#26 |
Cause the Chicks DIG IT!!
while we're at the tanks and this threads going everywhere how low do those blazer tanks look under the back of the truck? I got a 3 - 5 drop and got the blazer tank but have been wondering bout this. Am i gonna be good?
#27 |
![]() Join Date: Feb 2001
Ok what years are those?
I will check out where the flange rests. I have the two straps holding the tank and the skid plate. Thats six bolts holding that tank up. I dont think its gonna come loose. The skid plate is snug against the bottom of the tank. Just looked and found these pics. I made my own cross members and the tank fits up snug against them. I didnt have to worry about it hanging down so much (which it doesnt at all) since its a 4x4. Last edited by Mudder; 02-16-2005 at 04:28 AM. |
#28 | |
67 is sold
Aren't you concerned having the tank snug up against the skid plate? I assume your skid plate is metal? |
#29 |
see but in those pics i cant see where the flange rests.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
#30 |
The flange on mine is below the frame. The straps are what holds it up.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
#31 |
Nope no concern and its been that way for 10 years. There is no movement between them at all. I think the flange may rest against the bottom of the frame. Any area that touches metal to metal there is rubber.
#32 |
what kind of rubber is between the frame and flange? i have some strips that came for it with the straps...
#33 |
I just used a small rubber hose that was slit on th edges of the cross members and it it came close to the frame. I dont think its that close to the frame. I redid all of it about 3 years ago but am sorta confused of what all I changed. I would have to look at it. I put a new tank in 3 years ago. The first one had come from a junk yard.
The straps do have rubber between them and the tank. Last edited by Mudder; 02-16-2005 at 01:30 PM. |
#34 |
I have to go by and get some other measurments today so I'll get the width of the inside of the frame today I hope. Been sitting here thinking about that flange. Not sure if it is even tight against the frame now that I think about it. I'll have to look at it.
#35 |
67 is sold
![]() I'm using strips of rubber between the side flanges of my tank to the frame. |
