Old 02-10-2005, 01:33 PM   #26
TheFabShop
These brackets are so easy to make.I get all my brackets laser cut and have just been getting a couple done at a time guess I could do more.I have been running these compressors for about 3 or 4 years now with great results.Once you have a line drive you will NEVER go back to an electric compressor.There is just a little maintenance that needs to be maintained to keep them up.I run them on 3 to 4 7gal tanks regularly at 200 psi no problem.
TheFabShop is offline   Reply With Quote
Old 02-10-2005, 04:10 PM   #27
69burban
Garage Built Rides
69burban's Avatar
AWESOME!! can you sell me one? I would love to see some pics of one installed on a smallblock. I'll probably PM you also.
Albuquerque, New Mexico
65 long bed,
shaved drip rails, tail lights, tailgate, and molding. 350/700r4, dropped springs
69burban is offline   Reply With Quote
Old 02-10-2005, 05:54 PM   #28
luckydog
< Fav Place on Earth!
luckydog's Avatar
I'd like to see some pics too...
Horsepower is how FAST you hit the wall, torque is how HARD
luckydog is offline   Reply With Quote
Old 02-11-2005, 01:57 AM   #29
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Ive heard that these put more of a strain on your motor therefore decreased horsepower. I dont really see any difference than if you had a/c but I just thought I would throw that out there.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 02-11-2005, 02:11 AM   #30
fastbagged68
fastbagged68's Avatar
Only takes HP when its on. It might rob a few HP when it is off but it is worth it. If you are worried bout less HP go out and get some better heads or 1.6 roller rockers etc. And when was the last time you saw one of these trucks racing often and laid out on air. You don't see that too often.
fastbagged68 is offline   Reply With Quote
Old 02-11-2005, 02:32 AM   #31
el curioso
el curioso's Avatar
heres some
http://www.geocities.com/spencerhut/truck/air.htm <--Chevy engine
http://www.pavementsucks.com/tech/yorkcomp.php <--dodge engine but will also work with a 350 due to the mountingf of some alternators.
look for on board air tech aricles and you get many web pages dont be scared to look at ones for jeep, land rovers fords, etc... its not that chevy engines dont have them its just that its use on ALL type of off road vehicles. Dont hate appreciate!
el curioso is offline   Reply With Quote
Old 02-11-2005, 02:42 AM   #32
bagged69c10
Im not worried about it at all, if it makes my truck hit the tarmac harder or get some air quicker then im all for it. I just know that some people spend alot of money just for a few horses but I am not one of them. Im gettin kind of interested in this now. Is there anyone in the DFW area that could possibly help with the install.
1965 c-10 long bed
1993 Sierra x-cab
Old 03-24-2005, 07:09 PM   #33
LuckyFastEddie
Install question
I have a 47 chevy PU 350/400 and a S10 2 pc drive shaft.The front drive shaft doesnt move up or down as it is secured at both ends. Could I put a pulley around the drive shaft and run a belt to the compressor which would be mounted to the side of the frame. Just dont have room at front of engine. It would be out of site and high enough for ground clearance even with bags aired out . From what I'm reading here a belt driven air compressor seems to be the way to go. Any feed back pro or con will be appreciated. Thanks
LuckyFastEddie is offline   Reply With Quote
Old 03-25-2005, 12:08 PM   #34
Slammed67
Progress = 0%
Slammed67's Avatar
What happens when you have the truck lowered all the way and by some chance all the air leaks out of your tank(s)?? Not a practical idea.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 03-28-2005, 06:12 PM   #35
XXL
Seņor Member
XXL's Avatar
You might have problems with your transmission seal going out with all that side force. Or... I suppose you could balance out the load with a compressor on each side. But that sounds like a lot of trouble.
XXL is offline   Reply With Quote
Old 03-28-2005, 09:23 PM   #36
jamis
F.A.S.T. president
jamis's Avatar
Have you guys ever tried running a bendix or meritor compressor made for producing air pressure? I wouldnt think the york would work out very well because in an AC system the compresser is designed to pass oil thru a closed sytem. It has to have a constant flow of oil to keep lubricated. I know they are already being used, I just dont get how they can be efficiant.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 03-29-2005, 08:40 PM   #37
Slammed67
Progress = 0%
Slammed67's Avatar
Actually, they don't which is why they are so widely used. The Yorks have an internal oiling system. The crank splashes oil on all internal moving parts. Some oil will be passed on through the output side, but not much. As long as you maintain the oil level and use a water/oil separator, they work just fine.
Old 03-29-2005, 11:00 PM   #38
BeerMonkeY
sold
BeerMonkeY's Avatar
theres a pic of mine on my cardomain page http://www.cardomain.com/memberpage/429771
for some reason i cant post it on here though
BeerMonkeY is offline   Reply With Quote
Old 03-30-2005, 08:57 AM   #39
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Here's mine mounted on the LT1.
FuelCellGuy is offline   Reply With Quote
Old 03-30-2005, 02:48 PM   #40
jamis
F.A.S.T. president
jamis's Avatar
Thanks Slammed, I didnt know that
I will have to take a look in the bone yard to see if I spot any.
Old 03-31-2005, 04:13 AM   #41
el curioso
el curioso's Avatar
The fix
"YORK OIL FIX" This ought to fix most oil problems on a york. it did for mine. my $.02
