70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Carby Floats
I just bought a NAPA carb kit for my 72 with the original Q-Jetand it had the brass float and my friend doing the carb was surprised the float was brass..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: What did you do to your truck today? Chapter II
Snapped a head bolt torqueing heads on 5.3, modified z bar mount to work on saginaw 3 speed with ls engine, this mount must be for a bellhousing that has eqaul length ears, mine did not so i had lengthen the lower bolt hole, mig on stainless isnt pretty but it proved to be strong
Hooked up my cluster temp guage...other ports in the heads where taken up with electric fan thermal switch and mechanical temp guage. Just wanted it to work.
1970 C10 Short Stepper with 71/72 front clip. |
#4 | |
Moderator
![]() Join Date: Jun 2017
Put intake on motor, pulled gas tank dumped old gas out, found half of an old keyed cap inside the tank lol
I have found many a dead mouse and rocks inside old fuel tanks along with rusty bailing wire, coat hangers, tools and God alone knows what all else .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
Would have wondered what that noise was w a low tank.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
I've been in more than a few old work rigs where a handful of 3/8" ball bearings wouldn't be heard rolling 'round in the tank .
#9 | |
RAT1968 '68 Cab/'71 Parts
You just reminded me of replacing my tank behind the seat. I had it reworked and put it back there because I didn't want an under the bed tank for a few (not all so good) reasons. As a solo builder, solo worker, I think it was the worst part of the whole frame up job.....
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
Oh I love my under bed tank, no fuel sloshing when it is under 1/2 and no smell at all, plus kinda funny when I fill mine, the spout is inside an Danger explosives red box, makes a lot of people wonder what's up w the box, works for me and finally a bit more of in cab room for stereo parts that i never use cause I love the big block and 3" exh, makes my heart beat faster and I smile a lot.
Mudman.
![]() Join Date: Jul 2017
I have not got to work on my truck in over 2 weeks but I have bought a lot of stuff. The Home AC went out then my shower started leaking 4k down the drain i would have loved to put it all in my truck
Swapped out the Ignition lock cylinder.
I also installed a new rearview mirror after I had to fixed bad manufacturing on it. Have a few more minor things to install.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
#13 |
![]() Join Date: Jul 2016
Been feeling guilty about not driving it for a couple of weeks. So, we went for a little stroll. I need to do tune up on it bad.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
#14 |
![]() Join Date: Jul 2015
I put a tune on my rig this week. New adjustable vac advance, cleaned and lubed the distributor properly and new lighter weights so I do not have to rely on the mechanical advance!
Boy I must have gained 100 horsepower! All kidding aside been on hotrodders.com and followed up with some of the tech articles those boys put on, Its good stuff! |
#15 |
Old member
I finally installed the 2 under hood light that I got about a year ago after the other one quit working.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#16 |
I would never use any head Bolt more then 1 time no matter what.
#17 |
Moderator
Makes the use of ARP studs a really good proposition then...
Even a street engine can benefit from a good set of studs...hardened washers and nuts, lube torqued to spec... ![]() ![]() ![]() |
#18 |
![]() Join Date: Oct 2013
I just got her running again after the second rebuild in less than a year and am dreading the loud screeching that happens at about 2500RPMs.
After removing valve covers to check rockers then installing and testing again my wife comes into the garage and asks when am I going to fix that dam fan belt.... DOH |
#19 | |
Moderator
#20 |
Did a complete coolant flush over a month ago. Still trying to chase a gremlin??? in my gauge as it reads a bit warm.
Put a infrared thermometer all around the system and this is what I came up with. Thermostat housing 169 Hose Inlet to Radiator 167 Bottom Radiator Driver Side 163 Top Radiator Cap 135 Bottom Out to Water Pump 131 Using 4 core brass/copper, Super Stant 160 Thermostat, Stock Water Pump with cast impeller, Hoses, ect.. Prestone Green with Napa Kool additive. Not bad for a farm guy. Guess I need to pull that teflon tape off the Sending Unit in the head. |
#21 |
Looks good to me!! What was the temp outside? Where was your gauge pointing?
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
#22 | |
The gauge never used to read this way that is why it got me worried. Gen I block with a hot Accel Super Coil HEI and R45ts plugs to burn off any oil blow by. |
#23 | |
#24 |
Yes I do, or that silly Harbor Freight infrared laser thermometer is way out of spec. I should have tested that thing against some boiling water. Someone on here has pointed out that the Teflon tape can interfere with an electrical connection.
#25 |
Old member
I fixed my passenger side mirror. I used S/S tie wire to keep the mirror together so it want break again.
The s/s conduit has rusted a part inside the mirror. So I slide it back together and wired it up so it can't come a part. ![]()
