02-07-2006, 07:29 AM | #26 | |
Re: Misc Performance and etc
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
02-07-2006, 12:47 PM | #27 |
Java Mechanic
Would the Victor Jr work OK on a basic truck 350 (72 vintage 185hp 4v motor) with mid 80's FI smog heads with an Edelbrock 1407 carb and economy headers hooked up to a granny-low 4sp in a C-20?
I was thinking of chucking some $$ at an air gap RPM .. but might be interested in that manifold if it will work on my setup.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
02-07-2006, 04:12 PM | #28 | |
02-07-2006, 08:16 PM | #29 | |
'70 GMC C-25 LWB
1970 GMC C-25 LWB (middle of frame up) 5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood. 1987 Camaro z28 350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer. 1988 Monte Carlo (Super Stock ashpalt race car) My Truck |
02-07-2006, 08:17 PM | #30 |
Some More Picks of the Edlebrock RPM manifold
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" Last edited by Bowtie67; 03-06-2006 at 09:32 PM. |
02-07-2006, 08:18 PM | #31 |
More picks of Holley Stealthram Setup
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" Last edited by Bowtie67; 02-22-2006 at 10:30 AM. |
02-07-2006, 08:20 PM | #32 |
More StealthRam EFi Picks
02-07-2006, 10:18 PM | #33 | |
Java Mechanic
I could be interested in that second manifold (didn't see it on the first pass..) .. I'm open to suggestions also.. if going to a larger plenum manifold and the performer carb doesn't really buy me anything I may want to go a different rout ... just trying to get a nasty sounding rig that will snap your head back .. not neccesarily trying to get low ETs (especialy with a two ton sled of a C-20 .. lol)
02-07-2006, 10:42 PM | #34 | |
02-07-2006, 11:18 PM | #35 |
Can't tell me nothin'
Take me out of the runnin for the Vic Jr. the Wallet just doesn't seem to co-operate with me these days.
02-08-2006, 01:19 AM | #36 |
Hey Botie,you`re right.And,that`s what I`ll do.My son broke his leg(pretty bad)a couple weeks ago snoboarding.So,we won`t be doing a trip to N/E to ski.I`ll just do a redeye solo-style.I`ll give you a down payment to light a fire under my azz.If you still have the Muncie when I come,and I have the cash,I`d like to haul that back.PM me what you`d like down on the hood.
02-08-2006, 01:36 AM | #37 |
Can you shoot me a # I can call?
I am probably local and I am interested in the front suspension and EFI conversion. |
02-08-2006, 07:15 AM | #38 |
special-K, grendel You have email
02-08-2006, 04:13 PM | #39 |
Active Member
Any more info on the 5-lug conversion axles. Do they have the wheel studs? What would shipping to 95350 be?
thanks
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
02-08-2006, 04:36 PM | #40 |
'70 GMC C-25 LWB
Were you able to find a part number on the Stealth Ram? I need to figure out application info on it. Maybe you could shoot me a phone number too?
(D)
02-08-2006, 06:20 PM | #41 | |
Minus the powder coating, Minus the Aif FIlter and throttle cable bracket assembly and I will shoot you a PM with my number
02-08-2006, 06:26 PM | #42 | |
02-09-2006, 08:55 PM | #43 |
Thanks,he`s fine.Laid-up with a full leg cast for 6 weeks and a tutor coming to the house.Then 4 weeks in a walking cast.He`s talkin`to his girlfriend all the time on the phone,now.Maybe he`ll want to take the ride up,but kinda doubt it.He`s hating the crutches and it`s hard to sit cuz it needs to be elevated.
02-10-2006, 07:03 PM | #44 |
ttt
02-10-2006, 11:12 PM | #45 |
How old is the 4 core rad. and how much, if you got rid of the electric fan.Is it for a auto. or manual.zip is 82210
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
02-11-2006, 02:02 AM | #46 |
what happened to flint mi
hello do you still have either of the fuel injection set ups? how many sensors did you have to install? i.e- o2- throttle position -coolant temp -maf or mas ? thanks
02-11-2006, 07:49 AM | #47 | |
Between both setups the Stealthram setup although it looks the coolest the MPFI actually is a much better setup because of all the runners and the inlet for air is all equel to all cylinders, although not really any issue is that the Stealth setup will have a tendency to run a little richer on the rear cylinders because of the other cylinders are stealing most of the air before it can get to the rear cylinders. The Stealthram setup is a bit like a tunnel ram, the base is actually from a tunnel ram it runs better in the mid to upper RPM ranges but becuase of it being a fuel injection setup the lowend isnt truelly all that affected.
02-11-2006, 10:25 AM | #48 |
Bowtie, if it's not already spoken for you can consider the Holley Multiport Fuel Injection system sold. I'll PM you my address so you can give me a quote on shipping.
Thanks, Ron
72 Chevy C10 (rust repaired, starting body work) 72 GMC 3/4ton 4x4 72 Chevy C20 Suburban 38 Ford Tudor Humpback Sedan (from the darkside) 67 Pontiac Parisienne 55 Studebaker Commander 2dr Hardtop (Starliner) My Youtube channel with Video Updates! |
02-11-2006, 10:27 AM | #49 |
PM me and I'll send you a m.o. MON.
02-11-2006, 03:19 PM | #50 |
Kaycee, ronh72c10, PM's Sent..
