Old 12-15-2024, 11:03 PM   #301
pjmoreland
pjmoreland's Avatar
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
My friend with the cab already sold the dash, so I decided to press ahead with repairing my existing dash. I cut out the center section and welded in the patch panel using a gauge bezel and glovebox hinge to set the alignment. I have not started repairing the rust yet.
I installed the driver side rocker panel. Ran out of daylight. Got seam sealer and a coat of primer on it.
pjmoreland is offline   Reply With Quote
Old 12-16-2024, 12:01 AM   #302
'68OrangeSunshine
'68OrangeSunshine's Avatar
That's gonna be better than a new truck, Pat.
Old 12-16-2024, 12:42 AM   #303
pjmoreland
pjmoreland's Avatar
Thank you. I sure hope so.
Old 12-16-2024, 06:59 AM   #304
CUSTOM/10
CUSTOM/10's Avatar
You make it look too easy !!!
Nice work...
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 12-16-2024, 08:34 AM   #305
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: 1971 K10 Stepside - Getting a Roller Roadworthy
You really get things done and quick too. Nice work thus far.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 12-16-2024, 11:44 AM   #306
pjmoreland
pjmoreland's Avatar
Thanks, guys. I copied the dash repair technique from Grumpy Old Man. He did the same thing where he left the lower structural support bar in place and made the cuts in places that are inconspicuous. It's gone smoothly so far. I still have lots of work to do on the dash though, and it's raining again.
Old 12-17-2024, 11:34 PM   #307
pjmoreland
pjmoreland's Avatar
It dried out enough today to get some paint on the rocker panel. I installed the door and fender a few hours later. Also took the driver side hub back off to install the correct inner seal.
Old 12-18-2024, 12:43 PM   #308
loudchevy
loudchevy's Avatar
Nice job knocking out those outer rockers. The dash replacement/repair looks difficult just based on doing it inside the cab and having the windshield in place.
Good progress.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 12-18-2024, 12:45 PM   #309
pjmoreland
pjmoreland's Avatar
Good progress.
It's definitely going to be awkward dealing with that welding blanket.
Old 12-19-2024, 01:45 AM   #310
pjmoreland
pjmoreland's Avatar
Patched the rust in the dash this evening. I have lots of grinding to do now.
Old 12-19-2024, 01:47 AM   #311
pjmoreland
pjmoreland's Avatar
Also applied some sealant to the upper corners of the windshield gasket.
Old 12-19-2024, 02:13 PM   #312
1970cstblazer
Good save! Fortunately a lot of that will be totally concealed once reassembled.
Old 12-19-2024, 02:42 PM   #313
pjmoreland
pjmoreland's Avatar
Yep! I won't have to put much effort into cleaning up the concealed welds other than grinding them flat.
Old 12-20-2024, 11:56 PM   #314
pjmoreland
pjmoreland's Avatar
Smoothed out the welds on the dash. Also filled several random holes that had been drilled in the floor and kickpanels. Also installed the driver side door seal.
Old 12-21-2024, 01:19 AM   #315
57taskforce
All about them K’s
57taskforce's Avatar
Excellent progress!
Tyler
57taskforce is offline   Reply With Quote
Old 12-21-2024, 03:20 AM   #316
pjmoreland
pjmoreland's Avatar
Originally Posted by 57taskforce View Post
Excellent progress!
Thank you. That dash ended up taking way more time than I thought it would.
Old 12-21-2024, 06:24 PM   #317
pjmoreland
pjmoreland's Avatar
It was raining this morning, and then it stopped. I took that opportunity to work on replacing the rear window. About the time I got the old window out, it started raining pretty good. I was committed at that point. Got soaked, but the window is in. So long to the "WILD" decals.
Old 12-21-2024, 09:08 PM   #318
pjmoreland
pjmoreland's Avatar
Painted some brake parts.
Old 12-21-2024, 10:24 PM   #319
'68OrangeSunshine
Don't like sliders?
Nice install.
Old 12-21-2024, 10:25 PM   #320
pjmoreland
pjmoreland's Avatar
Don't like sliders?
Nice install.
I don't like old leaky sliders.
Old 12-22-2024, 12:21 AM   #321
'68OrangeSunshine
Never ran with one. I do have a Sliding Back Window in a shed that a union brother gave me. The lock is busted off, though.
Seemed like a good idea when I had a big German Shepherd that was truck bed savvy. He could have been trained to hop inside at a couple of knocks on the back window.
But no dog now. Won't fit a Suburban or a Blazer, and I like the leakproof stock [for 56 years] back window I have.
Old 12-22-2024, 12:26 AM   #322
pjmoreland
pjmoreland's Avatar
I suppose it could be nice for getting some air flow going on a hot day. When I was a kid, I rode in the back of a truck once that had a camper shell on it that had a slider, and the cab had a slider, so we could communicate with the people up front.
Old 12-23-2024, 09:44 AM   #323
loudchevy
loudchevy's Avatar
I'm with you on the leaky sliders. Pretty sure the one on my truck caused all the rust I replaced on the bottom rail of the rear window. I'll be doing a single piece of glass like yourself.
Where did you get the glass and seal from?
Scott
2003 Tahoe Stock
Old 12-23-2024, 11:15 AM   #324
pjmoreland
pjmoreland's Avatar
The glass is a used original I got locally. It's Soft-Ray tinted. My plan is to replace the door windows with Soft-Ray as well. All I have found at this point is one of the large door windows, so I'm still on the hunt for the other windows.
The rear window seal is Precision brand from gmcpauls.com
Old 12-24-2024, 09:54 AM   #325
396ci
396ci's Avatar
i have a bunch of door glass you can go through.
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline   Reply With Quote
