Old 03-12-2006, 10:11 PM   #26
Draggin79
Draggin79's Avatar
Re: New member, 79 inside w/ pics!
any of you have some problems when fitting the notch, due to the frame changing dimensions? also where the old shock mounts were on the frame, kinda screws things up.
Draggin79 is offline   Reply With Quote
Old 03-15-2006, 07:32 PM   #27
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Your notches look good.
As far as the shock mounts go, maybe you can fill them before welding the notch in. Since the width of the framerails change with maybe you can weld in a filler strip the width of the wider frame areas to make up for the narrow portions of the rails.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
