Old 09-17-2005, 02:22 PM   #26
cdowns
cdowns's Avatar
Originally Posted by rmrtndl
Have you had any problem with the color fading or having a milky appearance?
I have read POR-15 is UV sensitive. I don't think the frame will get any direct sunlight (insert witty comment about rolling the truck here). Anyone know if indirect light will cause fading etc?
A local guy used POR-15 on his frame ('67 Ford). It looks awesome and finish appears very durable. He is very pleaseed with the results so far.
no fading issues cause i tend to keep the trucks on all four tires// i had the inside of my last bed painted with POR15 and after about 4years in full florida sunlight there was some fading but no peeling ,lifting or rust issues however it did nothing to stop the oak tree from falling on the truck in a hurricane
Old 09-17-2005, 07:06 PM   #27
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
I had mine sandblasted then used epoxy primer and industrial enamel
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 09-17-2005, 07:57 PM   #28
4x4Poet
I have read POR-15 is UV sensitive. I don't think the frame will get any direct sunlight (insert witty comment about rolling the truck here). Anyone know if indirect light will cause fading etc?...
POR15 is UV sensitive. When I first started using it, I had some fade on me. Looked worse than flat black. Best online comment I ever heard is, "It looks like @$$."
That's why I mentioned above that I topcoat POR15 with Extreme Chassis Blk while the POR15 is still tacky (usually 3-5 hours after application). Any UV resistent paint will do, such as a store gloss black or any other gloss color. I just like the higher solids content of Extreme Chassis Blk.
Just for info, if POR15 is left to dry before topcoating, it dries so hard and smooth that it has to be scuffed up to give the topcoat something to adhere to. It arguably needs POR15's Tie-Coat primer, too. However, by topcoating POR15 while it is tacky, no scuffing or primer is needed which saves time, effort, and $$.
This is particularly important to me when I'm coating axles, frames, brackets, and other parts that have many cavities and areas that I can't reach with sandpaper, so I couldn't scuff all of the POR15 surface if I wanted to. Tacky-time topcoating is the best UV-protection method I've used, so far. Learned it from a POR15 rep.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 03-29-2019, 11:27 PM   #29
OlySezHey
OlySezHey's Avatar
Re: Looking for product recommendations for painting the frame
OK - it's been 14 years - how do all y'all feel about things now? Thanx, I REALLY appreciate the help
Genesis 1:1 - Revelation 22:21 🙏
'72 GMC C1500 Wide Side Sierra Grande
'77 Chevy C20 CCLB (went to go get it 4/29/19!!!)
'96 Chevy K2500 Ext cab
'97 Chevy K1500 Tahoe (I gotta stop lookin' at CraigsList when I'm bored!)
'57 Chevy 6400 (coolest piece yet )
OlySezHey is offline   Reply With Quote
