![]() Join Date: Sep 2004
Blazer tank question
I'm wanting to install a Blazer tank in my 69 GMC LWB. I found one but it's listed as for a diesel.
Would there be any tank difference between gas and diesel? Will all Blazer tanks fit these 67-72 trucks? Thanks, aitch |
Maybe I should have asked this on the Blazer side. I assumed that several of the members had installed Blazer tanks.
Any thoughts on whether a deisel tank would be different? |
67 is sold
Did GM even offer a diesel on the 67-72 trucks
![]() Many people here have swapped blazer style tanks into their pickups with great success ![]() |
Blazer tank
If it's for a blazer with a diesel, it would have to be from the mid 80's. You might make it work, but it's not a very good fit.
It's listed as 26 x 26 x 9 and 27 gal.
Year not listed. |
Thats not a 67-72 tank. If you go to most any parts dealer they will have a steel tank for about 250? They are 21 Gallons. Here's a pic of mine.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
![]() Join Date: Feb 2001
I bought a steel replacement tank for a 86 (31 gallon) for around 100 bucks from Raybucks. They have the sending units and straps for mounting.
Mudder, did the 31 gallon Raybucks tank fit just like the 21 gal $250.00 model one???
Alex 1971 Lil' Red 350 SBC 700R4 |
![]() Join Date: Jan 2005
Couple of question for you on the tank install
1. Where do you mount your spare? In the bed? 2. Where do you route the fill neck? Inside the wheel well, or cut a new door in side of bed?
'72 Chevy K-20 Crate 350, SM465, 4.10's |
#10 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Correct me if I'm wrong but that's what I think
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#11 | |
67 is sold
CPNE is correct (again) (Rolleyes) LOL. I think the 77 chassis is wider than a 67-72 frame. I do believe that raybucks has the metal replacement tanks for the 72 Blazers (21 gallon). I wish someone with the books could see what the width differences are in the 2 frames.
#13 |
Oh crap
![]() ![]() I'll buy mine from Les at GMC Pauls.
#14 |
LOL I wasnt telling you to buy a 31 gallon tank I was telling you what I paid for one.
#15 |
How about a 73+ surburban tank in a 72 lwb frame? I've been thinking about doing this for quite a while but, as usual
![]() I've got the tank, with the complete rear section of the burb frame. I'll measure it and post it here later. Anybody know what the 72 frame width is? I'd measure mine but it sitting in a swamp right now. I'll probably get stuck as soon as I try to move it unless it freezes!
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
#16 |
Some good measurments on the two frames would be great. It would answer some questions.
#17 |
Does Tree know you are sporting a 31 gal. tank....that girl maybe on the way to Owensville, if she knew that,,,,, Ya know size matters!!! LMFAO!!!!
#18 | |
American Woman!
![]() I hate my gas tank being behind me when I drive...drives me nuts! |
#19 |
You are involved....and I am really laughing my A$$ off...couldn't help it Tree...guess that's my weird sense of humor.....I'm still laughing girl!!!
Well then......Move it!!! Both my trucks have had the tank relocated!
#20 | |
American Woman!
#21 |
Still laughing....and
#22 | |
Also, if someone had measurements on the early Blazer tanks that would be helpful. aitch |
#23 |
a thing i have a question about is.....does the flange of the blazer tank rest inside the frame rails or underneath? the only way i could see it fitting is underneath but like that i would think if a strap would let go things could get interesting when it started skidding on the ground sparking.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
#24 |
I've got a LWB and it measures 27 3/8 between frame rails.
aitch |
#25 |
Here's the 'burb frame section and tank I have;
![]() Fuel fill on the left side, correct? (Been a loonng time since I cut this out!). If it's left side fill then it measures 27-3/8 in. from the inside edge of the frame c channel to the inside edge of the opposite side. That's behind the tank. In front of the tank it measures 27-5/8 in. Top view; ![]() Can anybody tell me the capacity on this tank? Guesses maybe?
