Re: Vinegar for rust removal
Moderator
![]() Join Date: Dec 2012
Here's the thread, check out the pics, they are amazing!
http://www.garagejournal.com/forum/s...t=vinegar+salt |
Thanks Jon ....I put my crusty lower rear shock mounts in it for four days, didn`t touch them, took them out, not to shabby for 50 years of rust...I will neutralize with baking soda before paint...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
If you use the POR 15 stuff, this vinegar solution will take the place of the metal prep they say you have to buy. Alot cheaper too.
Opportunity usually comes disguised....As hard work!!! ![]() |
Heres the 2nd batch of parts I've done. Rear brackets for stepside tail lights. 4 days soak time, 2-3min wire brushing and a baking soda soak for 30 minutes to neutralize the vinegar soak.
One note I will add is that I do not use the salt mixed into the vinegar, but I do not have that black tarry slag to clean up either that you see with the salt/vinegar solution. I just use straight vinegar and then soak in a baking soda/water solution to clean/neutralize the process. Im equally happy with the 2nd batch of parts, and will be doing tailgate chains for the matching trailer project next. Pics to come As you can tell, just a little paint left that will come off easily enough by hand and some 60 grit. Will be getting self-etching primer tonight, then sprayed after my next set of parts are ready.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#6 | |
By the way I had talked with an old restorer, well older than me, anyways he used to use vinegar all the time until somebody had told him about citric acid, now he uses it exclusively, he reason being he can up the strength, he normally uses a pound per gallon, but that gallon is used a long tme before he discards it, and it don1t smell as bad as the vinegar, he buys it in bulk 5 lbs at a time...http://www.wkfinetools.com/trestore/...itricacid1.asp
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip Last edited by Rich 5150 69; 06-15-2013 at 05:27 AM. |
HOW long until spring??
![]() Join Date: Mar 2009
another way to beat rust is the battery charger and wash soda method but this way with the vinegar looks pretty darn easy!!
Here is a link to an old thread on electrolysis and rust removal http://67-72chevytrucks.com/vboard/s...d.php?t=385635
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
hmm, ill check that out. the etching primer is probably overkill, but its what i currently have on hand
rustbelt no, but simply just dipp it in a pool full of vinegar. lol
What do you guys think about putting brake drums in vinegar (or citric acid)? Do you think it would damage the surface that contacts the brake shoe? Any other suggestions for removing rust from brake drums? Thanks
Posted via Mobile Device |
worst case you can always dip then and take them to the machine shop
Brake drums might be better sand blasted, at least you can mask off the shoe area, if they are scored bad enough it wouldn`t matter you would turn the drums anyway.
#13 |
Quick question; I have a little rust on my headlight bezzels on my '65 from the 3 screws that are used to hold them on. From reading this, the vinegar will remove the chrome or damage it. How can I clean the rust off and not damage the chrome?
#14 |
Moderator
The headlight bezels aren't rusted, that is just a stain from the rust from the screws. A little compound will take the stain off without damaging the bezel. I like Meguiar's Ultimate Compound, but there are a hundred things that will work. Nevr-Dull will do it, too.
#15 |
I was actually just about to ask if never full would work, I've used that before on wheels. Thank you Jayoldschool!
#16 |
are the bezels aluminum or steel? mothers has a great aluminum polish also. i have used the never dull also w/good results
#17 |
Moderator
Yes, of course my advice only applies to the aluminum bezels!
#18 |
I used never dull on the aluminum side pieces on my 66. They looked great. Then I wiped them with a wet rag, and they went instantly dull again.
#19 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Did you strip the clear anodizing off of them first?
#20 |
#21 |
60-66 Nut
You need to remove the clear anodizing from aluminum before you can polish it. Oven cleaner works good for that.
#22 |
It helped a little, but didn't get the rust completely off. I dont believe mine are aluminum though.
#23 |
[QUOTE=concretekiller;6126398]It helped a little, but didn't get the rust completely off. I dont believe mine are aluminum though.
Does a magnet stick to them?
#24 |
Moderator
Those look like plated steel to me. Naval Jelly will take that rust off, but the plating is damaged.
#25 |
The headlight bezels are chrome. The turn signal bezels are aluminum though. Working on polishing those now. Also may have found an aluminum grill and bezels on craigslist!
