03-09-2006, 10:58 PM | #26 | |
Re: Has anyone used a set of 6" rear lowering springs?
03-09-2006, 11:02 PM | #27 |
She's a 60 or 70-footer right now, but everything under the sheetmetal is new. I almost don't want to do the body work and paint, i might be scared to drive it after that.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
03-10-2006, 11:12 AM | #28 |
Steven, your truck sits exactly the way I want my blazer to sit. How hard was the c-notch? Did you pull the bed to do it?
Thanks, Rg (jkade, sorry for the hi-jack, I'll give you one free hi-jack of any thread I start...)
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
03-10-2006, 02:55 PM | #29 |
C10 Club Tennessee
So let me get this straight-Do you have to c-notch when you lower a blazer 6 inches in the rear?
I don't own a 2wd, but may in the near future
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
03-10-2006, 03:10 PM | #30 |
Yellow69, I have a 6" drop with NO c-notch. Anything greater then 6" will need a c-notch.
Rg
03-10-2006, 04:09 PM | #31 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
03-10-2006, 06:23 PM | #32 |
Roger, I did pull the bed to do my c-notch. The bolt-in c-notch has like 5 steps on the intructions, HA... That thing was a pain to put in. You have to grind rivets out (the worst part of the install), cut out the portion of the frame, then when you get it all going back together at least 2 of the bolts were too long (they were hitting the crossmember behind the axle.) And in the end it basically puts a spacer between the top of your springs and the frame. I'm thinking about welding mine in because I think I want it to be a little stronger so I don't get nervous the next time I go to tow something. If I had it to do over again, I would bypass the bolt-in notch and make my own out of some pipe, then box in the frame right there.
If you do go with the bolt-in, I know that it can be done without removing the tub on a Blazer, but it has to be a pain in the @ss.
03-11-2006, 03:00 PM | #33 |
Thanks Steve, I'm thinking I should make my own and weld it in also.
Rg
