#26 |
Resident Curmudgeon
![]() Join Date: Dec 1999
18 inch drop, laying rockers
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#27 |
Flake Daddy
air suspension
15x8" 275/60's all the way around... ![]()
1968 SWB Fleet Daily Driver 350/TH400 shaved driprail,emblems,tailgate,air ride suspension 1964 Pontiac Catalina 2dr. hardtop shaved everything, air ride suspension 1998 Range Rover 1960 El Camino....in the works..... |
#28 |
-Praise the Lowered-
Front: 3" springs, 15x8 w/ 4.5 bs, 225/70/15
Rear: 5" springs, 15x10 w/ 4.5 bs, 275/60/15 springs from "Classic Performance Products" (CCP)
Race-N-Jason ('71 Chevy C-10 LWB 454/TH350) ('07 Dodge Ram 2500, 5.9 Cummins/6-speed Manual) Last edited by race-n-jason; 10-27-2004 at 04:49 PM. |
#29 |
Has anyone done a static drop and running 20's or bigger? I only see 20's on bagged trucks. Im looking to change my supension but i dont want to drop my truck to the ground, i just want the tires to meet the fenders. I think i can achive this with dropped spindals and springs and a nice set of 20's but i'd like to see pics of someones truck who has done this. I think the biggest rims ive seen so far are 17's ..... Is there a reason for this?
#30 |
I think it's just because our "group" as a whole just thinks they look bad. Of the few that do have big rims, I've seen maybe 2 that look "right"
Brian 72 C10 longbed 350/th400 Let the world change you and you will change the world. |
#31 |
senior member
heres mine i cut 2 coils from the front and made 2 inch lowering blocks for the rear hopefully i get my 275/60/15's this year
69 GMC bagged |
#32 | |
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done... |
#33 |
here's Butter's Ride it has spindles and springs up front and springs out back butI'm not sure of how much drop! The tires and rims are TT II 17x8 with 255/45/17 on the rear 18x10 4.5 bs 295/45/18 nitto's
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#34 | |
#35 | |
senior member
69 GMC bagged |
#36 |
Yes, but I do love the orange. Mmmmmm. Now if it just had black and orange ghost pinstripes and wasn't ghetto'd out.
#37 |
Struggling Artist
4.5-6" drop 20x9.5 " wheels w/275/35/20
69 1/2 ton lwb lowrider 90 C-1500 2wd 08 2500 HD 4WD 94 Grand Cherokee 49 Cadillac sedan ![]() |
#38 |
Before and After
3.5 front 2.5 spindles by Chassis Tech and 1" lowered springs
5" rear with Chassis Tech springs Cragar SS 15X8 front Cragar SS 15X10 4" BS with 295 50s on the rear. See Avatar
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
#39 | |
#40 |
bad69, i think that looks really good but i just have one question ..... why are the rear rims tucked back inside the wheel well so much further than the front rims?
That was a concern i had about lowering my truck too much. I wanted to do a similar static drop by using the 2.5 lowered spindals and 2" and 6" drop springs but i didnt want to have my wheels not sit flush with the bedside and exterior. Is it just the type of rims or is it because of the way its dropped? I really like the boyd 20's ive seen on alot of the trucks but they were all bagged .... does that make a difference in the way the rim aligns with the distance relative to the wheel well or is it just a charicteristic of certain rims and their spacing? |
#41 |
Struggling Artist
the wheels are originally designed to fit a late model gmc,they have a more negative offset, I plan on having american racing build me a 20x12" wheel to fill out the wheel well better(I have 6 lug axles) a different wheel with a different offset would probably fit alot better.
#42 |
Here is mine as the process of lowering/restoring is happening. 2.5" ECE lowered spindals with 2" drop Ground Force Springs for the front and 4" ECE lowered coils in the back:
Alex 1971 Lil' Red 350 SBC 700R4 |
#43 |
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
#44 |
CPP 2.5" drop spindles and ECE stock coils in front. Rear is ECE 4" drop coils with adj. panhard bar and shock relocators. I'm thinking of going to 5" in the rear though, help the wheel gaps even out. Wheels are 17x8 Weld Techstar 5 tires are 255-50-17 Kuhmo ECSTA STX
1968 C10 - 383, non-stop project 1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies Last edited by rin68; 11-09-2004 at 11:43 AM. |
#45 |
Red Headed Step Child
Here's my 72 Jimmy with an Early Classic 4/6. I've got plans for 20's on it also
"Dinner, the perfect break between work and drunk" -Homer Simpson |
#46 |
Excelsior, You Fathead.
If I were to drop the front and rear two inches with springs, do I need to change anything else.
Go Navy. The Sea Is Ours. Budget 350 Build http://67-72chevytrucks.com/vboard/s...38#post2264638 |
#47 |
Got Light Emitting Diode?
possibly shocks
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
#48 |
Wow, that orange truck is WAYYYY too clean for my tastes. Look at that engine compartment. gah. Someone throw some dirt in there or something. Great deal for 10 grand though.
#49 |
Resident Young Old Dude !
4"- 6" Drop spindles and springs in the front and a Flip Kit rear..
#50 | |
Keep On Truckin'
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
