#26 |
Well, I've already got an aluminum Vertex box. I think Jeff's would probably fail mainly due to not being completely enclosed. Or is there a top that goes on it?
~Steve~
Friesen High Performance Auto and Graphics Toy: 87 Shortwide, 406 smallblock with a little boost My 87 buildup Daily Driver: 99 Sierra SLE 4X4. Black on Black and harder than hell to keep clean. ![]() |
#27 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
No top on the drop down version.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#28 |
That would probably be the kicker, no top.
~Steve~
#29 |
yeller
One could be fabbed pretty easily.
Chris, I had no clue you had one of there...where are you mounting yours?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#30 |
I could have swore I told you that when you were talking about one.. Maybe it was someone else.... IF I use it, I plan to put it inboard of the frame, IF there is enough clearance.
#31 |
Looking at your pics, what did you use for painting your frame, Jeff?
~Steve~
#32 | ||||
Until Seventy Times Seven
![]() Hurricane 'daughter' (and her mates)... Quote:
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#33 |
Replace the seals and o-rings on the steering box input shaft. The repair kit had instructions in many differrent languages including English. Unfortunately, they were all for the pitman shift.
![]() Replace the speedometer cables and cleaned/lubed the speedometer. Still, having some minor issues with it. Finally, used the truck to haul around a car trailer loaded with boxes and furniture...
#34 |
![]() Join Date: May 2004
Worked through the weekend then got called in Monday. Today I got the 350 built as far as the rocker arms then had to run my father-in-law to Memphis for a Dr appointment. I hope to get the motor in by Thursday then #2 son ordered new carpet & window seals so I'll have to see if I can get to them before I go back in to work.
76/77/78 Cheyenne 1997 K3500 454 soon to be 496 |
#35 | ||
yeller
