11-29-2011, 12:34 AM | #4301 |
Re: What did you do to your truck today?
Installed my newly designed mirror arms. The original made it so that the bar between the side window and the vent window landed smack in the middle of the mirror. So I cut about 3 inches out of the arm and welded it back together and painted it black. I think my next step is to get a 5" convex mirror head to give me great visibility.
11-29-2011, 01:36 AM | #4302 |
[ATTACH][/ATTACH] went from one 6 to a new 6
11-29-2011, 01:06 PM | #4303 | |
11-30-2011, 12:07 AM | #4304 |
After making a final decision to use the Caprice core support mounting hardware I cut the holes and welded in plate to hold the 64 core support. Looked over the Caprice radiator and made mental notes on how to integrate it.
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
11-30-2011, 12:16 AM | #4305 | |
Senior Enthusiast
11-30-2011, 01:39 AM | #4306 |
thanks hope to have a cool truck like everyone else on here some day
11-30-2011, 03:00 AM | #4307 |
Redneck Hillbilly
Still driving her every day, and loving it.
12-02-2011, 10:01 AM | #4308 |
Installed my new-to-me Deluxe heater. I have to admit, at first, I was thinking - "Man, that sure is a SMALL heater core." It didn't take long to change my mind though!! I could've baked bread in the cab this morning!! During my 20-minute drive to work, it got SO hot in the cab, I had to turn the heater ALL THE WAY OFF and roll down the window to get some relief!! I wired up the blower motor switch last night just to make some heat til today, now, I need to figure out what all the flappers and cables do and get them installed and connected.
12-02-2011, 10:15 AM | #4309 |
I just about have the underside of the cab repaired, just one more front cab brace to go. I painted the firewall section flat steel blue and undercoated the floor while i had some warm weather. Now it's back to normal temps and I hope to tip the cab back down so I can get it in the garage but it's freakin pitch dark at 4:45 in the afternoon....sheshh!
12-02-2011, 10:42 AM | #4310 |
samuellg1977, thank you for your military service and protecting our freedom. If it was not for YOU we couldnt enjoy the priviledge of extreme hobbies like this. Thank you...
12-02-2011, 03:01 PM | #4311 | |
Sam |
12-02-2011, 09:08 PM | #4312 |
Today i printed out and used this thread http://67-72chevytrucks.com/vboard/s...elay+headlight and wired up some headlight relays into my truck and the difference is AMAZING! My low beams look like high beams now! this upgrade is so great i already went and got another set of relays that im going to wire into my other classic car.Thanks "markeb01" for the great right up!
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
12-02-2011, 09:09 PM | #4313 |
Painted my thermostat housing to continue the dechroming of Stanley...
Build Thread - Papa's truck build up |
12-03-2011, 09:05 AM | #4314 |
The plan for today is to finish off the '69 and get it back on the road. had a slight delay,waiting for new headers. Interested to see how the new cam/intake combo improves it. Waiting on a new dual electric fan setup, but put the clutch and original shroud on for now with a new triple pass aluminum radiator. Bought a Gearvendors over/under drive off another site and should be hear by next weekend, so will be able to cruise the highway at about 2200-2400 rpm and still keep my 4.11 gears and my TH400. She is working on her little project and we hope to fire off that big block maybe tomorrow for the first time.
12-03-2011, 11:51 AM | #4315 | |
Senior Enthusiast
12-03-2011, 01:43 PM | #4316 |
What kind of relay do you use for headlights ? I am not electrically inclined, so I don't have a clue. Thanks
12-03-2011, 03:54 PM | #4317 |
if you go to your local parts store ask for a heavy duty headlight/horn 30 amp relay they will get you the right ones cost around $5 each or you caan get them on ebay : http://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313
12-03-2011, 11:22 PM | #4318 |
Picked up a "parts" truck today for the fleetside bed. but the truck seems to have a lot of good parts.. Spent some time cutting up the caprice radiator support and mocking it into the 64. Hopefully I will have it ready to put in tomorrow so I can start figuring out what to do with the inner fenders..
12-04-2011, 12:40 PM | #4319 |
worked on the passanger sie sunvisor mount and striped down the rear saw bar for powed coating will take it all in next week..
12-04-2011, 12:57 PM | #4320 |
here is the sway bar
12-04-2011, 01:00 PM | #4321 |
All went somewhat well. The '69 is running and performs great. BUT the gear drive I chose is horrible. Not the good sounding whine some like, this has more of a growl-not pleasing at all. Removing it tomorrow night and going back to chain. Was very pleased with headers- been very happy with the Patriot brand lately. Hope you all had a good weekend. Lots of cool projects going on. Hope to get back to my '65 Burb next week-had to fix shop truck first.
12-04-2011, 01:06 PM | #4322 |
If you chose a fixed idler gear drive like the sig erson, quiet one they sound a little better, pete jackson dual idler drives are notorious for some reason for he growling, even though I chose a quiet gear drive for my coupe, after several long road trips it sorta made me nuts......
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
12-04-2011, 01:14 PM | #4323 |
First....this is a great site, I'm really glad I got on board and joined. I'm really amazed at the projects and talent here.
As for one of my trucks (one is '66 one is '72), I'm in 'wait' mode for a week until a shipment gets here with a brand new grill/insert ('72) as well as new cab bushings, some chrome trim pieces and then a few used pieces. All of this is coming in from good ol' Bill Peeters of 'Bills Truck Shop', Ontario....good guy. My '66 is in hibernation in the garage....but I'm going to hopefully fire it up and pull it out long enough to do some rustchecking on it before tucking it back in again. As for today, well......just gonna' go out for a drive and thats about it. Given the upcoming Christmas season 'hobby' time is going to be on the downslope side so putting in the new grill/etc and the other upgrades will have to wait until January. Keep up the amazing work and projects guys!! All Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
12-04-2011, 01:19 PM | #4324 |
here is the last of frome yesturday sway bar
12-04-2011, 01:22 PM | #4325 |
Agree with 65Custom, that looks great - nice little modification of stock parts.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
