08-20-2005, 03:42 PM | #26 | |
no brain no headache
are you still giving them away with the video? i plan on buying a video when i get to that point and i was just courious.
1996 GMC Sierra z71 1970 SWB 2wd (project) |
08-20-2005, 04:14 PM | #27 |
grendel, a postal MO is probably best if its convenient for you. Otherwise certified funds ($20) along with your mailing info to
ebfabman PO Box 5454 Concord, NC 28027 70c10swb, sorry that was a three only promo a while back (they were taken fast) to raise donation funds for this message board. However if you purchase a Cab Repair DVD set, I will include a filler patch at half price ($10) if this would help. Thanks......eb |
08-20-2005, 04:36 PM | #28 |
I like matthufhan's, all you need is a piece of sheet metal bigger than "that there hole", and a rivet gun. No template and no need to "massage" that piece of metal.
'69 Fleet It ain't yours, if you didn't build it! |
08-22-2005, 02:00 PM | #29 | |
08-22-2005, 02:14 PM | #30 |
fill gas filler hole
You can fill the filler hole by taking a short piece of 2 in exhaust pipe 5in long & slicing it off at an angle- same angle as back of hole, cap the other end with a piece of flat plate, butt it up to the back of the hole and weld it in.
Then drill a1/2 hole in the bottomcenter, drill another hole in the bottom1/4 in size to the side so water can drain out, then install a electric antenna in the tube, wire it up under the carpet to the radio and you have filled the hole with something you needed anyway. 72mdgmc |
08-22-2005, 02:17 PM | #31 | |
I am not installing an AM/FM radio, as I posted earlier. Just an XM radio tuner and MP3 Player. |
08-22-2005, 02:18 PM | #32 | |
I have and can use pretty well a few types of welders. |
