02-20-2006, 01:12 PM | #26 | |
Re: Crate vs built or vice versa
As for cast parts, I agree that cranks are fine but if you're going to put any significant beating on the engine I'm a big fan of the H.T. pistons. In this case, it's within my rule - < 1 HP/CID, cast, > 1 HP/CR, H.T., > 1.2 HP/CR, forged, baby - forged |
02-20-2006, 01:14 PM | #27 | |
GREAT response! |
02-20-2006, 02:17 PM | #28 |
where are you getting this 3yr warranty at? names and #'s would be great... thanks
'67/70 Chevy C/10 '10 2500 Crewcab Duramax 4wd Last edited by redneckdds; 02-20-2006 at 02:18 PM. |
02-20-2006, 02:19 PM | #29 |
How about an itemized price list?
I had a real tired 350 of unknown origins in my truck when I bought it. The time had come to fix it. I decided to build my own. I also decided that since I tow a lot a stroker would be nice under the hood. AND my buddy the engine rebuilder guy said he just picked up a 400 crank shaft. They have pistons that work with your stock 350 rods and a stock 400 crank so with the tired old 350 I had on a stand I had everything I needed for a 383. You can't format real easy so just deal with the post... 383 related parts & labor: Crankshaft...................................$200.00 400 Balancer (used)........................$30.00 Balance job..................................$200.00 Cut con rods for cam clearance.........$20.00 400 flywheel...................................$30.00 clearance block for con rod clearance..$15.00 ARP con rod bolts.............................$38.00 Oil pumpdrive....................................$8.00 Oil pumpsump....................................$9.00 "Performance engine Kit: Sealed power moly rings, Fel pro gaskets, con rod bearings, main bearings, cam bearings, block plugs, 383 pistons, three piece timing set, oil pump"........$317.00 R&R block plugs................................$10.00 degrease block.................................$35.00 deck block......................................$50.00 bore & deck-plate hone cyl(s).............$80.00 deck-plate charge.............................$10.00 "Remove, install, & fit cam bearings "....$25.00 Recon con rods.................................$80.00 Pin fit new pistons.............................$28.00 Assemble short block..........................$75.00 Sales tax.........................................$26.13 .................................................$1,286.13 How does that ad go? New 383 for your 4x4: $1300 Knowing the guy with the crate engine got way less engine for $1500, Priceless.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
02-20-2006, 02:33 PM | #30 |
I just dropped my block, crank off at machine shop. Machine work and rebuild kit cost me $590. That's with a mild cam setup. I have $200 in my heads and $250 on carb and intake. I'll probably spend another $100 on misc. So I'm looking at $1140 plus time. The factor in the fact I know what I have in the engine, the enjoyment od bulding(priceless) and the pride in saying "I built it". That would equal -$5325.62. So I actually make money on the deal.
See how I rationalize. It works! JKR
****Have you ever danced with the devil in the pale moonlight....I ask that of all my prey**** 68' C10 Short Step (rebuilding as we speak) 72' Custom Camper (wrecked, parting out) 79' C10 Fleet (rough, parting out) 97' C1500 Short Step Custom (DD) 97' Kawaski VN800a Customized 99' Z71 Silverado 04' Suzuki Volusia |
02-20-2006, 03:25 PM | #31 | |
02-21-2006, 10:47 PM | #32 |
laying low
I, for example, have an 88 350 truck engine in need of a rebuild. I already have a Performer intake and carb on it. I am wondering if I can perk that one up to maybe 300 or so HP without spending another $1000 for heads and such. Would 9 to 1 cr with Vortec heads and an rv cam do it? What is a good price to pay for a set of useable Vortecs? Or a pair of older Vette heads?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
02-22-2006, 09:38 AM | #33 | |
http://www.sdpc2000.com/catalog/2172...-Head-Kits.htm
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
