Old 10-25-2004, 05:59 PM   #1
Dual quad
Smell that burnin' rubber
Dual quad's Avatar
Please post a pic of your lowered truck
I'm going to lower my SWB, but I am undecided on the amount of drop and
wheel size. Please help me decide by posting a pic of your lowered truck
along with the following info...
Amount of Front drop
Amount of Rear drop
Manufacturer and type of drop (spindles, coils, bags, blocks, etc)
Wheel diameter, width, & offset (front/rear)
Tire size (front/rear)
Thanks in advance
Dual quad is offline   Reply With Quote
Old 10-25-2004, 06:02 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
5/7 REMOVED SNUBBERS AND USED A TORCH TO HEAT THE SPRINGS
FT. 195 / 50 / 15 AND REAR IS A 225 / 60 / 15 ? ( HAD 295 / 50 / 15'S ON REAR )
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-25-2004, 06:11 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
4.5 drop front using ECE spindles and Summit brand 73-87 truck 2 inch drop springs.
6 inch rear drop using complete ECE 6 inch kit with track bar and relocators.
15x8 inch wheels all around with 4.25 backspace
245/60/15 tires front
275/60/15 tires rear
Old 10-25-2004, 06:42 PM   #4
greasemonkey
greasemonkey's Avatar
2 1/2" front, 3" rear.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 10-25-2004, 06:49 PM   #5
1972C10
1972C10's Avatar
3/5 Drop All spings. HOpe to get some spindles and do it right way.
1972C10 is offline   Reply With Quote
Old 10-25-2004, 07:20 PM   #6
tnblazerk5
User #12137
tnblazerk5's Avatar
heres mine (sorry bout the pic ) front p225-70r15 28 1/2 in at the fender well
rear p275-50r15 and 27 1/2 at the fender well the rear need to come down on mine about a inch or 2
front spring cut and the bumps cut off and energy supension bumps put on and 4 1/2 inch blocks on the rear
tnblazerk5 is offline   Reply With Quote
Old 10-25-2004, 07:48 PM   #7
Randy70C-10
Randy70C-10's Avatar
Here's my wifes truck, 3 inch drop in the front and 4 in the back.
Randy70C-10 is offline   Reply With Quote
Old 10-25-2004, 08:58 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
ECE's 4.5/6 drop
ECE's 2.5 " spindle/2" spring, and 6" rear spring. ECE's adjustable track bar and rear shocks. In this pic,...7 and 8 inch ralleys with 215/70-15's and 275/60-15's.
Keith
Convert to disc brakes.
Old 10-25-2004, 09:23 PM   #9
SCOTI
SCOTI's Avatar
6" front drop: spindles, 1 coil cut (6cyl springs), poly sway-bar bushings, disc conversion, 6.5" van ralleys w/215-70's
6+ rear drop: bags, 1.5" lowering blocks, adj. panhard bar, relocated stock shock mounts, 8" ralleys w/255-70's
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-25-2004, 09:29 PM   #10
72 Super
72 Super's Avatar
Here is my 72.It has 5 inch drop springs in the rear and at the time of this picture the front was roughly 4 with heated springs.It now has ECE drop spindles with 1 inch springs,but wish I would of went with the 2 inch.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 10-25-2004, 09:32 PM   #11
haulna
haulna's Avatar
3.5/5.5
Early classic front spindles, and coils up front.
Early Classic leafs and shackles in back.
15inch wheel tire setup.
72 Chevy SWB
haulna is offline   Reply With Quote
Old 10-25-2004, 09:47 PM   #12
Peregrine
Peregrine's Avatar
4 in drop all around done the wrong way with corvette wheels, I'll get more info later. And I really like the truck 72 Super, us long beds gotta stick together :P
Brian
72 C10 longbed 350/th400
Let the world change you and you will change the world.
Peregrine is offline   Reply With Quote
Old 10-25-2004, 09:52 PM   #13
jhwkns
Registered Cruiser
jhwkns's Avatar
2"F/4"R I used ECE springs.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 10-26-2004, 07:18 PM   #14
72 Super
72 Super's Avatar
Peregine,thanks for the complment.I like yours to and it looks like you got sweet truck yourself.Yes I am a longbed man myself but have had a few shortbeds too.
Ray
Old 10-26-2004, 08:09 PM   #15
1968GMC
love my truck
1968GMC's Avatar
front 255/60/15 with 4.5 drop
rear 275/60/15 with 3 inch drop BUT i got stuff in the box for this pic and it went down anoter 3 inch so it looks like a 5-6 inch drop
1968GMC is offline   Reply With Quote
Old 10-26-2004, 08:44 PM   #16
theo70
COMING SOON...
theo70's Avatar
Cut coils & 2.5" CPP spindles up front, dearched leafs on the way...
theo70 is offline   Reply With Quote
Old 10-26-2004, 09:07 PM   #17
gashog
Active Member
gashog's Avatar
Wow, there's some nice trucks on this thread.
my 69 has 2.5" McGaughys spindles up front and 3" drop springs and 1.5" lowering blocks with an adjustable track bar out back. 15X8 with 255 60's and 15X10 275 60's wheels and tires.
69 Custom/10 454 Turbo 400 and 70 Custom/20 350 Turbo 350, 73 cheyanne C/10 also 69 camaro Z/28 and 85 Iroc Z
gashog is offline   Reply With Quote
Old 10-26-2004, 09:41 PM   #18
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
When she was still a LWB: 2.5" ECE spindles up front, 3" ECE springs and 1.5" lowering blocks in the rear. Front 15X7 and 255/60-15, rear 15x8 and 275/60-15.
When she wakes up from surgery as a SWB, I will probably drop the front another 1.5" with ECE coils, and replace the rear springs with 5" ECE coils, and lowering blocks as needed to suit my taste.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 10-26-2004, 10:19 PM   #19
HeavyD
HeavyD's Avatar
JHWKNS your truck is the exact look that I want..did you just use springs, or lowering spindles as well? What were all the parts you needed to order? Does it ride OK? Any problems with alignment or bottoming out? We have pretty bad roads up here...lots of huge holes!!
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 10-26-2004, 11:41 PM   #20
jhwkns
Registered Cruiser
jhwkns's Avatar
HeavyD... Springs only up front. Springs, an adjustable panhard, and shock relocaters on the rear. Koni shocks (that are getting a little tired after 7 years). The tires on the truck are 275/60's on 8" mags. I did the alignment myself. I'm satisfied with the ride, and there is no abnormal tire wear. I don't think anything more than a 2" front spring drop is practical, but 5" is no big deal in the rear. Get some good shocks they're worth the extra bucks. If you don't have a swaybar. They are cheap at the boneyard, and easy to install. J
Old 10-27-2004, 04:13 AM   #21
HeavyD
HeavyD's Avatar
Thanks J..man this post has a lot of nice looking trucks!
Old 10-27-2004, 05:52 AM   #22
mcmlxix
Collector of Projects
mcmlxix's Avatar
4/6 drop from ECE
275/55/17 on 8.5" Impala SS wheels
Rich
1972 K5 Blazer CST Click HERE
Old 10-27-2004, 06:27 AM   #23
special70gmc
special70gmc's Avatar
4.5/ 6 using springs droped spindals and an axel flip out back
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 10-27-2004, 08:14 AM   #24
kxmotox247
kxmotox247's Avatar
Air Ride Suspension
18 x 8's and 20 x 10's
3" Dropped spindles Front
C" Notch'd Rear
kxmotox247 is offline   Reply With Quote
Old 10-27-2004, 12:15 PM   #25
Dual quad
Dual quad's Avatar
Thanks guys, some beautiful trucks here for sure. I was thinking ECE 4/6 beforehand, and am now pretty much decided that's the way I'll go. Now I've just got to figure out what size AR Torque Trust II's (15, 16, 17, 18) to go with.
