Old 10-23-2014, 07:23 AM   #26
Keith Seymore
Keith Seymore's Avatar
Re: VIN decoder for 1970 GMC
Originally Posted by preciador6 View Post
Bruceman so this is the right frame for the truck?? I thought The numbers so post to match the vin#?
The sequential portion of the VIN should match if it is the "born with" frame.
Looks like a frame swap to me, Preciador.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-23-2014, 09:35 AM   #27
preciador6
K
This is a gmc value Van box truck any possibility they used different frames on this or were made different at another company
preciador6 is offline   Reply With Quote
Old 10-23-2014, 11:29 AM   #28
Keith Seymore
No.
The VIN stamp on the frame occurs at the vehicle final assembly plant, so the supplier doesn't matter.
The VIN on the body should match the VIN on the frame.
K
1979-1986
1986 - 2019
Old 10-23-2014, 11:36 AM   #29
preciador6
No.
K
Thank you Keith. Do you know of another place were this body would be stamped or it just came with a plate somewhere...I can't find it,the door on the driver side of this gmc came rib bided and there's no glove box
Old 10-23-2014, 01:57 PM   #30
Keith Seymore
It should be on a plate attached somewhere, but I wouldn't know specifically where.
Did you say who the manufacturer of the body is (ie, Grumman, etc)?
I can ask some of the guys around here if they know or recall.
K
1979-1986
1986 - 2019
Old 10-23-2014, 02:17 PM   #31
preciador6
K
Not sure it's a GMC Value Van p10 1971
Old 10-23-2014, 02:45 PM   #32
bruceman1968
bruceman1968's Avatar
preciador6, Search your entire step van body. Independent manufactures could put the Vin plate anywhere they wanted. So you need to look everywhere until you find it.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 10-23-2014, 02:52 PM   #33
preciador6
Will do thanks again...it's weird how the frame is the same year and same city.
Old 10-30-2014, 05:59 PM   #34
preciador6
Found it under some wires and junk on the firewall..Thanks Guys.
Old 10-31-2014, 08:07 AM   #35
Keith Seymore
We build/built multiple millions of vehicles every year in Flint. Doesn't seem that unusual that if the truck was still local that a donor frame would come from the same area.
Very good. Did it match?
K
1979-1986
1986 - 2019
Old 10-31-2014, 08:11 AM   #36
preciador6
K
It's a Flint 1971 frame.
