11-17-2005, 04:56 PM | #1 |
What speedo gear do I need?
My speedo is showing 20 slower than I am going. I currently have a blue one in the trans just to see if it was the speedo or the gear. The gear that came out looked pink. Is this an actual gear color? Also, where do I get them?
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear |
11-17-2005, 08:37 PM | #2 |
Re: What speedo gear do I need?
Try this link. It'll let you know what you need
http://www.tciauto.com/tech_info/speedo_gears.htm If your a turbo350 tranny than a pink is 7 tooth and blue is 18 tooh. Big difference, so yes you need to go back a few teeth.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 11-17-2005 at 10:49 PM. |
11-17-2005, 09:46 PM | #3 |
Sounds like you need a gear with less teeth. Less teeth-spins faster, more teeth-spins slower.
I'm having the same problem but in reverse, the speedo in my truck reads about 10 to 15MPH fast. I figured that I need a 45T gear and a 40-45T housing.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
11-18-2005, 01:41 AM | #4 |
www.novaresource.com/speedo.htm and ...speedo2.htm
There's a formula there for calculating the speedo gear ratio you need, and a list of available combinations you can use to get that ratio. You'll need your rear end ratio and your rear tire diameter. The TCI site mentioned above has a tire diameter calculator. Last edited by jimfulco; 11-18-2005 at 01:41 AM. |
11-18-2005, 01:48 AM | #5 |
What speed were you going when your speedometer was 20 MPH off?
You can buy replacement gears at a GM dealership. |
11-18-2005, 08:59 AM | #6 |
Thanks for the info. Will have to figure out my gear ratio now. It's a 5 lug leaf rear.
12-05-2005, 12:16 PM | #7 |
Update. I believe the gear ratio is 3.07. I have 29" tall tires. The drive gear on the trans shaft is black, 8 teeth. The current driven gear is brown, 18 teeth. Do I need to go up or down on teeth count on the driven gear to get the speedo to show faster? Speedo is currently showing slower than I am going. I have used the TCI site above, but it shows to use what I have and it is off. Also, using the Nova website, it says I need to drop down to an 17 tooth driven gear but the TCI site does not show one listed. Any help is appreciated..
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear Last edited by fade94; 12-05-2005 at 12:31 PM. |
12-05-2005, 08:16 PM | #8 |
Send it to me, and I'll send you mine its 20mph fast
1971 LWB Chevy C-10 350/350 3:42 eaton |
12-06-2005, 01:46 AM | #9 |
See if your local Chevy dealer has a 17-tooth gear. If they can't find it, tell them to try part number 3987917.
12-06-2005, 02:48 AM | #10 |
Granddad's Ol' Truck
I just had to do this at the beginning of last week. In addition to the link that Bill/Palf70Step listed above, try this one:
http://www.bowtieoverdrives.com/index.shtml I found this one helpful for calculating the info. The TCI site was helpful for the part numbers that I needed when it came time to order them from the Chevy dealership. Dean
1971 Chevrolet Custom 10 short step-side 2005 GMC Sierra SLT 2500HD crew cab 2wd [I]1971 Chevrolet Custom 10 Deluxe lwb fleet-side |
12-06-2005, 12:02 PM | #11 |
Hmmm, all the calculators want to know how many drive teeth I have now and I dont really want to take it apart until I have a new one to go in. Anyway to tell what I have now with a 3speed tranny and 3.73 gears? I am swaping to 3.08 gears with the same tranny. Tires are 29"
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
12-07-2005, 12:08 AM | #12 |
http://novaresource.org/speedo.htm has the formula and charts that you need.
Rear axle ratio x 20.2 / tire diameter = speedometer gear ratio In your case, 3.73 x 20.2 / 29 = 2.598:1 Take this ratio, rounded to 2.60, to the charts. Since there's no gear combo that gives exactly 2.60, you'll have to use one that's as close as possible. If I need one that's about halfway between two available ratios, I'd prefer using the one that's a little less than what I need, because it will make the speedo read a little bit fast, instead of a little bit slow. My lead foot makes this a better choice . Decide which gears you need, & buy them. A local GM dealer should have what you need. |
12-07-2005, 09:01 AM | #13 |
Well, I did the "rotate tire and count drive shaft revolution". Now I'm really confused. The drive shaft rotates LESS than 2 times for ONE revolution of the tire. Wouldn't that make the ratio 2:?? Local Chev dealer does not have the 17 tooth gear in stock and can not find one locally.
12-07-2005, 12:10 PM | #14 | |
12-09-2005, 02:37 AM | #15 |
Might be able to tell by the color of the gear. Take out the driven gear (one bolt & a one-handed wiggle & pull maneuver), then see if you can look down the hole with a mirror & a flashlight, but be aware that the colors tend to fade with age.
Of course with the driven gear out, you could count its teeth, then see which drive gear matches it in the novaresource chart. That's assuming the speedo is correct now. Count the teeth more than once, because it's easy to lose count. |
12-13-2005, 06:26 PM | #16 |
Ok. Got the 17 tooth from local dealer. Put it in. Now, it just jumps. The drive gear on the shaft looked fine. Anything else to check on this thing? Is there something special I needed to do to install the driven gear other than just put it in?
12-14-2005, 01:08 AM | #17 |
Is the speedo cable fully engaged in the small end of the gear? Sometimes you have to fiddle with it to get the square drive to engage.
12-15-2005, 03:18 PM | #18 |
I could have sworn it was all the way in, but I'll have to check. I may have pulled it out while hooking the other end back to the speedo.
12-15-2005, 07:06 PM | #19 | |
What size gears are in a TH350? 1.5" or 3/4"? I also dont want to take mine out before putting new ones in.
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over. _______________________ 2006 VW GTI |
12-16-2005, 02:28 AM | #20 |
Chevys usually have the 3/4" one, and Buick, Olds, & Pontiac usually have the 1-1/2" one. The housing that the gear rides in is also bigger on the BOP transmissions, and you can tell the difference from the outside. The small one is maybe an inch in diameter, and the big one is more like 2".
10-12-2019, 08:52 PM | #21 |
For anyone that might search this old thread. There's a convenient way to determine the correct speedo driven gear if your speedo is off. My speedo was reading 20% faster (72MPH) than actual (60MPH on GPS), or 12MPH faster. 12/60 = 0.20 or 20%. The rule of thumb is 1 tooth for every 5% of difference. In my case I had to add teeth to the driven (pencil) gear to slow down the speedo, 4 teeth since it's 20% too fast. My old driven gear was 20-tooth. I swapped it today for a 24-tooth (ACDelco P/N 3860347, yellow, 3/4"OD). The speedo is now accurate. Luckily I did not need to change the 7-tooth drive gear in the tailshaft. Truck has 235/55R17 tires and a 3.07 rear end.
02-28-2020, 09:18 AM | #22 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-28-2020, 09:35 AM | #23 |
Here's a good thread on pulling the tail housing and changing the drive gear:
http://67-72chevytrucks.com/vboard/s...d.php?t=462914
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
02-28-2020, 10:34 AM | #24 | |
02-28-2020, 12:03 PM | #25 |
Who in the hell looks at their speedo in reverse???
