#351 |
Now what??
Re: 1967 C10 Custom Big Window
Looks real good. I like the lines and insulation. I will probably bend my own lines. My stock ones are ok, but I "might as well"..
69 Long Fleet - Project 06 Ram 1ton Cummins 4x4-DD 01 Tahoe- wifes "The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi "A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell my, um, build ![]() USMC OIF Veteran SEMPER FI! ![]() |
#352 | |
Sofa King Crazy!!
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed"
#353 |
So I haven't checked in for a while. Wow, you have made a ton of progress on your truck and I have to say that thing is sooooo clean. Great job.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser 71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished 93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's 98 Chevy short bed DD 97 Z71 3 Door 51 Suburban-S-10 swap "What other hot rod can you carry 7 of your friends in"
#354 |
Under Construction
do you have the column in yet ?
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#355 | |
Sofa King Crazy!!
Um....Heath, patience. Waiting to get the elusive motor back from the shop.
#356 |
Under Construction
[/QUOTE]dont have much patience left these days... guess ill give you a break.....
#357 | |
Sofa King Crazy!!
dont have much patience left these days... guess ill give you a break.....[/QUOTE] I hear ya! Got my side mouldings in last night, gotta get a pic to prove it of course. Going to work on it after noon today, my paint and body guy is there now fixing a couple of things on the paint and getting my breather cover and valve covers ready for paint too. Feels good to be making progress when I am not even there!!! Will be starting to install my fuel neck today also.
#358 | |
![]() Join Date: Apr 2009
#359 |
Sofa King Crazy!!
I decided against moving the Xmember forward, it is more simple to shim the rear of the top a-arm and gain about 1 inch instead of going through all of the work and time of moving the Xmember forward to gain 1.25 inches. Also, tubular a-arms correct the geometry some too.
#360 |
Nice work.
#361 |
Sofa King Crazy!!
#362 |
Sofa King Crazy!!
Alrighty then......back to the pics. Weekend weather was not too bad so I was able to get a couple of things done. I had to create a little more room for the gas tank flange so I pulled out the fuel cell and mounted it on the bottom side of the top of the crossmembers, didn't take a pic....but it was done!!! I took the filler neck of off the tank and went to a muffler shop and had them weld in a pipe to make a flange out of the filler cap. Worked out good. I also had them put a 45 degree bend in the end of a 32 inch peice of pipe to make a fuel filler hose. The 45 degree bend is for clearance of the sending unit. The install of this has not happened yet but the parts are ready and I can cut the crossmember under the bed next weekend to install the pipe and hoses.
All of the wiring for my bags looked like a birdsnest so my friend Ronnie and I pulled it out and started fresh from the valves and rewired everthing all the way into the cab for final install. I put wireloom around all the wires to clean it up and protect them. Since we were already doing the wiring I decided to hook up the bag gauges. My paint and body guy came by on Friday and prepped the rockers for painting again. He closed the doors just a hair too much after he shot the paint the first time and it stuck a little bit. He should have that fixed and my breather cover painted next weekend.
#363 |
VA72C10
![]() Join Date: Mar 2008
Looking good...maybe you could have him touch up the cab corner while he's mixing up paint anyways.....
Looking for a 67-72 swb or blazer project in or around VA.
#364 |
Under Construction
looking good.
#365 | |
Sofa King Crazy!!
Thanks Heath!
#366 |
Now what??
Nice progress
#367 |
Heath, that truck sure is coming along, i love it. Out of curiousity, what bag kit are you using and size of bags for the front. Thanks. James
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#368 | |
Sofa King Crazy!!
#369 |
Sofa King Crazy!!
Here's the update I have been wanting to post, fuel cell filler hose install. The placement has been though out and it looks like it will be a simple install, then again nothing is simple when you actually do it. For you long bed guys I got a measurement for the Summit Fuel Cell and you won't have to buy a flange for the cell. Here ya go.
I pulled the bung out of the fuel cell and had a local muffler shop weld in a 2.25 pipe inside it. The measurement from the back of the bed floor to the center of the fuel cell filler neck was 26.25 and in the center of the bed. The x-member will have to be cut about 7 inches to allow for the 45 degree bend in the pipe to clear the sending unit. There is approximately 7.5 inches between the x-members under the bed so that worked out perfectly to run the pipe to the side of the bed. The pipe was left a little long on purpose, 32 inches from end to end. I have options on how to run it through the bed floor to the filler neck now, I can either have the pipe bent at a 90 straight up or use a peice of 90 degree fuel hose from the filler neck to the pipe. And yes this will all be under the bed. ![]() Summit, Jeg's, Speedway, Competition Sales all have fuel filler necks that will work for my application. I will be using a 45 degree neck so that it makes it easier to fill. Since there are already 2 bends in the filler hose and 1 bend in the pipe, my only concern is fuel kickback so I am choosing not to make another 90 in it to get it closer to the rear of the bed (unless someone tells me otherwise). The 45 bend in the filler neck should be sufficient to get it close to the rear. The big brown truck came by bearing gifts. I was really happy with the quality of these mouldings, plus they were made by MAR-K in OK City, USA. They are on sale right now, and that made them cheaper than the competition can sale and ship their imported, foreign made mouldings!! And check out the packaging!
#370 | |
#371 |
Sofa King Crazy!!
It's alright! Look at the amount of people on here, it's hard to keep up with everyone's real name!
#372 | |
Under Construction
there is only one ME, the world could not handle 2! ![]() Great progress David !!!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 01-28-2010 at 04:23 PM. |
#373 |
Sofa King Crazy!!
Thanks Bro. I was worried about how to do this and it is simple when you finally get it figured out.
#374 |
Still Learning
The new moldings look awesome! I'm sure they will look even better on the truck. I am assuming your gonna do a spray on bedliner? Or are you waiting to paint the bed floor till after you install the gas filler?
#375 |
low n' slo
![]() Join Date: Mar 2009
those moldings are gonna look good man. hey whats the status on the motor and trans?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
| Bookmarks |
| Tags |
| 1967, custom, lwb |
