Old 01-23-2026, 11:16 AM   #426
Vic1947
Vic1947's Avatar
Re: 65 Fairlane pro-touring build
Originally Posted by joesscamaro View Post
Hopefully, they can knock your car out and get it back to you soon. The color combo looks great!
Thanks! He's making progress ...here's a few more pics. Car is now completely in epoxy. He likes to give it a couple of weeks to fully cure and then lightly block it and come on with the high build urethane primer.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 01-23-2026, 03:31 PM   #427
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I like the color combo too. It even looks good in epoxy!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-23-2026, 03:48 PM   #428
Vic1947
Vic1947's Avatar
Thanks, Dale!
Victor
Old 01-30-2026, 05:17 PM   #429
Vic1947
Vic1947's Avatar
Doors and trunk lid are in high build primer and ready for final blocking prior to paint. Fenders are partially skim coated and blocked, and the hood is nearly ready for another couple of coats of primer. He ended up reshaping the scoop slightly to enhance the ridge that goes down the center. I think it will look much better that way. He's been working on it pretty steadily. He plans to get on the quarter panels next week which should be a test of his patience. The existing lines are pretty good, but I know they need a lot of work before they're ready for prime time.
Victor
Old 02-01-2026, 02:55 PM   #430
Ol Blue K20
Nice, it might come home soon. Doesn't seem like paint prison...
Dale
Old 02-01-2026, 05:43 PM   #431
Vic1947
Vic1947's Avatar
Thankfully that seems to be the case. Unless he gets swamped by other stuff, he might actually get 'er done. What makes me kind of nervous is that his shop is absolutely full. I don't know if his other customers are in no hurry or what the deal is. I'd hate to see all this great progress come to a screeching halt if someone else steps up and says - hey what the heck is going on? Guess we'll see. When I went in Friday, he said his goal was to start on the quarters the first of this week. That would be great if it happens.
After skim coating and sanding, he plans to bury everything in high build primer and let it cure good. Then final blocking with 320 and it will be ready for sealer, paint and clear. Doesn't sound like all that much when you say it fast, but it's a lot for sure.
Victor
Old 02-09-2026, 06:05 PM   #432
Vic1947
Vic1947's Avatar
What a beautiful day in the neighborhood! 78 degrees which beat the old record by six degrees. Worked a little in the yard since I'm still waiting for Justin to get my instrument bezel in primer. I've been doing some wiring on the engine to lay the groundwork for routing the cables thru the firewall. The Holley harness has about a half dozen plugs that are unused for my application. I was able to hide most of them under the intake. The real issue is the Ti-VCT harness which regulates the timing of the cams. It's a separate harness that plugs into a module separate from the ECU. All these wire bundles have to pass thru the firewall in some way. I have a Haltech bulkhead grommet and an aluminum clamshell piece designed for a Holley harness I can use as a starting point. Once I get the car back, I'll know more.
Trying to keep it as neat as I can, but it's almost impossible to hide everything. I know the high-end shops build all kinds of trick parts to make it look like the car just magically runs without any electronics - but it ain't me, babe.
Victor
Old 02-09-2026, 08:04 PM   #433
KevinK7
KevinK7's Avatar
I haven't been around so it took me a bit to catch up, you sure are making some progress. Car is looking fantastic
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 02-09-2026, 08:11 PM   #434
Vic1947
Vic1947's Avatar
Thanks! Hope to have a lot more to post as the car moves through the paint process and gets back to the barn. Glad you're watching.
Victor
Old 02-13-2026, 01:02 PM   #435
sduckworth13
sduckworth13's Avatar
Looking great Vic! Can’t wait to see the car painted.
Scott
sduckworth13 is offline   Reply With Quote
Old 02-13-2026, 01:29 PM   #436
Vic1947
Vic1947's Avatar
Thanks, Scott. You'll have to swing by and see it in person when I get it home. Right now, Justin had to slow down on it a bit to work on other customer vehicles. He has the front clip, doors and trunk in final primer, but the main portion of the body is in epoxy with just a small amount of skim coat and blocking done here and there. With a two-man shop, there's just no way to get 100% of their time.
Victor
Old 02-13-2026, 04:10 PM   #437
sduckworth13
Sounds good! I’ll be glad to stop by.
Scott
Old 03-25-2026, 02:30 PM   #438
Vic1947
Vic1947's Avatar
Still in a holding pattern at the paint palace. My painter had family business to handle and hasn't been back in the shop until recently. He does have the Fairlane up on a two-post lift to (I assume) work on the rocker panels and lower quarters. I've been trying to keep out of his way because every hour I spend at his place jawboning is an hour no work gets done.
Meanwhile, back at the ranch, I've been doing little odds and ends like painting the steering column and dash bezel. I went ahead and assembled gauges and etc. into the panel so it's pretty much ready to install when the time comes.
I found a nice 50th anniversary Challenger online and bought it to have for trips and cruise ins. It needed a few things, so I've been tinkering with it while I'm waiting for the Fairlane to get back home. I'm also trying to get some drywall guys to come out and scrape off the popcorn ceiling in the shop and replace it with knockdown texture. But dang, those guys don't seem to want to call back. I reckon they don't need to mess with a little job like mine when there are apartments and townhomes going up all around here.
Victor
Old 03-25-2026, 02:57 PM   #439
62c30
Challenger is cool. I've got a 16 rt with the shaker hood. It's crazy how a mass produced car gets so much attention. Although as big as they are it's hard to miss them.
62c30 is offline   Reply With Quote
Old 03-25-2026, 03:48 PM   #440
Vic1947
Vic1947's Avatar
That's funny, we also had a 16 RT with a shaker hood. I always regretted trading it in and when we decided to buy another Challenger recently, I looked high and low for one with a shaker hood. However, nearly everything in my price range was either high mileage or had a rebuilt title. I was about to give up when I ran across this 50rh anniversary model. I didn't even know they made them, but I liked the unique wheels, badging and interior. I decided I could live without the shaker hood and took the plunge ...and then joined the local Mopar club.
Victor
Old 03-25-2026, 03:57 PM   #441
62c30
Other than the wheels and trying to keep a black car clean I like it. Bought new and new has just over 36k on it
Old 03-25-2026, 04:04 PM   #442
Vic1947
Vic1947's Avatar
Sweet!
Victor
Old 03-26-2026, 09:20 AM   #443
3drburb
Very nice build you have here, been checking it out from the start and always look forward to see whats happening.
As for the popcorn ceiling, IF, it's pre 1980s, please, google Popcorn Ceiling Removal Risk.
3drburb is offline   Reply With Quote
Old 03-26-2026, 12:45 PM   #444
Vic1947
Vic1947's Avatar
Great advice, fortunately our home was built in 2008 and shouldn't have that problem, but it's still a messy process to remove and replace the texture. I fooled around and got too old and creaky to do it myself.
Victor
Old 03-27-2026, 11:52 AM   #445
scottofksu
scottofksu's Avatar
Awesome progress and awesome new car!
My wife drives a white 2020 Challenger Scat Pack Widebody with the 392!
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 03-27-2026, 01:26 PM   #446
SCOTI
SCOTI's Avatar
IDK buddy..... Sounds like you timed it well
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-27-2026, 05:13 PM   #447
Vic1947
Vic1947's Avatar
Thanks! I found a widebody 50th down in GA when I was on the hunt. Nice car but unfortunately had a rebuilt title. Insurance can be an issue with rebuilds. My wife loves driving ours but still lays a patch sometimes when taking off. Accidentally acccording to her.
Truer words were never spoken.
Victor
ford, restomod, t56
