#26 |
Re: steering wheel pics
I went for something in the 15.5" range. I found this at a local auto parts store for $139:
#27 |
thats the one i have on my 68
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
#28 |
![]() Join Date: Sep 2007
Ok I dug this up from the recent archived posts. I need a little help. When I bought the truck it had what seems like 8" steering wheel on it. It's actually larger than that. But the problem I'm having is that I can't see turn signals or even the Speedometer the wheel on the truck just covers all of that up and you have to move around to see everything. I HATE IT.
So I actually found a good 60-65 custom wheel that I want to put on. However with out knowing what I need to put the other wheel on. I tried to install the other wheel but it looks like I'm missing something that goes on top of the colum. When I put the wheel on I can still see the into the top of the colum, around the base of the wheel. Next problem is that I'm not sure what pieces I need for the horn. Anyone have pics of the top of the colum blown apart so i can see what I'm missing. The truck it's going on is a 1968 chevy and the wheel is a 60-65 custom steering wheel. Thanks any help would be apperciated... Regards... |
#29 |
th
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
#30 |
va_tlc,
Ok i'll be the first one to ask you. Why is it installed upside down? I'm assume it was intentional.. |
#31 |
soba, i musta had the wheel turned some, i hate when your driving a truck with the wheel off center , so i assure ya its right
#32 |
Future TOTM Winner
This is the only pic I could find on my laptop, but this is the wheel I'm currently using. I'm sure most of you recognize it as being from a mid 80s Chevy truck. They are a direct bolt on as far as I can remember.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
