#26 |
Re: anyone seen update on this blue truck?
that tells me the brand... or are all air ride suspensions the same?
#27 |
![]() Join Date: Apr 2004
I thought you were asking how far it was lowered. You were not specific. Air ride has adjustable ride height.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#28 |
#29 |
Questionable
My post was not incorrect. I went to Google.com and searched for "air ride suspension". The first return is Air Ride Suspension's website.
http://www.google.com/search?sourcei...ide+suspension Add that with the "C" notch and you have his suspension.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#30 |
It has dropped spindles in the front but it also has full air ride suspension also. I think it sits about 8" lower than my 68' when the bags are deflated.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
#31 | ||
OFF TOPIC: Quote:
#32 | |
Questionable
![]() Just trying to help, but everyone wants to make me out to be a butthole!! ![]()
#33 |
The spindles are 73-87 3" drop.
#34 |
thanks for the info kxmotox247, just the stuff I was askin for!!!
#35 |
kx thanks for all the info and your reply to my PM good luck with your car I think everyone would agree the 67' is untouchable.
bogey5 |
#36 |
Thanks for the compliments everyone. The original owner should get the credit for putting it together though. It's unbelieveable how much that truck attracts attention.
#37 |
Questionable
Is the original owner a board member?
#38 |
He was at one time but I don't think he's been on here since I bought the truck. I think he was building a 59-60 Chevy wagon that sounded pretty cool.
#39 | |
#40 | |
I think Belltech either made or still makes them. |
#41 |
#42 | |
#43 | |
LAIDOUT
Kxmoto wasn't sure about the wheel measurements but I have done a little checking and estimate his front 18x8s are 4" BS, and the rears are 20x10s with the reverse rim option, BS about 3 or 4". 3" is the minimum BS for this wheel with the reverse rim. Wheel info: http://www.americanracing.com/wheels...nter§ion=V After deciding I wanted my truck's stance to duplicate this truck, I found and installed a narrow-ish Ford 9" in my truck which is 58.25" wide hub to hub. My 9" is 7.75 narrower than the stock 71 rear-end, and after a few careful measurements I have decided to go with the minimum 3" BS on the rear 20" Torque Thrusts. I even bought a 68 front clip for my 71 to complete that look, but my truck will be torch red. Installing a Camaro rear-end isn't a true bolt in, you have to cut off the leaf spring pads, set your pinion angle, and weld on the angled pads for the trailing arm C-10 suspension. About the same as I had to do with the 9" I used. |
#44 | |
