![]() ![]() Join Date: Jan 2005
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
More photos
![]() Join Date: Feb 2002
Fastening that nut prevents the Fender Skirt from becoming a Bongo on washboard roads.
I was gonna say Didjeridu, the Aboriginal instrument, but it turns out to be a wind instrument, not percussion. Carribbean Steel Drum is more what I was looking for.
The steel drum is painted now.
The tail lights are back together, and they are functional. I suspect it's been a very long time since bulbs were installed in these. They've been sitting out in the weather with no lenses attached. Took some lubrication and effort to get the bulbs in the sockets.
Patched the two 6x9 speaker holes in the driver door. I discovered there is a large dent in the lower center of the door like someone tried to close the door on a baseball batt. It's going to make it interesting trying to smooth out the patches with body filler. I might try to find some sort of small jack that I could use to push the dent back out. Had to get the door reinstalled because we're expecting rain again tonight. I've got two more holes to patch on the passenger side.
A few more photos
Dude musta loved his Rock 'n' Roll to have dual 6x9s in each door.
Qudraphonic sound seemed just about to happen in the Mid Seventies -- and then it didn't. Not enough medea support. The Industry wasn't ready. The public wasn't buying. ![]() ![]()
All about them K’s
![]() Join Date: Jun 2014
Strong work!! You are killing it. I feel like a worthless pile reading along and realizing I haven’t really touched any of my old trucks in 6 month. It’s a long story but I live 2 miles away from them for now so I guess I have an excuse lol.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
That would complicate things for me if my truck weren't at my house. The rain here has made progress a bit challenging. That's why I've been working on pieces that I can bring inside. I was planning on working on the bigger tasks first, but these little things need to get done eventually. I'm also waiting for some parts to arrive. Once it's time to install the engine, transmission and transfer case, I'll kick my wife's car out of the garage and roll the truck in.
#13 |
Got rained out again last night so I spent the evening doing some organizing, and I tested an AM radio I picked up for $10. It turns on and makes the typical AM hissing noises, but it can only just barely tune in stations. I'm thinking I might try replacing the electrolytic capacitors.
#14 | |
#15 |
#16 | |
When I bought the Orange Stepside, the PO had jammed in a GM AM radio. No pushbuttons so I assumed it was from the late '50s. [No tubes.] Antenna was a telescoping type, but laid flat above the dash. I ''improved'' the antenna with a Radio Shack antenna that was a thin copper wire that scotchtaped itself to the upper edges of the inside wingshield. In North Carolina I got a better oval speaker to fit under the louvers in the dash top. Before separating from the Service I bought a Sanyo AM/FM Cassette Receiver/Recorder at the MCX. I had it ''professionally'' installed in the dash and cut a 5.5'' Speaker hole in each Door. Rocked and/or Rolled all thru my College days. [Years later, I found the Dude had powered the radio off the Heater Control illuminator bulb feed.] I must have cut a 1'' hole for a springed AM/FM telescoping antenna with a Greenlee 1'' Hole Punch. I found the OEM 516 Orange Radio Delete inside the passenger door. I cut holes for the Sanyo's knobs and painted it wrinkle Black. I have a White Radio Delete Plate in the dash now. The old Jensen speakers are still in the doors, filling the holes. Nowdays, I tend to listen to my engine closely. That old Delco AM Radio might still be in the shed. I should dig it up and check it out.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 11-26-2024 at 01:58 PM. |
#17 |
Typically, electrolytic capacitors are little cylindrical aluminum cans. Also, I found a service manual for a 1965 Corvair truck radio online which appears to have the same circuit board design as 67-72 trucks. It has a board layout diagram that shows the locations of the capacitors and it has a list that includes a description of each capacitor.
#18 |
chevy truck fan
nice job on the speaker hole fixes... I did the same thing on my '72!! I feel like it is a right of passage to have to do the "ol speaker in da door" patches.... LOL!!!
#19 |
#20 |
![]() Join Date: Oct 2012
I got lucky and the PO cut them out above the kick panel closer to the window crank. Didn't bother to patch them since new door panels would cover them up. Never seen (2) speaker holes cut in a door, that was a first.
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#21 |
That was convenient. Two speaker holes per door is a first for me, too. My '68 had a round speaker hole cut down low on both doors. I bought a replacement door on one side due to exterior damage, and the replacement had a speaker hole, too.
#22 |
Received the replacement front wheel hub just now. Thanks so much, Nick B.,for helping me out!
#23 |
Cleaned up and painted the replacement hub. There is a slight difference between the new and old. The inner seal depth is not as deep on the replacement. The seals I removed from my originals were thin (.25") even though the hubs appear to be made for the .31" wide seals everyone sells. I have been looking all over the place, and I can't find any .25" wide seals. The old thin seal I've got says, "Made in Singapore" and "UF 0215E" on it, but searching for that goes nowhere. The wider seals will probably work just fine.
#24 |
I found a seal that should be the correct dimensions. It's SKF 24904. The I.D. and O.D. are the same as seal 442380, but it is .25" wide. It's what's spec'd for a 1974 Dodge W100. I ordered a pair of them.
#25 |
![]() Join Date: Jan 2007
You’re doing quite a bit more than I expected! Very cool.
Looking great, keep it up.
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
