Engine Driven Compressors for Air Suspension
I've been reading around the internet about guys who use A/C compressors instead of electric compressors for the air supply on air suspensions. I've seen kits for sale as well, but they seem expensive. How many of you air riders out there use A/C compressors? Did you use a kit or did you piece together your own system? Had any trouble with oil getting in the system?
Any answers would help. I've been around here a little while and I've never seen this topic come up. Alright boys......................let's hear it! E |
I have done a few newer trucks with the engine driven compressors and like them a lot, run a filter about 18" from the compressor and oil in the lines isn't a problem.
Kinda funny that off roaders have been using York compressors for many,many years for on-board air set-ups, but now it seems to be some newly found setup ![]() |
you will need a filter, dryer, 25 feet of air line i use the one from home depo its worked fine. you will need a ford or volvo compressor, the brackets from one that has a big flat side with holes on it this makes it easyer to aling and weld in. youll need a pressure switch and a check valve you can get it from grainger .you will also need to get a intake filter i used a breather filter the ones that look like the ones that ricers use.(no offense intended to any one with ricers just dont have any other way yo call them)and if you going to be using your serpentine set up a serpentine clutch. put it all together and wala there you have it. need some tec and guidence please look at this web page www.madxj.com under the on board air section. if your going to be using a normal air commpresor you will also require an oiler on the intake side of the commpresor. hope this helps.
just my .02 cents |
Go to onboardair.com I am running one on my burban once it is complete. Its the only way to go!
Mike
Is there room when You are running a/c?
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
Mike
Thanks el curioso.I just read the link You provided.
Trucker.
I had mine mounted on the alternator side of the engine on my 83. It was a DIY kit from AirLift which is made of parts from Onboardair.com
Head Peon
![]() Join Date: Dec 1999
Check out this link it explains how to mod a York so it doesn't discharge so much oil...here's another link that has helpful york info. Some people have problems with them because they don't take care of them properly...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 Last edited by Shev; 01-27-2005 at 11:46 AM. |
Got L.E.D.s
What would oil in the lines hurt? My question is the weight of these compressors on the motor, and how the brackets hold up if your slamming down hard. Most of the compressors I've seen are really heavy.
Bagged 1972 2wd Blazer http://www.earlyclassic.com/home.aspx |
Trucker.
It could make your valves stick.
The York 209 weighs about 10 lbs and I didn't notice a difference after I mounted mine. |
Got L.E.D.s
Maybe if it was really cold. But it would be better than water with no oil.
10 pounds is that it?
JUNK COLLECTOR!!!!!
if you guys are talking about the york compressors i think you are, check out www.coloradok5.com , they have a complete tech article on installations of york compressors, tells you exactly what you need to mount it, and what york pump to look for, for the good one! i think they got the complete installation done for something like $150, including the air tank and all the lines!!!
![]() ![]() The dark side! 2000 XLT PSD F-250 4x4! Offroad package 1970 C10 Short-step soon to be short fleet, maybe? Corvette in truck's clothing in work! Corvette IFS, IRS, TPI and Doug Nash 4+3 |
#13 |
Progress = 0%
I'm running a York on my truck and like it much better than the two electric compressors I was running. I just picked up another York at the junkyard this weekend for $29 (for a spare or future project).
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
#14 |
Slammed67, do you or have you ever had problems with getting oil in your system? What are you using to keep it out? Got any pics? Thanks E
#15 |
Progress = 0%
The compressor hasn't seen a whole lot of use yet, so I can't say for sure how much oil passes through the compressor with regualr use. However, I have an oil/water seperator after my tanks/before the valves.
#16 |
Got L.E.D.s
I was always conserned about rpm. And if they can handle 6,000 rpm. I know most engine driven comp. where designed for diesels running much lower rpm. I have a belt driven compressor I pulled off a 2 ton truck and it was so heavy it discuraged me from even tring it.
#17 |
Head Peon
Yorks were used as air conditioning compressors on Fords and other vehicles so "normal" rpm ranges shouldn't be a problem. For a high rev application you might want to use some kind of rpm activated switch to kill power to the clutch when it gets over lets say 4000...better safe then sorry...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
#18 |
Mike
As long as You have an airtight system,at speed the comp shouldn't be running.Once Your tanks are filled,the pressure switch will shut the compressor off.
#19 |
#20 |
Garage Built Rides
![]() Join Date: Dec 2004
Does any body have a source for york mounting brackets on older small blocks like ours?? Thats been the only road block for me so far.
Albuquerque, New Mexico 65 long bed, shaved drip rails, tail lights, tailgate, and molding. 350/700r4, dropped springs |
#21 | |
Seņor Member
#22 |
Head Peon
I don't know of any company that has a york bracket for older small blocks....smashingchuck was supposed to send me an outline of his so I could draw it up so Jason could laser cut them. I'll get back on that project...how many people would be interested in a set if we can get them made?
#23 |
I would...
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#24 |
why not just get the mesurements from here-->>http://ccicompressor.com/docs/CCIsrvice.pdf and make your own instead of having to PAY some one to make them. you will need little or no travel any way why mot make them your self. i made my own when i added oba to my jeep and every thing works fine up to today. try the web page that i had recently stated it really helps explain the process of a good braket. but if you have the dough go get them made. i would save that money and buy a cold one instead.
My$0.02 p.s heres the link for that web page http://www.madxj.com/ its a walk in the park. ![]() |
#25 |
Garage Built Rides
I would Shev. It's a time thing for me. by the time I built one, I'm sure I would be happy to dish out 35.00 or so bucks. But if I can't find one I guess I'll have to build one......and then have a cold one!!
