Old 02-18-2012, 10:05 PM   #376
Conundrum
Conundrum's Avatar
Re: No Limit '72 C-10
I have another question on the caster mod.....
Is there a reason for moving the lca forward 3/4" and uca 1/2" rearward instead of moving them both 5/8"?
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 02-19-2012, 01:02 PM   #377
hairlesshobo
hairlesshobo's Avatar
The more you move the lower forward the more it will center the tire in the fender well. Other than that, I don't see a reason. Someone correct me if I'm wrong...
Shawty: '84 C10 Silverado SWB, 700r4, SBC 350 - 4 bolt main, bored 60 over w/ Weiand aluminum intake and moderate cam, 2" true dual exhaust, Thrush mufflers, 3.42:1 gears -- Build Thread
The Tranny (wrecked ): '86 Trans Am, SBC 350 (now in above truck), Borg-Warner T-5, 2" true dual, Thrush mufflers, 2.73:1 gears
hairlesshobo is offline   Reply With Quote
Old 02-19-2012, 01:26 PM   #378
Conundrum
Conundrum's Avatar
When I Zed my frame I moved the whole front suspension forward so my wheels are centered.
I was wondering if it had something to do with the steering?
Old 02-20-2012, 09:58 AM   #379
aggie91
I'm just glad to be here!
aggie91's Avatar
This gives you a big improvement in caster. It also helps center the wheel in the opening on some years. Most of the benifit is in the increased caster, thats why you move the lower forward and the upper rearward.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-20-2012, 01:25 PM   #380
Conundrum
Conundrum's Avatar
I get the change to caster, but what I was wondering was if there was a specific reason for moving the lower 3/4" and upper 1/2" instead of an equal 5/8" each?
Old 02-20-2012, 01:30 PM   #381
mooseknuckles
mooseknuckles's Avatar
....more caster.
mooseknuckles is offline   Reply With Quote
Old 02-20-2012, 04:14 PM   #382
robnolimit
robnolimit's Avatar
when I did the JT, I went 1" on the bottom, and shimmed the top. You need about 1 1/8" to 1 1/4" of offset between the top and bottom ball joints to get the caster in range. There are many ways to do it. Stock C-10's have the wheel too far back, and the lower you go, the more noticable it is. Moving the ball joints in a way that helps cure this gives you a 2 for 1 mod.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 02-20-2012, 06:13 PM   #383
Conundrum
Conundrum's Avatar
Thanks Rob!
I don't have to worry about moving to wheel forward because I did that when I Zed the frame. So I think i'll go with 5/8" top and bottom then so that my wheels stay centered.
Old 02-22-2012, 11:17 AM   #384
mild2wild
What are your wheel and tire specs?
mild2wild is offline   Reply With Quote
Old 02-22-2012, 12:16 PM   #385
robnolimit
robnolimit's Avatar
We're running 18 x 9 wheels all around, with 275-40-18 BFG KDW
Old 02-25-2012, 09:47 AM   #386
truck farmer
Hey Rob, correct me if im wrong but, did you say in an earlier post that if we already had your panhard bar kit that you would take some off the price of the rear sway bar kit? since i already have the trailing arm brackets.
truck farmer is offline   Reply With Quote
Old 02-25-2012, 12:34 PM   #387
robnolimit
robnolimit's Avatar
yep, you already have theTA mounts, so you save $25 bucks.
Old 02-25-2012, 02:26 PM   #388
duallyjams
duallyjams's Avatar
What is the b/s on the wheels and what is the over all height and width on the tires.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-25-2012, 07:44 PM   #389
truck farmer
Thanks Rob, I'll be ordering that shortly. how do I let them know I already have the TA mounts when I order?
Old 02-28-2012, 06:59 PM   #390
Conundrum
Conundrum's Avatar
Hey Rob, not wanting to sound pushy but do you think that 3/4" is a safe amount to drop the uca mounting points? I'm getting ready to section crossmember and I am going to incorporate the caster mod as well and was thinking of welding the crossmeber to the frame this time. Just curious, I can wait to weld it in until after the math is done for this mod if it needs more research still.
Old 03-12-2012, 02:09 PM   #391
aggie91
aggie91's Avatar
Just so you know, the stock exhaust manifolds would not fit. So, we got a set of the new Hedman 3/4 length for LS. When I was a kid, Hedman was not so great. But I have too tell you, these are NICE. 3/8" flanges, 16 gauge tubing, and nice collectors. Here's the best part, they fit GREAT! I can tell we'll be using a lot of these in the future.
Rob - Do you have a part number for these headers? I've searched but can't find a Headman set that looks like the ones in the pictures in that post (Post #195). We are did a raise crossmember in an '82 and will be using a 5.3 out of a GMC truck. We liked how the headers you used fit.
Thanks,
Karl
The LST Challenge:
Old 03-13-2012, 03:44 PM   #392
robnolimit
robnolimit's Avatar
I'll look for it. We're in thrash mode at the moment, may be wed.
Old 03-13-2012, 03:53 PM   #393
aggie91
aggie91's Avatar
Thanks, Rob
Karl
The LST Challenge:
Old 03-14-2012, 01:03 PM   #394
Low Elco
Aggie-Page 8&9.
The headman part # is 45660. They are available plain, or HTP ceramic coated.
Low Elco is offline   Reply With Quote
Old 03-15-2012, 01:00 AM   #395
robnolimit
robnolimit's Avatar
thanks Elco
Old 03-15-2012, 04:13 PM   #396
Greywolf200
Congrats on the feature in Street Trucks on JT.
Jack
Jack Byrd
'70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4
'76 Airstream Argosy MH(want a longer one), 454CID, TH400
Greywolf200 is offline   Reply With Quote
Old 05-04-2012, 12:10 AM   #397
Littletony
Littletony's Avatar
x2
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945
Littletony is offline   Reply With Quote
Old 05-04-2012, 10:45 AM   #398
robnolimit
robnolimit's Avatar
wheels are 18 x 9, with 6 1/4" bs. I would have liked 5 1/2" bs, but these were donated. Tires net at 27.8 x 10.75
Old 05-19-2012, 08:34 PM   #399
Can't kech me
Can't kech me's Avatar
We set the cab on using urathane mounts, and squared it all up nice. Next, we slid in our used 5.3 and boted it in. Now, I bought an ECE mount for the trans, and I like it a lot. It catches both the top and bottom of the frame, so it would help stiffen the chassis. But, someone welded in some tubes in our chassis, so the ECE mount won't go in. So we used one of ours. Urathane on the motor mounts, rubber on the trans. The oil pan hung down a bit, so we cut it off, shortened the pan 1 3/4", and added to the sump a bit forward. (i'll get some picts) The motor is as far back as we could get it in the stock firewall.
Ok, i pmed you about this, but i finally took the time to figure it out, is the oil pan steel or aluminum? if it is steel what kind? Could i do it with a MIG welder on 75/25 carbon/argon with regular .023 wire for steel? thanks so much if i am able to shorten the sump myself it save me a TON of money
"As I walk through the valley of rice i fear no honda, for i have torque!"
Can't kech me is offline   Reply With Quote
Old 05-20-2012, 10:10 AM   #400
robnolimit
robnolimit's Avatar
The pan is aluminum, and a fair job to modify. Now, you can get new pans from Speedway, Summit, and Jegs for cheap.
1972 chevy, c-10, no limit engineering
