#1 | |
Son Of Gravel Man
How low should I go?
I would like a lower stance but still have some ground clearance to clear speed bumps and potholes. What drop am I looking at?
Daily driven 70 C10 longbed Its a work in progress ![]() Quote:
Re: How low should I go?
probly run a 3.5/6 or a 5/7, but bags are the way to go if you have the money
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
Watch out for your cornhole !
![]() Join Date: Jun 2003
A 4/6 drop is completely drivable without worry.
67-72 Addict!
I just did a 3/4 drop with cut front springs and new rear coils. I'm waiting on my new urethane bushings to see how low the sway bar will be using stock brackets. I may have to grind off stock rivets and modify. My rear shifted 1/4" to the right.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#5 | |
Outlandish Trends - FL
-Bret 67 short-fleet sold! |
![]() Join Date: Aug 2005
I just did a 4/6 which I thought I would be happy with, but now I want it lower. I would go 5/7 with coils and spindles or get er bagged
its just $$$$$
4/6 is plenty drivable
4/6 is totally driveable. Just get the exhaust tucked up.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
![]() ![]() Then you can change your drop whenever you want.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
Questionable
BAG IT!!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
WTB this ad
3.5" 6" gets her pretty close to level. Very driveable.
laying low
![]() Join Date: Mar 2001
See. I just love those shots of your truck. Smooth ride there bud. I think I am convinced to go with the truck ralleys on my 69. Oh and I dig spinners too. Have them on my 88 GMC with Outlaw ll wheels.
You must have the bump stops removed from the rear? No bottoming at all with the 6" rear drop? 4" spring and 2" blocks?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#13 |
How low should you go man. All the way to the ground.
#14 | |||
Son Of Gravel Man
![]() Quote:
![]() I will probably go 3/4 for now. ![]() ![]()
#15 | |
WTB this ad
#16 | |
WTB this ad
#17 |
Active Member
what is everyones thoughts on coil-over shocks with drop spindles?
#18 |
I agree with the 4/6 I only drag my pipes because I havent got them tucked in the frame rails yet, bumpstops from rear have been removed and I haul 4 wheeler and couple of other heavy loads no bottomin out. I drive it everyday, no problems other than pipes.
1971 LWB Chevy C-10 350/350 3:42 eaton ![]() |
#19 |
I've got a 4/6 with my pipes below the crossmembers and I have NEVER bottomed out on anything.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
#20 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#21 |
Active Member
I vote 3.5F 5R real streetable and gives you that "old skool" raked look...
#22 | |
WTB this ad
#23 | |
#24 | ||
Son Of Gravel Man
![]() as for rims these in 20's ![]() or the 17 escalades which ever I can fit in my buget. Maby I'll just get the 2 in drop springs and have them throw in the 5 in drop springs instead? ![]() You gotta have a little rake ![]()
#25 |
Epoxy Primer Friendly
Lower it to the ground, and then when that gets in the way, chop the rockers off
