Old 11-24-2010, 08:27 PM   #1
mcboomport
mcboomport's Avatar
75 C10 shortwide driver
I went into this project with the intension of a show truck, but after I built my 250r quad, I realized I don't know when to quit. I decided to make myself quit and build a decent driver. Every piece of front suspension is new/ rebuilt. It is going to have 20/22 inch bonspeeds, bagged with a KP Components 4-link/ cantilever. four wheel disc brakes. I started with a fairly clean 1975 GMC frame, had a few cracks where the front shocks mounted and where the power steering box mounts. Other than that it was pretty clean.
mcboomport is offline   Reply With Quote
Old 11-24-2010, 08:31 PM   #2
mcboomport
mcboomport's Avatar
Re: 75 C10 shortwide driver
I wire wheeled the frame. 7 hours. poor choice of stripping for sure! HA!
Old 11-24-2010, 08:35 PM   #3
mcboomport
mcboomport's Avatar
I used POR 15 on the frame. I followed the directions and it looked great. I then decided to use the POR15 Chassis Coat. It then flattened out the shine, but looked as if there was brush marks. I am not sure I am happy about it. After I get the chassis complete, I am thinking about wet sanding it and coming up with something......
Old 11-24-2010, 08:42 PM   #4
mcboomport
mcboomport's Avatar
POR15'd
Old 11-24-2010, 08:45 PM   #5
mcboomport
mcboomport's Avatar
Some random parts..
Old 11-24-2010, 08:47 PM   #6
mcboomport
mcboomport's Avatar
sheet metal
Old 11-24-2010, 08:51 PM   #7
mcboomport
mcboomport's Avatar
20" front/ 22" rear Bonspeed Sweeps. I've had these wheels sitting in boxes for about 8 years waiting for this build.
Old 11-24-2010, 08:54 PM   #8
mcboomport
mcboomport's Avatar
Bolting on front cross member / front a-arms. I have some tubular uppers that I will eventually put on.
Old 11-24-2010, 08:54 PM   #9
mcboomport
mcboomport's Avatar
SSBC oversized single piston front brakes
Old 11-24-2010, 08:58 PM   #10
mcboomport
mcboomport's Avatar
mock up tires/ springs to get it into the garage
Old 11-24-2010, 09:01 PM   #11
mcboomport
mcboomport's Avatar
got it into the garage. Just started bolting on the rear. I'm waiting on KP Components for my air management stuff.
Old 11-24-2010, 09:45 PM   #12
benoit454
Chris
benoit454's Avatar
wow nice work, looks great. So it's 7 bolts on each side once the motor mount plates are removed to unbolt the whole front crossmember? That's pretty cool, I wondered how many held it in place.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 12-10-2010, 11:47 AM   #13
72cheyennesuper20
72cheyennesuper20's Avatar
Bring on the bags.
72cheyennesuper20 is offline   Reply With Quote
Old 12-15-2010, 05:19 PM   #14
mcboomport
mcboomport's Avatar
Got some air management stuff finally after a few months of hell with some wrong parts.
I got the front bags in last night as well.
Old 12-15-2010, 05:36 PM   #15
87 chevy silverado
how did i miss this. subscribe
87 chevy silverado is offline   Reply With Quote
Old 12-15-2010, 06:00 PM   #16
Showboat1984
Sweet, Sweet, Sweet!!!
Showboat1984 is offline   Reply With Quote
Old 12-15-2010, 07:35 PM   #17
mooseknuckles
mooseknuckles's Avatar
I like where this is going!
mooseknuckles is offline   Reply With Quote
Old 12-29-2010, 12:28 PM   #18
mcboomport
mcboomport's Avatar
Got my valves and tanks mounted as well as ran some preliminary air lines until I figure out some other fitting options. I also got the front steering and suspension put together. I am having a couple issues, things to do prior to wrapping it up.
1- my bags rub a bit on my lower a-arms when fully decompressed. I'm thinking I need tubular lower a-arms......
2- a-arms don't lay on the ground. I still have about 2 inches to go. I have tubular upper a-arms, because I think the balljoints are binding and not letting it lay out.
3- The rear of the frame sits about 8 inches above ground when layed out(without bumpstops) I have about a 6" notch. I'm thinking about adding another 4 inches to the rear notch.
4- I'm going to section my front cross member and modify my sway bar brackets.
5-rear fuel cell.
6-run brake lines.
7-finish air line layout with grommets/ cleaner fittings ect.
Old 12-29-2010, 12:32 PM   #19
mcboomport
mcboomport's Avatar
Pictures of the front.
Old 12-29-2010, 12:34 PM   #20
mcboomport
mcboomport's Avatar
more
Old 12-29-2010, 12:36 PM   #21
mcboomport
mcboomport's Avatar
last ones for the day.
Old 12-29-2010, 02:45 PM   #22
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Looks like a great project!
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 12-29-2010, 06:08 PM   #23
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Looking great!!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 12-30-2010, 02:38 AM   #24
sgtvanmp
sgtvanmp's Avatar
Its coming along great. Where did you pick up the POR15? I think I am going to have to use this when I do up my frame.
Keep up the great work.
sgtvanmp is offline   Reply With Quote
Old 12-30-2010, 12:05 PM   #25
mcboomport
mcboomport's Avatar
Thanks guys! I've been wanting to get on this project for years now! I know it will never be done, but thats ok..
I got the POR15 off of ebay. We have a parts store called Baxters here that has it as well thats about the same price. Like I said above in my posts, I couldn't believe how amazing the stuff laid out and looked, my prep work was pretty much perfect. But then I tried putting their Chassis Coat black on top and it looks kind of like crap and didnt lay out smoothly..
