Old 04-06-2005, 10:25 AM   #26
68gmcdually
68gmcdually's Avatar
I just got a owner's manual for my '68 off of e-bay I will check it out tonight when I get home.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
Old 04-06-2005, 12:39 PM   #27
68LSS1
68LSS1's Avatar
Originally Posted by john_doe
What did the GM say to run in the 67-72 Chevy/GMC trucks when they were new? Maybe something to consider?
Possibly, but if you have the original engine still running I might could see the use of a thick weight of dino oil. I'm sure most have changed/rebuilt the engines. And per chance if it did say to use 20w/50 back in the day, GM doesn't say to use anything like that today in their truck engine (except maybe for the diesels?).
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 04-06-2005, 01:23 PM   #28
1-PU70
1-PU70's Avatar
This was taken from a 1970 service manual
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 04-06-2005, 01:38 PM   #29
Mudder
Mudder's Avatar
I ran a comparison test with Vavoline and Castrol. The 305 Camaro had 250,000 miles. I had always ran Vavoline. After an oil change I would have to add a quart at about 600 miles. I changed to Castrol and I got an extra 200 miles before I had to add a quart. I believe the Vavoline breaks down faster. I drive 124 miles a day, so it was pretty easy to do a good comarison. I use Castrol now.
Mudder is offline   Reply With Quote
Old 04-06-2005, 04:17 PM   #30
booth
Active Member
booth's Avatar
Becareful when talking oil filters. One Fram branded filter could be made by Wix and the next Fram branded filter could be made by Baldwin, Donaldson... hey it could even be made by Fram. Depending on part# Napa filters are not all made by Wix. One way to tell, look at the baffle plates, (the top part of the filter with all the holes in it) they will have different stampings and hole paterns depending on manufacture and the size of the filter.
Later
Paul
'67 Chevy LWB (Running)
'67 Chevy LWB (Not Running)
'70 Chevy LWB (In Pieces)
'72 Chevy LWB (In Pieces)
booth is offline   Reply With Quote
Old 04-06-2005, 05:05 PM   #31
'70_402
'70_402's Avatar
If Wix Is The Best In Filters.... Just Buy A Freakin Wix Filter... Not One That They Made And Put Another Name On It... You Get What You Pay For And Trying To Save A Few Dollars When It Comes To Changing Oil Is Not A Good Idea... Find Somewhere Else to Save Some money
I Run Mobil 1 And Wix Filter Every Time.....
'70_402 is offline   Reply With Quote
Old 04-07-2005, 03:34 AM   #32
68LSS1
68LSS1's Avatar
Later
Paul
See my earlier post. Fram filters are made by Fram. No one rebadges as Fram. Fram does rebadge like I said earlier. NAPA Gold are Wix. Silver may be different as they used the cheapest bidder in the past for those. I never use the Silver so I haven't seen one in a long time. Better to stay away until someone determines who's actually making them now.
'68 Short Step
