#26 |
67 is sold
While the tank behind the rear axle may be more at risk, I have yet to read one post about one being involved in a wreck that caused the tank to rupture.
Is it possible? Sure it is. But I have never read about one case on the few years I've been on this board. Just my $.02 ![]() |
#27 |
![]() Join Date: Feb 2001
My rear tank is basically done just like 95% of all the Blazers out there.
#28 | ||
its all about the +6 inches
A tank behinde the seat does in fact offer plenty of side impact protectoin...it is higher than the hood on most cars sold today. (today as in the last 10 years) Quote:
One out of the billions made, and none of the hundreds modified. |
#29 |
never fart in your cab, it might blow up.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
#30 |
![]() Join Date: Sep 2005
I think fuel tank location is determined by space limitations and desired interior space which is much more of an issue on cars.
Several of the Lexus cars I work on have the tanks mounted behind the rear seat in a effort to gain more trunk room. Some models even use a saddle tank that wraps around the drive shaft The only down sides I see with the tank behind the seat in a truck is room and sometimes the gas smell that I think comes from the filler cap venting as my truck tank does not leak.
1969 C20 Customer Camper CST, 396, TH400, Factory A/C, Olive Green. |
#31 |
Just need a couple more parts.
[QUOTE=Longhorn Man]Very good idea in making a frame around it...have you done anything from damage on the bottom of it? Most cars will go UNDER the rear of our trucks and lift our rear tires off the ground. (I know you said lowered, but hom much...this may not protain to you)
I am lowered 4 inches. I did not protect the bottom of the tank. Since I am a pavement only driver with this truck, I did not think it was an issue. If someone runs into me and goes under the box I don't think I should have the responsiblity to protect others once they are under my vehicle. Unless I backed over them. You have to draw the line somewhere as to safety, as you can not protect from every possible equation. When my tank was behind the seat I do remember smelling vapors on hot days when I was sitting at a light or something. Pretty sure the vapor were from the vented cap and not leaks inside the cab.
--------------------------------------------------- 1947 Studebaker M5 project to match the camping trailer. 1950 Chev 4x4 Pickup 1958 Shasta Airflyte Travel trailer (fresh restoration) 1971 C/10 Pickup(Frame off Restoration) 1972 K5 Blazer CST (Daily Driver & My Company Truck) 1976 Honda CB750 Bobber 1988 Jaguar XJ12 |
#32 |
Cantankerous Geezer
The safest location is in the front of the bed between the frame rails. There you don't have to worry about rear and or side impact, and you have the bed and stiffeners between the tank and the driveshaft.
In my 15 years of firefighting, we never had a gas tank explode. I saw a couple where the fire burnt the tank, causing the gas to vaporize, which made one heck of a blowtorch. The NBC report on GM trucks in the mid-70s was a fraud. They had to use blasting caps to get the truck to explode. From an impact standpoint, in the cab is where the tank should be. But if you want to move, go ahead. It's in the works for my 69, I want to use that space for other purposes.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
#33 |
![]() Join Date: Aug 2001
![]() ![]() ![]() ![]() (ANDY..I CAN'T IMAGINE ANYONE SENDING YOU HATE E-MAIL LIKE YOU' VE OFTEN COMPLAINED ABOUT. MAYBE YOU OUGHT TO POST SOME OF IT FOR EVERYONE TO SEE, & MAYBE SOME OF THE MODS OR JOSH CAN GET TO THE BOTTOM OF THIS) ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 10-04-2005 at 06:13 PM. |
#34 |
IMO, if you want to be safe, live in a bubble and walk everywhere. Honestly I havent heard of many explosions of gas tanks in wrecks, and if they hit you that hard, youve got more prominant things on your mind... unless your unconsious. For me, Im going to relocate the gas tank behind the axle and install 3 point harnesses. In an instance of an explosion, hopefully the bolts mounting the cab to the frame break and I fly to safety.
In any instance, dont worry about it... I just wouldnt mount it above the top wall of the bed and drive through a rifle range. RELOCATE IT! If all else fails, reinforce the hell out of it. ![]() |
#35 | |
![]() I HAVE NEVER HEARD OF A MISHAP FROM JUGGELING RUNNING CHAINSAWS OR SWORD SWALLOWING, BUT COMMON SENCE TELLS ME THAT THIS IS A DANGEROUS PRACTICE, & NOT TO TRY THIS. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 10-04-2005 at 08:39 PM. |
#36 |
I think folks have been watching to much Dateline, I keep hearing "blow up"...when it's really a case of rupturing and the leak catching fire(then it explodes). I have a video entitled "deadly weapons" where they put a lot of fallacies to rest...the guy takes a tank out of a truck and fills it completely (as well as half full) and shoots not only .223 rounds but tracers at that into it and he couldn't catch it on fire..he only managed to drain it. I'm more concerned about it "catching fire" directly behind me versus 4 ft or so behind me...I'll take the distance.
1971 Chevy swb Chevy trucks and import cars ![]() Last edited by Derrickbwg; 10-04-2005 at 07:33 PM. |
#37 |
SLOW BUT SURE,BUT CLOSER
I've had my truck for 19 yrs and have never considered to upgrade the to discs, bags, move the tank etc. First reason is money and second is I'm lazy!!!! LOL!!! I would feel safe in mine no matter what happened,especially if hit. These old trucks have real metal not junk like todays. Work in a stamping plant like me and you would know what quality is. And Andy I agree with you.
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
#38 |
do you smoke?
sorry i had to make that big to bring out a new point in this topic. imagine having fumes but forgetting they're there and lighting up a cigarette. |
#39 |
I was t-boned in my first truck,a`72.I was crossing a dual hiway and a guy ran the light and hit me at around 60 as I was going throught the intersection.Frame was bent,the cab & bed were shifted and caved in.No problem with the gas tank.Tanks were in cabs for about 50 years.Then they moved them to a more dangerous place,not for safety,but to give more interior storage.I don`t think safety is an issue in either of the two locations in question.
#40 | |
1971 Chevy swb Chevy trucks and import cars ![]() |
#41 |
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 10-05-2005 at 10:44 AM. |
#42 |
67 is sold
[Rodney King voice]Can't we all just.... get along[/Rodney King voice]
#43 |
fugedaboutit
![]() Join Date: Mar 2005
VinceY do have a pic of the extra bracing you did?.. I'm interested in doing some extra bracing after reading threads like this. I personally relocated my tank for local drag racing rules.
I have seen cars with gas tanks behind the rear axle.. dont remember which off hand but pretty sure they are out there. Not trying to generate hate mail, just remember seeing some after I started my tank swap.. Seems to me like some of the older mustangs had em'.. ?? eric
Currently truckless ![]() |
#44 |
I'm watching you!
My opinion here....
Depending on your model of truck you have between 6-9ft of steel behind the tank, about 5-6 ft in front, about a ft on the sides, and what over a ft on the bottom and a few ft on top. As far as impact protection.....that tank is safe, and if you are hit hard enough on the side to rupture the tank, are you going to be alive anyway? The only safety concern is if the tank is leaking, which in that case fix it before you drive it...a leaking tank anywhere on a vehicle is a saftey concern! Now I plan on moving my tank to the rear and protecting it with a crossmember and hidden hitch. The ONLY reason I am doing this is to gain the few inches behind the seat. For one I'm 6ft and would like the extra few inches and 2 I am a car audio enthusiast and would like the room for my audio equipment. If I was doing just a regular restoration I would have no problem with the tank in the cab. Again just my opinion. Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold ![]() Last edited by 68haywagon; 10-05-2005 at 11:29 AM. Reason: spelling is the devil - DOH |
#45 |
I think I'm among the majority that would agree that the tank will be prettysafe in either location although each location does have pro and cons. The important thing to remember is what was stated earlier, that the vapors or lost fuel in the event of a rupture is where the problems could arise from. Having said that, I would strongly recommend any one running a electric fuel pump to install a impact switch. In the event of a accident were the fuel pump stays live there could be a possibility of ruptured lines so you understand what I'm getting at here. Which leads to another point that hasn't been touched upon, the line routing. Protect the tank reasonably, install impact switch with electric pumps, and watch the feed (and return line if applicable) routing.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
#46 |
if i ever change my tank(again), it will most likely be a fuel cell in the front of the bed....
-Steve |
#47 |
![]() Join Date: Mar 2003
#48 | |
I'm watching you!
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold ![]() |
#49 |
![]() Join Date: Jan 2001
I've got twin auxiliary saddle tanks. My main reason for wanting to put in the rear tank is weight distribution and room in the cab. In the meantime, I'll watch out for little old ladies launching out of side streets.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
#50 |
I'd like to thank everyone who responded.....I know I learned a lot and from the numbers, it seems many others may have as well. Hated to hear about people getting hate mail over expressing their own views in an open forum where such valuable knowledge is so readily avaliable at a minimum of cost.
Possibly this issue needs to be addressed and dealt with as well. |
