Old 09-22-2016, 08:53 PM   #351
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
Thanks guys. I will look into it. Today I cut out that ugly ledge in the drivers side frame that I will not be using anymore.
Wade
SSABMUD is offline   Reply With Quote
Old 09-22-2016, 08:58 PM   #352
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
Max the Inspector Goldendoodle, came down to the shop for a surprise inspection. He was catching sparks but figured out some of them were hot. So I also cut out this bump. Then I built a new transmission crossmember.
Wade
Old 09-22-2016, 08:59 PM   #353
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
Here is Max. 10 months old and going to lose his knackers very soon.
Wade
Old 09-22-2016, 09:02 PM   #354
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
Going to take the weekend off of the frame. Maybe do some thinking (usually means more work).😊
Wade
Old 09-22-2016, 09:03 PM   #355
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
Wade
Old 09-23-2016, 02:45 AM   #356
Nut Case
Nut Case's Avatar
Re: My 1952 truck.
SSABMUD
The frame looks great, moving right along. Your welds look like you have done it before.
Max is great, my labradoodle Tucker is 7 and the smartest dog I have ever had. He hangs in the shop until I use the cutting disk/grinder, then hes out the door..
Good luck on your back
Keep on keepin on
Nut Case
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 09-23-2016, 06:53 AM   #357
99 to Life
99 to Life's Avatar
Re: My 1952 truck.
dang you aint playing around on that frame. not many of use would take the time to do that! I have a goldendoodle she is 1 and you'd think she has balls that need snipped. She is wild as ever. Takes stuff off my work table and chews it. She's destroyed many things.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 09-23-2016, 08:18 PM   #358
lower50's
lower50's's Avatar
Re: My 1952 truck.
Frame looks Great nice patch. I had a Golden doodle, best dog ever.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 09-23-2016, 11:37 PM   #359
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
I really need to get some shocks soon and need some advice or suggestions. I want a nice riding shock that I can also set the ride height with. I have no idea what these trucks weigh front and back. An air adjustable shock would be ok as I want a static suspension. She is going to be fairly low and staying that way. Maybe just a good adjustable coil over?
Wade
Old 09-23-2016, 11:49 PM   #360
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
Wade
Old 09-24-2016, 11:59 AM   #361
99 to Life
99 to Life's Avatar
Re: My 1952 truck.
I'm about to try the belltech nitro shocks. learned that from this good ol' site.
Old 10-02-2016, 01:19 PM   #362
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
Been working hard the last couple weeks. My camera on my phone died sopics have been few. Here are a few pics to catch up.
Wade
Old 10-02-2016, 01:25 PM   #363
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
I have a lot of work to do! I have to finish up the rear of the frame, cut off my fuel filler as I have changed my mind on it, and start brake and fuel hard lines. In the near future I need to remove my running board brackets and clean up the frame, then reinstall the brackets properly. (They were just tacked on at mock up of the truck).
Wade
Old 10-02-2016, 01:45 PM   #364
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
Wade
Old 10-03-2016, 10:41 AM   #365
99 to Life
99 to Life's Avatar
Re: My 1952 truck.
I luv a rolling chassis shot. looks great. I agree on the RB brackets. I always bolt mine on with s10 builds. I always hit my shins off them!
Old 10-03-2016, 11:07 PM   #366
lower50's
lower50's's Avatar
Re: My 1952 truck.
You have been busy! Looks great!
1951 MG TD
Old 10-09-2016, 08:27 PM   #367
fisherman420
Re: My 1952 truck.
Nice work, you've got some good progress completed....I wish I could say the same on my project. With the snow we got the last couple days hopefully you installed that psi maker on that pro!
fisherman420 is offline   Reply With Quote
Old 10-10-2016, 11:10 AM   #368
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
I still have not recieved my turbo for the sled yet and with the snow coming it's making me a bit bit-hy. Still waiting for the camera for my phone also. Grrr.
Wade
Old 10-10-2016, 11:15 AM   #369
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
Well I managed to get the fuel system fabbed up and also all the brake lines. Put my Lokar filler tube on along with the kickdown cable. Also put in my starter. Went to the swap meet here on Saturday and came home with a transmission pan, and some rear coilovers.
Wade
Old 10-10-2016, 11:16 AM   #370
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
Wade
Old 10-13-2016, 02:54 PM   #371
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
Geez Louise, this power steering pump has been giving me fits. When you mount your body lower on the frame you always pay for it somewhere. I think this combination will work. Waiting on my pulley to show up before I know for sure.
Wade
Old 10-13-2016, 03:04 PM   #372
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
Truck is put together again for the most part so I can finalize things before she starts getting some paint. I have the rear sitting where I want it but the front needs to come down two inches.
Wade
Old 10-13-2016, 03:35 PM   #373
joedoh
joedoh's Avatar
Re: My 1952 truck.
wow, easily one of the cleanest s10 swap trucks on the site! love the wheels!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 10-13-2016, 06:32 PM   #374
lower50's
lower50's's Avatar
Re: My 1952 truck.
Now you must be happy with that! It's going to sit real nice.
1951 MG TD
Old 10-13-2016, 07:31 PM   #375
SSABMUD
SSABMUD's Avatar
Re: My 1952 truck.
There is no interior, hood, grill or bumper yet. I'm thinking that will add close to three hundred pounds. I think one more inch yet. I want the rear of the front fender a pop can high.
Wade
