#26 |
I'm not going to pretend that they are all easy, but it shouldn't be that hard.
The biggest thing I see wrong here was way too big of a hammer. The idea is to be able to hit it with some speed (repitition) which you can't do with a 3 foot sledge. You need to repeatedly beat it, hitting about the same spot every time. You will hear the sound change....that is at least one cone loosening. Next take a screwdriver and tap it into the slot of the cone, this will expand it slightly. You can then either slide it up or unscrew it like a nut. You may have to modify a screwdriver to fit the slot w/o hitting the stud by grinding on the point a bit. Heat is not necessarily a help here either. As everything heats it expands....making it all tighter. This is such a solid mass of metal that it would be nearly impossible to heat the arm and expect it to not transfer to everything else..........as evidenced by killing the ball-joint. Steady repetitive shock..........not a huge blow |
#27 |
![]() Join Date: Jun 2003
Ok,
I'm the next member who has to do this job. ![]() ![]() Where should I start looking for one of those and how much of a drop for a 4" lift?? Thanks, 72longbed |
#28 |
please don't break
....haha....i just did this today, my truck was lifted 4 inches and never had the steering arm done. i had to rebuild the steering box so i went ahead and did the arm too. took me probly 3+ hrs (1 yesterday with aerokrol and 2 today with a 12lb sledge), its off now. i realy hope i can feel a differnce. it was temping to go to Xover while i was at it. good luck
#29 |
500HP/SB,
Is it really necessary to go with the steering arm with a 4" lift?? Do you have less of a turning radius?? Are there other problems that you had noticed without the new arm?? I just bought the 4" lift kit and didn't get the arm. I'm wondering if I can just go without it? Is a 'dropped drag link' an easier option? Thanks, 72longbed |
#30 |
OBS guy
72 Longbed
Go to www.fourwheelparts.com You can get a drop drag link from- Genuine Suspension (124.99) http://www.fourwheelparts.com/4wp/pr...WP&expand=sub6 Explorer ProComp (131.99) http://www.fourwheelparts.com/4wp/pr...RO&expand=sub7
88 Suburban Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear, Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more |
#31 |
OBS guy
For 4", you might be ok... Maybe just try it as is for starters. If the steering doesn't feel right, you should then try correction. Every truck is different.
However, 4" is the fine line, anything above 4" definitely requires correction.
#32 |
please don't break
72 longbed, i bought the truck with the lift so i dont know how it felt before. i have ben driving it for a year this way and the steering is a litle sloppy so i'm just changing it while i'm doing the steering box (i had the arm kicking around). doing the drag link would definatly be easier to install. good luck
#33 | |
user # 2756
![]() Join Date: Jun 2001
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
#34 |
![]() Join Date: Dec 1999
I would not recommend the drop drag link. It does nothing to correct steering geometry, just addresses the ball-joint angles on the link. Something about having a pre-bent link in a high stress area does not give me any confidence in the product as well. Seen those S-shaped drag links on crossover setups fold a few times. IMO the 2" drop pitman arm would be a better choice if not wanting to mess with the steering arm.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
