turn much with stock width arms and my wheel backspacing. I was going to sell the arms I just got and get -1s., but that may be a pain. So I'm trying to figure out the best way to narrow the front.. I think I've decided to move the lower control arms in 3/4" per side. I have over an inch of shims on the uppers, so i know it will work. Just having a hell of a time laying out my cut lines to move the mounts.
mcboomport is offline   Reply With Quote
Old 04-20-2012, 01:34 AM   #228
mcboomport
mcboomport's Avatar
I also have been collecting parts the past few weeks, got a brand new gm headlight bezel for 10 bucks! Also picked up another small tailgate band, sport mirrors for the driver, a factory take off tailgate for 40 bucks! Gotta love Craigslist and the Portland swap meet.
Old 04-25-2012, 03:45 AM   #229
mcboomport
mcboomport's Avatar
So I've spent about a week laying out lines, scratching my head figuring out the easiest way to do this, and I thin I've finally figured it out. My goal is to move the lower control arm mounts in 3/4" per side. Sounds easier than it is... the upper a arms have at least an inch of shims, so I will still have adjustment there with a bit of grinding on the crossmember to clear the bushing portion of the arms. I will post pictures of that as I reassemble.
I layed out parallel lines with the portion of the crossmember where it bolts to the frame. This is where I will cut/ slide the mounts in ( the vertical lines shown are preliminary). The horizontal lines are about 3.5" below the top of the crossmember.
Old 04-25-2012, 03:51 AM   #230
mcboomport
mcboomport's Avatar
I got some scrap 1-1/2" tubing about 3' in length and bolted it it the crossmember with the ubolts. I drilled holes in the tubing so it would sit within the mounts. I used the biggest bit I had ( I forget the size) to clear the factory pop rivet.
Old 04-25-2012, 04:09 AM   #231
mcboomport
mcboomport's Avatar
I don't have pics yet, but what I did then was take some scrap 1 inch square steel and cut four pieces into about 9 inch long sections and two pieces that are about 18 inches long. I will be Bolting two sections with the pieces (3 per front, 3 per back). I drilled holes 6 holes in each 18 inch sections (3 per side, all spaced 3/4" on center) I drilled 2 holes 3/4" on center on each 9 inch section.. so, I will be Bolting the 2 - 9" long sections to the 18" sections, then, tack welding them to the 1-1/2" tubing. After these are secure, I will cut out each lca mount. The whole piece will then be lifted out, then I will move the bolted sections in the 3/4" per side as already predrilled. This will keep the lca mounts parallel with the crossmember section that bolts to the frame.
I will then have to tack the mounts, and work the crossmember to match the new angles. I will also replate the areas I disturbed.
Old 04-25-2012, 09:10 PM   #232
mineralgrey01gt
Man nice set up you have going on there. I read the entire thread and keep up the good work!
bagged c10 a.k.a 1lo8fo
2006 gmc sierra crew cab
2007 ltr450 a.k.a hell on wheels
mineralgrey01gt is offline   Reply With Quote
Old 04-25-2012, 09:56 PM   #233
Nobaddaze
Nobaddaze's Avatar
seems like a good plan. please post up losts o pics. what will moving your control arms in do to the position of the bag? will you just drill new mounting holes on your upper bag plate 3/4" in?
Hard work has a future payoff. Laziness pays off now.
My Build
Nobaddaze is offline   Reply With Quote
Old 04-25-2012, 11:22 PM   #234
luifer76
luifer76's Avatar
X2 i really want to see how this turns out so yes post lots of pics....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 05-01-2012, 03:00 AM   #235
mcboomport
mcboomport's Avatar
Haven't gotten much done on the crossmember, been working on my 250r and rewiring my buddys 250r for lights, putting a new carb/ jetting it for him. (it is the bike I built and traded for the paintjob on my project truck, so gotta keep the painter happy) Getting ready for some dune trips.
Got most of the cuts done.. I decided to not bolt the bars, just weld some tubing the will get cut 1-1/2" in width, then welded back together, then measured an even width and welded in with a bunch of bracing.
Old 05-01-2012, 03:04 AM   #236
mcboomport
mcboomport's Avatar
The lower a arms have an extra hole to bolt the bags about an inch out. If that doesn't work, ill shift the bag on the upper mount a bit.
Old 05-03-2012, 02:52 AM   #237
mcboomport
mcboomport's Avatar
Old 05-03-2012, 03:22 AM   #238
mcboomport
mcboomport's Avatar
I forgot to post these a few weeks ago. I trimmed the fenders and saw I wouldn't have much room for steering layed out.
Old 05-03-2012, 07:37 AM   #239
cletis
cletis's Avatar
Withall the planning that should come out nice, can't wait to see it done
I think I can, I think I can,
http://67-72chevytrucks.com/vboard/s...d.php?t=452601
cletis is offline   Reply With Quote
Old 05-03-2012, 03:05 PM   #240
Nobaddaze
Nobaddaze's Avatar
New shop looks nice.
My Build
Old 05-25-2012, 12:02 AM   #241
luifer76
luifer76's Avatar
any updates on the truck bro?...
Old 05-26-2012, 10:53 PM   #242
maxxxy
maxxxy's Avatar
X2!!!
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 05-29-2012, 06:09 PM   #243
mcboomport
mcboomport's Avatar
No updates. haha. I have been in two stroke mode as of late. Went to the sand dunes for memorial day weekend and I just bought some old two stroke street bikes (Yamaha RD400 and Yamaha RD350). I've been researching and getting the RD400 ride-able. I rode it around for about an hour last night, so I will probably get back on the truck in a week or so.
Old 01-03-2013, 12:43 AM   #244
mcboomport
mcboomport's Avatar
I have almost fallen off the squarebody grid as of late. I hopefully will be getting back on track shortly. I recently picked up a pretty cool daily driver that I have been giving a little bit of attention to, a 1950 Chevy sport coupe ( yes I know it has a 52 front clip). I also have spent a bunch of time on my street bike. Too many projects will make a man go mad. It would be easier if my obsessions were just with squarebody trucks! Ps. I have been watching most of your builds on here, it is always motivational.
Old 01-03-2013, 01:18 AM   #245
king-918
king-918's Avatar
You need to get back on this some parts remind me of mine and I may borrow some ideas
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 01-03-2013, 05:05 AM   #246
hotrodred
hotrodred's Avatar
I dig both trucks!
Jon Carr
hotrodred is offline   Reply With Quote
Old 01-03-2013, 12:17 PM   #247
luifer76
luifer76's Avatar
cool looking daily bro....
