Old 02-11-2005, 11:46 AM   #1
redz 1970 K5
OBS guy
redz 1970 K5's Avatar
Question Ok guys, Dagburn steering arm removal...
I have only done this once before on my 82, and it was a PAIN- I think it took me about 6 hours just to get the arm off. I have a Chilton manual and factory service manual for the 71, and they give NO help to remove the factory steering arm (part that attaches to the driver side knuckle)
Anyone who has lifted their truck know what I am talking about.
It's those dang conical locking nuts... I would sure like to hear how you guys coerced your steering arms off. I can't get any type of puller down there either.
It will be soaking in liquid wrench all day, any help would be appreciated.
Thanks!
88 Suburban
Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear,
Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more
redz 1970 K5 is offline   Reply With Quote
Old 02-11-2005, 12:05 PM   #2
cochino12
It followed me home?
cochino12's Avatar
BFH. There are some numbers stamped on the arm on the opposite side of where the studs/washers are, pound on those numbers and it will start to loosen up right away. You might try loosening the bolts 1/2 way and driving around the block too. Good luck
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-11-2005, 01:15 PM   #3
88Jimmy4x4
88Jimmy4x4's Avatar
If its a true CA truck it shouldnt be too bad. Spray some lubricant and let soak then like cochino stated, beat down on it, not up...this should free up the conical washers.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 02-11-2005, 01:47 PM   #4
1969K10
1969K10's Avatar
I have similar conical washers/nuts on my closed knuckle, and i had a friend beating the side with a hammer, while I wiggled it up and down (with the help of a pry bar & 2 screw drivers). Didn't ever put a lot of force on anything, but kept constant pressure pushing up while he hammered...
Good luck
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 02-11-2005, 01:48 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
budweis posted some good pics of where to strike. I had to heat mine up w/ a propane torch and use a BFH to get mine off.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-11-2005, 02:02 PM   #6
redz 1970 K5
OBS guy
Any ideas on where to get new conical washers? I am striking out on sourcing some new ones.
Thanks for the good pointers.
88 Suburban
Old 02-11-2005, 08:34 PM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
www.shakerbuilt.com sells them. Your new steering arm should have come with them. But then again it could have used.
Old 02-12-2005, 10:37 AM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
The one I pulled from my 70 K5 came right off, the one I pulled of the 78 K20 that is going in the K5 was really stuck. Heat didn't help and penetrant didn't help either. I ended up having to get a large sledge hammer as the BFH wasn't enough. Bent the heck out of the studs and they are rather expensive.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-12-2005, 10:39 AM   #9
redz 1970 K5
OBS guy
d'oh! Don't want to do that... Probably cheaper just to find a used spindle then replace those studs,eh?
88 Suburban
Old 02-14-2005, 01:09 PM   #10
goldwing2000
goldwing2000's Avatar
Just did mine last weekend. 25-year-old Michigan truck. Took about an hour with an oxy/acetylene torch and a sledge.
Once you get the washers broken free, you can wiggle them around with a pair of vise-grips and pull them out.
Learn from my mistakes: leave the nuts at the top of the studs. If you miss the arm with the BFH and whack the studs, it will protect the threads.
~Kane
USMC
NRA
GWRRA
AMA
Remember:
Except for Slavery, Fascism, Nazism, Totalitarianism and Theocracies,
WAR HAS NEVER SOLVED ANYTHING!
goldwing2000 is offline   Reply With Quote
Old 02-15-2005, 12:40 PM   #11
poff
I just soaked it with Aero-Kroil and beat it with a big ball peen. I had to beat on it for a good 10 Minutes. I think a sledge is to big. A good 48 oz ball peen is large enough to break it loose but not bend the studs. If you have replacement cone washers you can try turning them with a punch or cold chisel, there is a slot in them if you can catch the edge sometimes they will come out.
'70 K-20 San Diego, CA
poff is offline   Reply With Quote
Old 02-15-2005, 01:27 PM   #12
redz 1970 K5
OBS guy
Hey, local labor, now that's what I am talking about! Say, what are you doing this weekend?
I just go out for about 5 minutes a day, wail on the arm with a sledge, spray with more liquid wrench and walk away. Good thing I am not in a rush, eh? I am not built to handle the frustration of constantly attacking a non moving object; I have to pace myself just so I can enjoy the work and not resent it.
88 Suburban
Old 02-17-2005, 12:26 PM   #13
redz 1970 K5
OBS guy
Still don't have the arm off... About 15 minutes a day trying. Heat, hammering to hell and nothing... 2 more options- Gonna get a BIG sledge tonight and go for it once more; if not, I figure it's time to do ball joints (was hoping to wait, but since they are 34 years old, what the heck?), so I will just pop the spindles off and wrangle it off from the shop vice.
88 Suburban
Old 02-17-2005, 01:40 PM   #14
alf4444
alf4444's Avatar
heat, smack, wiggle the conical washers out (spin them around the stud with a screwdriver and hammer) whack again. Be patient, and good luck with it in a vise it will only make it harder.
Next person to install a lift should do a write up on this and have a mod "stickie" it.
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 02-17-2005, 02:05 PM   #15
redz 1970 K5
OBS guy
Boy I wish I could get those conical washers to move...
I know it will come off, and there will be celebration. This is starting to hold my whole project up.
88 Suburban
Old 02-17-2005, 07:08 PM   #16
crispy
'71 Chevy Blazer
sounds like you've gotten plenty of good advice but i'll put in my 2 cents about my experience with these. i wedged a 6' prybar under mine and gave steady pressure up while my cousin banged on the top of the arm with a big hammer. we had it off in about 10 minutes... good luck.
'71 K5 Blazer (new project / daily driver)
"If you are not working to improve the situation, you have no business complaining"
crispy is offline   Reply With Quote
Old 02-17-2005, 08:10 PM   #17
redz 1970 K5
OBS guy
Guys, funny story-
So, I am really beating those conical washers up pretty good. So, I thought I should go ahead and order more. Went to the local Chevy Stealer- Took forever to research, finally got a part #, and not a single one in San Diego. Stealer wanted $15.55 a WASHER!
Found a small operation in Auburn, CA that sold me the genuine GM parts for $3/piece!!! So, including shipping I am getting all three for the cost of one from the dealer, and he has them in stock.
He doesn't have a whole lot of inventory, but he has what counts!
http://www.partsmikeparts.com/index.htm
88 Suburban
Old 02-17-2005, 09:32 PM   #18
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
parts mike is the way to go!
Old 02-18-2005, 02:09 PM   #19
redz 1970 K5
OBS guy
Ok, I'm done now... Not for the better though. Now, my neighbor and I are both gearheads and have spent countless hours in the garage. After a marathon attempt last night, we still came up short-
I am talking 15lb 3' sledge, 2 built 250lb dudes, MAPP torch, air chisel, 4' prybar, cutting discs, etc. 2 hours- thing did not BUDGE. Thing was smoldering it was so hot. Totally f'd up the upper ball joint due to the heat, no biggie- gotta replace anyways.
Gonna pull the hub assy off, get the backing plate off and literally cut 1/2 of the steering arm off. Gonna have to do new studs, but ah well, I am done playing here. What other choice do I have? Guess I could rent an oxy/acetylene torch too...
88 Suburban
Old 03-03-2005, 08:08 PM   #20
redz 1970 K5
OBS guy
Update--- pretty funny... or sad
Took off the entire knuckle with the steering arm still attached to a good machine shop. Said they could NOT get the arm off- they had to cut the arm off, and are going to have to replace the studs.
So it wasn't just me at least!
88 Suburban
Old 03-03-2005, 08:50 PM   #21
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
That sucks, go to partsmike to get some new studs if the shop does not have them. Don't use bolts! I thought mine was bad, heating it up with a propane torch and hitting it with a hammer did it after about 30 minutes.
Old 03-03-2005, 08:58 PM   #22
redz 1970 K5
OBS guy
Already have partsmikeparts studs, conical washers and locknuts! Thanks!
Mike was a nice guy to work with!
88 Suburban
Old 03-03-2005, 11:28 PM   #23
see ten
WTB this ad
see ten's Avatar
Conical washer removal
When I put the lift kit on my K10 I was also amazed by the stubborness of the conical washer. I paid a mechanic $10 to change my arm and he did it in less than 10 min. He took a deep socket that was larger than the diameter of the washer and put it on top of the arm. It took just one or two hits with a BFH for the washer to just pop up out of the arm. I guess this is kind of like using two hammers to remove a steering wheel. Place one on the loosened nut in the center and strike it with the other. The "shock" makes the part come loose. I haven't had a need to try this again but somebody please give it a shot and let us know if it works for you.
see ten is offline   Reply With Quote
Old 03-03-2005, 11:51 PM   #24
orangeuavol
GO VOLS!
orangeuavol's Avatar
Tried it all.....ended up cutting the d@mn thing off. After 6 hours I was fairly ticked off at it Had a new one anyway but still hated to destroy a perfectly good part. One of the boardmembers in CA sent me a couple conical washers free of charge. Great people on here!
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 03-04-2005, 08:02 PM   #25
redz 1970 K5
OBS guy
Moral of the story... If anyone is considering installing a steering arm, JUST DO A DROP DRAG LINK! A drop drag link runs for about $150 shipped.
In the end, I had to pay a machine shop $90 to remove the arm and replace all 3 studs, The new steering arm hardware (studs, washers, nuts) cost me $30, the drag link ends were about $50 and the sleeve was about $12. Oh, and the machine shop guys were in utter disbelief about how hard it was to get off. MACHINE SHOP GUYS!
So, I ending up being out $182, and on top of that hours of frustration and angst, busted knuckles and dirty.
If you ever hear anyone wanting to do a steering arm, just fwd them to this link, and from one friend to another stop the madness. If it's been on there for 34+ years, chances are it's not coming off without an epic fight.
DRAG LINK DRAG LINK DRAG LINK!!! I can't stress this enough.
88 Suburban
