01-03-2009, 03:08 AM | #251 |
60-66 Nut
Re: Our '66 Short Fleet Build
You're making some outstanding progress Joe!
I would just find a sandblaster that doesn't use silica sand and take the cab to him instead of soda. I've heard of some paint issues from blasting with soda.
01-03-2009, 03:16 AM | #252 | |
what issues have you heard of? you think I should find one that uses walnut shells or ??? just don't want regular sand to heat up the metal and warp it. i haven't really researched it much yet....
CHEVY ONLY |
01-03-2009, 03:35 AM | #253 | |||
60-66 Nut
I can't remember details at the moment, but some primers may not react well to any residual soda that may be present, and I'm not sure how well soda really is for removing rust.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 01-03-2009 at 03:36 AM. |
01-03-2009, 03:58 AM | #254 |
thanks for the info
i will look further into it I talked to Musclerodz awhile back and he told me of a blasting company around here that uses plastic media, so i will look into it
CHEVY ONLY |
01-03-2009, 09:31 AM | #255 |
Hey Y'all!!
A fella that I work with sells/restores mopars and parts. He swears by the plastic media blasting.
As Captainfab had stated, if there is any of the soda left in cracks and crevices (and how would you possibly get it all out of the seams??) it can cause you paint heartache later. On the subject of using sand, someone that is experienced with a sandblaster will not have any issues with metal warpage. The problem is finding a reputable 'blaster in my area. |
01-03-2009, 10:16 AM | #256 |
Hollister, CA.
Yeap, if you dont know what your doing, sandbasting WILL definately heat-warp the metal...I seen it first hand on my buddys 69 GMC hood.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
01-04-2009, 12:21 AM | #257 |
cool, i will be looking into the plastic next week......
not much progress today moved the engine perches to the forward holes (still need to drill the cross member for the lower bolts) and mounted the 700R4 to the 283 for mock up....found out the motor mounts are SHOT, the rubber has completely separated. I need to go pick up motor mounts and a trans mount before I can build a cross member i have a set of the newer style motor mounts and perches that i'm debating on using........ disclaimer: the trans is no where near the proper/final position, it is just sitting on blocks to hold it up for now.....
CHEVY ONLY |
01-04-2009, 01:22 AM | #258 |
Lookin' good Joe,I like your fabricated "cab lifter" and it's adjustable.
As far as blasting,I've been using coal slag or Black Beauty fine grit,it will remove rust and paint.It will heat up if you stay in one spot too long,but doesn't pit very much. I found that for paint removal that a steam cleaner works really well. |
01-04-2009, 01:26 AM | #259 |
thanks for the info olsofti!
CHEVY ONLY Last edited by joe231; 01-04-2009 at 01:26 AM. |
01-05-2009, 03:05 PM | #260 |
283 Drama Queen
That cab lifting tooling is outstanding!
Time to start renting it out, or sell plans for us to make it. Looks like it worked slicker than snot! Congratulations on your design and follow-thru.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
01-05-2009, 07:58 PM | #261 |
Its Deja Vu time again
Man seeing yours apart kinda annoys me because it makes me feel super lazy for not doing anything.
Thanks for all the cab pictures. Nice to see that gizmo in action |
01-05-2009, 10:55 PM | #262 | ||
feel free to borrow it any time you are around OKC it was pretty easy to build, the thread link posted back a page or two has all the dimensions on it. i'll never do the find some buddies/ a-frame/come-a-long thing again Quote:
well work is getting in the way of my free time again so it will probably be the weekend before I get anything else done oh, i did get the cab unloaded at work tonight. the cab jig works well with a forklift also now I need to get my cab dolly built!
CHEVY ONLY Last edited by joe231; 01-05-2009 at 10:57 PM. |
01-06-2009, 02:48 AM | #263 |
Flat Broke
Man Joe you are one busy guy!!! Keep up the good work, I'll have to come check 'er out one of these days once you get it back together (probably soon from the way you work lol). Let me know if you need a hand, I'm just down the road
01-06-2009, 09:01 AM | #264 |
thanks Sam!
you, jason65, scotts62, billysbowties, and i will have to get together one weekend
CHEVY ONLY |
01-06-2009, 09:13 AM | #265 |
Registerd User
01-06-2009, 04:43 PM | #266 |
Flat Broke
No doubt, im down
01-06-2009, 06:23 PM | #267 |
One day...
Yep im in
01-09-2009, 05:14 PM | #268 |
283 Drama Queen
Thanks for sharing Joe - that is a serious design.
01-09-2009, 08:19 PM | #269 |
CHEVY ONLY |
01-09-2009, 08:36 PM | #270 |
Nice lift Joe! I dont know how I missed this.
01-09-2009, 08:58 PM | #271 |
thanks Jeremy
CHEVY ONLY |
01-09-2009, 09:01 PM | #272 |
Resistance is Futile
Im kinda disappointed, actually. I thought it would have a control panel to show what floor it would go up to.
This is total ..................
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
01-09-2009, 09:10 PM | #273 |
that's a good idea............
CHEVY ONLY |
01-09-2009, 11:07 PM | #274 |
01-09-2009, 11:28 PM | #275 |
64-66 CHEVY JUNKIE
Time to start renting it out, or sell plans for us to make it. Looks like it worked slicker than snot! Congratulations on your design and follow-thru. I agree nice joe......
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E Do It In A Chevrolet |
