Old 02-15-2013, 04:51 PM   #301
Rusbuilt
Rusbuilt's Avatar
Re: She's a ton of fun (dually build on air)
I just got off the phone with Dave at PB!! I added A arms, sway bar and some of them famous PB hood hinges!!!!
Rusbuilt is offline   Reply With Quote
Old 02-15-2013, 04:55 PM   #302
JRANGER
JRANGER's Avatar
OMG!!! Its about to start happening!!!!! Lets do this!!!!
JRANGER is offline   Reply With Quote
Old 02-15-2013, 04:56 PM   #303
jkeating1
jkeating1's Avatar
Have you had a chance to shop NV4500's around Nashville? Just curious what the going rate is. I found a salvage one for $450 plus core, and a rebuilt with warranty for $1075, prob also plus core--which I don't have. So another buck and a half for that, I imagine.
JK
jkeating1 is offline   Reply With Quote
Old 02-15-2013, 05:05 PM   #304
Rusbuilt
Rusbuilt's Avatar
I have been looking for a 3500 or 4500, I've found a few but none I want to pick up yet. I have actually been debating on buying a whole truck so I know I get a good one. lol
Old 02-15-2013, 08:19 PM   #305
502ms
502ms's Avatar
Originally Posted by Xeen View Post
Rusbuilt do you realize you have nearly 250 replies and you haven't even started your project in earnest yet, popular much?
LOL!
And you guys talk about me. LOL!
I am excited though. I want a dually...plus I miss driving my stepper.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 02-15-2013, 08:21 PM   #306
502ms
502ms's Avatar
When I was debating on going with the T56 or the NV4500, I saw SEVERAL on ebay with 1 or 2 year warranty, free shipping, and remanufactured for $1099 and $1199. They were purty, too. But I decided I wanted the extra gears and the double OD.
Best Regards,
Leon M.
Old 02-15-2013, 08:23 PM   #307
Rusbuilt
Rusbuilt's Avatar
double over drive! lol
Old 02-15-2013, 09:10 PM   #308
jkeating1
jkeating1's Avatar
Good idea. That rebuilt didn't have shift tower, stick, bellhousing, release arm, throwout bearing, flywheel, slave cyl, master cyl---I know some of that stuff you'd want new anyway, but I'm jus sayin....
JK
Old 02-15-2013, 09:35 PM   #309
jkeating1
jkeating1's Avatar
BTW--while I've got your thread 'jacked for my own education, what do you use for hubs and rotors when you put a dropmember on a 45 yr old one ton? Are the spindles set up for hubs/discs that bolt up to the spacers it already has, to compensate for the wheel offset?
JK
Old 02-15-2013, 09:37 PM   #310
72k5zl1
72k5zl1's Avatar
are your mirror arms white or a brushed finish?
my build threads, 68 pro touring, auto cross c10 (mid life crisis)
http://67-72chevytrucks.com/vboard/s...d.php?t=464109
website http://www.sauersgarage.com/
72k5zl1 is offline   Reply With Quote
Old 02-15-2013, 10:19 PM   #311
Rusbuilt
Rusbuilt's Avatar
I'll be running 73-87 1ton 3" drop spindles and rotors. All I have to do is install the 1 ton ball joints in the PB arms.
They are brushed
Old 02-15-2013, 11:37 PM   #312
jkeating1
jkeating1's Avatar
[QUOTE=Rusbuilt;5891543]I'll be running 73-87 1ton 3" drop spindles and rotors. All I have to do is install the 1 ton ball joints in the PB arms.
Aren't the lug studs in a big spacer that bolts to the hub? Like 3" deep and 7 or 8" around, or is my memory fuzzy? If so, I guess you just get a stock one for a 73-87 1 ton, huh? Or IS that the hub?
And that T56-in-a-C30 idea is intriguing! Damn, if it can handle the torque of a Viper V10, it ought to be able to handle a HD truck pulling the occasional trailer! They have a funky output shaft though.
JK
Old 02-15-2013, 11:44 PM   #313
Rusbuilt
Rusbuilt's Avatar
I'm not sure I'm following your question.. Big spacer? Are you referring to 10 lug adapters?
Old 02-16-2013, 12:21 AM   #314
jkeating1
jkeating1's Avatar
No, I'm talking factory stuff for 8 lug. You're saying the front wheel bolts to a hub face that is the same as on a C20? So the control arms are longer? Or is the spindle designed to "stick out" farther? I mean---to compensate for the 9" or so backspacing of the front wheels.
JK
Old 02-16-2013, 12:30 AM   #315
Rusbuilt
Rusbuilt's Avatar
The only thing C20 I am using is the frame itself. I will be running c30 PB arms, 73-87 ball joints and spindles. With factory dually hubs/rotor.
Old 02-16-2013, 01:11 AM   #316
jkeating1
jkeating1's Avatar
Ahh! A picture's worth a thousand words! Its the outer half of the rotor/hub I was trying to describe. That answers my question. If you get the hub for a 83-87 DRW C30, that "spacer" as I was calling it, is just the outer half of the hub. Thank you--now I don't have to worry about scrounging the salvage yard!
JK
Old 02-16-2013, 12:27 PM   #317
67cheby
67cheby
67cheby's Avatar
gonna be SWEET !
67cheby is offline   Reply With Quote
Old 02-16-2013, 09:31 PM   #318
502ms
502ms's Avatar
Do it! I am excited about it. Think about the benefits....and yes you can make it do what you want!
Best Regards,
Leon M.
Old 02-16-2013, 09:55 PM   #319
lolife99
67-72 parts collector,…
lolife99's Avatar
Is Nate making your arms shorter so the wheels will tuck?
Keith
Convert to disc brakes.
Old 02-17-2013, 12:12 AM   #320
Rusbuilt
Rusbuilt's Avatar
Lol you're welcome.
Originally Posted by 67cheby View Post
gonna be SWEET !
Thanks Mike
That was actually originally posted by jkeating1. I don't think I will do a t56. I will more that likely be running the NV3500.
I'm not sure. I went ahead and placed the order for the arms with Dave so I could have it all cut with my dropmembers and I should be hearing from Nate about what exactly I should do on the arms. I welcome any input, especially from a wise suspension man like yourself!!
Old 02-17-2013, 12:16 AM   #321
Rusbuilt
Rusbuilt's Avatar
I do know the dm has a narrowed track width so that will help and if I do run semi wheels they will have a huge offset. I may be ok with a factory length arm.
Old 02-17-2013, 02:50 AM   #322
502ms
502ms's Avatar
Oh - gotcha. Well, in either case, you will be banging gears....funday funday!
Best Regards,
Leon M.
Old 02-17-2013, 11:08 AM   #323
Rusbuilt
Rusbuilt's Avatar
lol yes sir.
Old 02-17-2013, 11:30 AM   #324
lolife99
lolife99's Avatar
I guess I didn't realize you had the Dropmember also.
The 73-87 bagged dually guys run dually hubs with narrowed arms, or 1-ton single wheel hubs with "lengthened" arms.
I'm not sure if the Dropmembers narrowed track width will be enough.
Have you mocked up your front end, with the wheels you will be using, yet?
The stock set-up won't tuck.
As in this member's truck.
(I would ask Nate what he thinks)
Keith
Old 02-17-2013, 11:40 AM   #325
jkeating1
jkeating1's Avatar
I've been meaning to ask you--what's the difference between a 3500 and a 4500? And what is the 3500 in?
Here's a 3500 for that appears to be much less $ than 4500's
http://www.ebay.com/itm/CHEVROLET-19...5ac08f&vxp=mtr
JK
JK
dropmember, dually, patina, semi wheels
