Old 02-11-2006, 08:42 PM   #26
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: How low should I go?
Originally Posted by camaro__thunder
Lower it to the ground, and then when that gets in the way, chop the rockers off
Or you can start digging
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 02-11-2006, 08:43 PM   #27
1969owner
1969owner's Avatar
1969owner is offline   Reply With Quote
Old 02-12-2006, 09:05 PM   #28
Hart_Rod
Hart_Rod's Avatar
This low!!!!!!
Hart_Rod is offline   Reply With Quote
Old 03-29-2006, 09:34 PM   #29
carrzy4
Active Member
carrzy4's Avatar
What about a 3/5 coil spring drop? is there any other suspension parts that you need to change or modify?
carrzy4 is offline   Reply With Quote
Old 03-29-2006, 10:37 PM   #30
carrzy4
Active Member
carrzy4's Avatar
lmc truck says if you lower the rear 5", you need to C-notch and add an adjustable tracking arm, is that true?
Old 03-29-2006, 10:42 PM   #31
powell72
powell72's Avatar
An adjustable track bar, and shock mount relocators, yes. No need for a notch though, not even with a 6'' drop.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 03-29-2006, 10:44 PM   #32
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
LMC is a bunch of knuckleheads. Like Powell said, 6 inches is fine w/o c-notching.
Old 03-29-2006, 11:04 PM   #33
shifty
Questionable
shifty's Avatar
Rob, you need to help me work on the suspension for my truck
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-29-2006, 11:11 PM   #34
Hart_Rod
Hart_Rod's Avatar
Any time man! Whatcha need?
R
