Old 02-28-2020, 09:05 PM   #26
Hart_Rod
Hart_Rod's Avatar
Re: What speedo gear do I need?
Originally Posted by tim_mc View Post
Here's a good thread on pulling the tail housing and changing the drive gear:
http://67-72chevytrucks.com/vboard/s...d.php?t=462914
Good thread, however.... my tailshaft has something that looks a crushsleave on it. How the heck does that come off????!!!!
Hart_Rod is offline   Reply With Quote
Old 02-28-2020, 10:46 PM   #27
Hart_Rod
Hart_Rod's Avatar
I got the sleeve off with a little bit of tapping. I then took the output gear off. When I went to put the new output gear on, I noticed that there are two alignment holes in the output shaft. Which one is the correct one? It looks like it should be the most forward one. Suggestions?
Old 02-29-2020, 12:43 PM   #28
TBONE1964
Cluster King
TBONE1964's Avatar
Here is the way to tell if your speedometer is out of cal.
Regardless of your tire size, gear ratio , etc, drive your truck on a measured mile.
If you drive a measured mile and your odometer either falls short or exceeds a mile, then your trans gears need changed.
If the odometer moves exactly one mile for the mile driven, the gears in the trans are correct for your combination.
If comparing your factory speedometer with gps, you will find the oe speedometer for these trucks are rarely on the money and need some calibration.
Hope this helps. I don’t know much about speedometer gears at the trans but know how to confirm if they are correct,
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 02-29-2020, 01:03 PM   #29
TBONE1964
Cluster King
TBONE1964's Avatar
Old 03-01-2020, 10:33 AM   #30
Hart_Rod
Hart_Rod's Avatar
Good info, Thanks!
So I found a Youtube video from Monster Transmissions that explains why the clip needs to go in the most forward hole. I got everything put back together and the speedo is dead on!
