Old 10-13-2004, 10:14 AM   #26
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Originally Posted by dubie
Are you going to fish plate it for additional strength? I am going to do the same thing to my spare 72 lwb frame.
Yeah, I made the pattern at work yesterday, then traced it onto 1/4" plate last night. But I got so into the teardown of the rest of the frame that I never got them on last night! Either tonight or tomorrow night I will finish grinding the welds and install the fish plates. I think now that the frame is just bare rails, I might lay the frame on it's sides to weld in the plates. I think the welds will look better that way, rather than trying to weld upside-down and stuff
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 10-13-2004, 10:45 AM   #27
ebfabman
Hey Glock, nice looking job! The reason I like to keep the cuts straight is because I use part of the removed section to make diamond shaped plates to lay over the joints, including the 90 degree areas top and bottom.
here
ebfabman is offline   Reply With Quote
Old 10-13-2004, 10:50 AM   #28
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks damn good keep up the good work....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-13-2004, 11:54 AM   #29
glock35ipsc
Thanks!! I can't quite tell from the pics, but it looks like you are plating the verticle cuts as well. Is that what you meant by "including the 90 degree areas top and bottom"? Hadn't thought of that.
You are the one who has inspired me through your posts to attempt this. Thanks to all for your great comments!!
Bob
Old 10-13-2004, 12:02 PM   #30
dubie
dubie's Avatar
Here is an unpainted pic from Ebfabmans website. Hope ya don't mind me borrowing it bud!!
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 10-13-2004, 01:03 PM   #31
Jimbotronics
YA YA
Jimbotronics's Avatar
WOW!!!! Awesome job!! That goes for both of yas!
What could a person expect to pay for a quality job like that?
I'm looking forward to seeing progress photos as you go.
Jimbo
'72 SWB - 350 (frame-off resto in progress - donations accepted)
'04 Chevy Avalanche
'03 Cadillac CTS (wife's ride)
Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707
Jimbotronics is offline   Reply With Quote
Old 10-13-2004, 04:11 PM   #32
smitty62
smitty62's Avatar
Isn't that the LWB truck you wrecked a while back? Great job!!
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 10-13-2004, 04:26 PM   #33
love it loud
Calibration Engineer
love it loud's Avatar
Originally Posted by glock35ipsc
No problem, I used a regular grinding disc to knock down the weld, the used a 60 grit flap disc to dress them. I love those flap discs!
Where can you find these flap discs?
CANADIAN CONNECTION
love it loud is offline   Reply With Quote
Old 10-13-2004, 04:38 PM   #34
dubie
dubie's Avatar
Acklands Grainger for us Canadians Princess Auto also sells them. About $10-$15 each but well worth the money
Old 10-13-2004, 06:11 PM   #35
glock35ipsc
It was! Until now........
Bob
Old 10-14-2004, 12:39 AM   #36
glock35ipsc
I have been buying them lately at Harbor Freight, I think they are about $6 or $7 for a 3-pack. I order them through MSC Industrial for work. Much better and last longer, but at $5 each (USD).
Bob
Old 10-14-2004, 12:41 AM   #37
glock35ipsc
More Pictures!!
MORE PICTURES!!!
I finished the frame tonight! Now I need to degrease it, then it goes to the sandblasters on Monday.
Here is the end result:
Bob
Old 10-14-2004, 01:44 AM   #38
67cst
i love summertime
67cst's Avatar
you mustve flipped that frame on its side! cheater! jk, i was looking at the close up of the fish plate and i was thinking damn thats a nice bead then it appeared in the pic above that its on its side?!?
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 10-14-2004, 02:56 AM   #39
fine69
fine69's Avatar
Can you post some measurements? How much where? Why cut at the place you did? Etc.? I am going to do the same thing shortly. I am skilled enough, and have the equipment to do it. But i always look for a better idea. Thanks
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 10-14-2004, 07:46 AM   #40
glock35ipsc
If that is cheating, then I am guilty!!! I tried to grind the welds on the inside while it was on the jackstands, but that proved to be a PITA! So I grabbed the engine hoist and lifted one side in the air and worked on the lower side, then let it down and did the other side. It did make for much nicer welds.
Bob
Old 10-14-2004, 07:49 AM   #41
glock35ipsc
I will get some measurements from reference points for you tonight and post them here. Basically, you remove 12" from the middle, just ahead of the rear cab mount, and take 8" off the very end of the frame. I chose the exact location I did for one reason: the serial number is stamped on the top of the upper rail right where I removed the 12", and some other numbers are stamped ahead of them on the side. I placed the step in a way that would leave both sets of numbers. It's a no-no to deface the serial numbers, so I wanted to leave them alone.
Bob
Old 10-14-2004, 10:02 AM   #42
glock35ipsc
As requested:
Bob
Old 10-14-2004, 10:27 AM   #43
corn
Ive been getting my flap discs from wally world. They were @ $5 if I remember right. Great job on the frame...corn
corn is offline   Reply With Quote
