Old 05-08-2009, 03:00 PM   #376
sweet70beast
sweet70beast's Avatar
Re: 66 slammed hearse
Originally Posted by jonzcustomshop View Post
yet again, where are the pics?( of the house)
Ya where are they?
The real question is, Do you have enough room for my stuff?
I'll bring my camera to cruise night tomorrow night and see if we can get pics afterwards, besides Michelle wants to look at that bus.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 05-08-2009, 07:05 PM   #377
aboz
aboz's Avatar
As far as a top of the line prop coffin, I would build the frame from 1" angle aluminum and skin it in 1/4" lauan plywood. The curved surfaced top would be fashioned from a slab of carvable polyurethane foam. The entire outer wood and foam surface would then get a layer of fiberglass cloth and resen finished off with skim coats of bondo, sanded, primed and painted. Nickel plated accent handles and trim would then be attached. If the inside were to be finished out I would cut panels of coreplast lightweight plastic to match the top, bottom and sides. I would then cut and glue in 1" to 2" thick pillow foam sheets to match the shape. These would be covered in a red velvet-like material and matching velvet buttons would be punched through. This is top of the line mind you and would cost $3000-$3500. Then again a simple old fashioned classic wood coffin could be made entirely of wood and painted black for about $500.
ABOZ
aboz is offline   Reply With Quote
Old 05-09-2009, 09:17 AM   #378
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
Is that a pass the buck Jared? Thanks for all the well wishes
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 05-10-2009, 12:54 AM   #379
kdrodworks316
KOFFIN DRAGGER
Well our second cruise nite was a big success! we had about 8 cars show up and I was representing our class of trucks with the hearse. I know Mr. passthebuck took pictures, so its on him to get them up. We had a nice mix of beautiful paint to rattle can paint to rust rods on display in the Arctic circle parking lot.
Jared and I are going to take pics of the new home of KD rodworks tomarrow afternoon. Its a little rough, just like everything else I own. But it will be getting the KD treatment very soon.....now what have I done with the custom painted kitchen appliances?
Old 05-10-2009, 11:55 AM   #380
michael bagby
michael bagby's Avatar
Originally Posted by kdrodworks316 View Post
Ok these brakes are really starting to grind me the wrong way. I havent drove her for a week and I get in to take her home and looky there, the pedal goes clear to the floor. It will stop, but you got to really want it. No leaks, master is as full as it could be, I'm at a loss here? any ideas? I am going to replace the rear shoes this weekend, but they dont look to bad compared to the new ones. The front pads are about 85% or more. More bleeding? I used a pressure bleeder and got clean fluid to all 4 corners. I dont know anything else to do. HELP! Oh, and I still cant figure out my left turn signal problem. I got it at the switch and the fire wall, but not the tail. Its all new and shows no sign of damage. I have checked for bad grounds and they seem to be ok. Got a taillight, no brake or turn on the left.
this is probably answered just found post couple days ago &my to do list grows but your vacumm line from carb 2 booster is it completly clear as well as port on base of carb ive seen your scenario with that being the cause like i said probably done & im late as usual but i tried
michael bagby is offline   Reply With Quote
Old 05-10-2009, 10:00 PM   #381
sweet70beast
Oh no, this thread is about to be highjacked. Someone call homeland security!
Here's the pics from cruise night.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
Old 05-13-2009, 08:36 PM   #382
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
I got your hi-jack.....
still not one picture of the LED kit lit up
and a lil off topic question: does speedway motors sell 3" drop spindles for an 89 R3500??? how about home depot
nuttin but love,
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 05-14-2009, 01:48 AM   #383
kdrodworks316
KOFFIN DRAGGER
Speedway does not sell a spindle for that app, as far as I know. Check it out for your self www.speedwaymotors.com
On the subject of LED lights, I would love to stay out past dark and get those pics for ya RL, but I am still having charging problems, so I have to be home before dark or the burban dies and there I sit. I will get my offical/unoffical picture taker guy to address this problem asap(thats you Jared) So maybe this weekend I can make that happen for ya.
I also made another change to the Rat build, I decided that 350 cid was not near enough to get my blood pumpin, so 427 cid with 3 dueces later, I may have barely enough to raise my heartbeat. I will be setting it between the rails this weekend, pics to follow soon after(Jared thats you again) It ought to fill the windshield up nicely with the 3 dueces and some loud as hell zoomie lake pipes sticking out the side. I got to stop talking about it, my pants are getting tight in front.
Old 05-14-2009, 01:55 AM   #384
kdrodworks316
KOFFIN DRAGGER
teasers......
Old 05-14-2009, 07:24 AM   #385
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
dual thermostats?
truck motor?
Old 05-14-2009, 01:39 PM   #386
RunninLo
RunninLo's Avatar
As much as I'd love to tell you to switch to big boy britches and stay out and play I understand. Being sidelined in the dark isn't as much fun as one might expect. Not like I haven't seen 'em on a ton of other cars anyway.
At least you're out driving yours, all of my stuff is getting mothballed for the time being due to lack of funds or parts. Just had to shell out $128 to renew my CDL that I don't even use. might be good to have though if I'm ever looking for work again. seems somebody always needs something hauled and I do have access to a KW and flatbed that is just sitting.
Josh
88 4x4 crew DD
Old 05-14-2009, 04:26 PM   #387
joe231
joe231's Avatar
I feel your pain Josh....I just hate to turn loose of my CDL, just in case...
even if the economy gets worse, there will always be a demand for truck drivers
CHEVY ONLY
Old 05-15-2009, 12:04 AM   #388
Captainfab
60-66 Nut
dual thermostats?
truck motor?
Yep! looks like a tall deck to me
You're going to need some intake spacers if you're puttin a tri-power intake on that engine Derric.
Old 05-15-2009, 08:39 AM   #389
jonzcustomshop
1961 crewcab
He might have a trick up his sleeve....
speedway sells a tripower adapter that bolts right up to a 4bbl intake...
Old 05-15-2009, 09:19 AM   #390
kdrodworks316
KOFFIN DRAGGER
Yep, truck motor. I am not sure if its a tall deck yet, but the captain is right, I may need intake spacers. I am going to change the intake to a performer and then put the adapter on top of that. If I do it that way, I can still use HEI. The regular 3 duece intake doesnt accept HEI. Anyone got any spacers laying around? The price was right, considering it has been well maintained and never rodded, FREE! It came out of a rolled over tater truck last fall from work.
Old 05-15-2009, 12:54 PM   #391
Captainfab
60-66 Nut
Just remember that the tall deck distributors are longer than the ones for the regular V8's
Old 05-16-2009, 09:55 AM   #392
kdrodworks316
KOFFIN DRAGGER
I am pretty sure its a regular deck. I havent got the intake off or pulled the distributer yet, but just looking at it. As soon as I know for sure I will let everyone know.
And remeber its cruise nite! If you are in eastern idaho, come on over to arbys in rexburg at 7:00pm tonite and join in the fun. Pics to follow, Joe and Jon.......
Old 05-20-2009, 10:55 AM   #393
sweet70beast
Here's the new house.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
Old 05-20-2009, 12:15 PM   #394
joe231
joe231's Avatar
CHEVY ONLY
Old 05-20-2009, 08:13 PM   #395
sweet70beast
What I meant to say was, "The world headquarters of KDRodworks".
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
Old 05-24-2009, 01:40 AM   #396
kdrodworks316
KOFFIN DRAGGER
Yep, Jared is right. Hopefully the bank moves a little quicker so I can move in!
Got the big block in the rat today, Im kinda under the gun because my body man is moving away and taking all of his cool tools with him. So I got to get as much as I can done between now and monday. We have also been working on Jareds skylark, Its on the frame rack getting pulled in new directions. I also picked up the rearend for the rat, will be putting it in tomarrow and getting the rat on its own feet. So I am getting closer to the end on this project, still have to wire it, plumb the brakes and fuel system, mount the fuel tank, mount the battery box, finish the steering, install the pedals, plumb the clutch, burn in the body mounts and bolt it down, build a floor and firewall, install the radiator and cooling system, build the loud as he** zoomie headers, install the throttle pedal and linkage, install gauges, install glass, reinstall the door latches and window regulators. figure out a shifter for the saginaw, french the taillights, install the wiper motor and 1 wiper, finish the body work, rebuild the carbs, get a driveshaft built, install the calipers and rotors/hubs, find some tires and wheels, install the clutch, hmmmm did I forget anything? Pics should be up soon, I knoe Jared took some of the new engine. And yes, captainfab and Jon were right, it is a tall deck. So I need some intake spacers, anybody got some? I also need a short waterpump for a bbc? More updates and pics thru the weekend. I am taking my lil boy camping sunday afternoon, so all work stops at about 5:00pm
Old 06-04-2009, 01:07 AM   #397
kdrodworks316
KOFFIN DRAGGER
Well, my body man moved away and closed his shop, so KD has a new shop!KD rodworks has moved in and I am open for business! Finally! Now all I need is a good web person to fix my site up and fire up the plasmacam! any takers? SuzQ any good with websites?
Old 06-04-2009, 02:07 AM   #398
sixfour4x4
sixfour4x4's Avatar
i can/will help you out...
'64 4x4 Stepside 350/sm420, going L92 in the near future
'05 GTO that gets more attention than my truck
'69 Jeepster Commando that needs more attention than my truck
'71 wagoneer that gets less mpg than the gto
sixfour4x4 is offline   Reply With Quote
Old 06-04-2009, 07:33 AM   #399
jonzcustomshop
1961 crewcab
I see you moved a little farther away from the big city...
Old 06-04-2009, 03:52 PM   #400
Captainfab
60-66 Nut
So you aren't sitting it that brown KW anymore?
