03-07-2006, 09:40 PM | #1 |
Has anyone used a set of 6" rear lowering springs?
I ordered a set but haven't got them yet. I took the springs out today and put the wheels and tires back on. It is sitting on the frame but that is were it needs to be. I also ordered a c notch kit to help with the clearing issue. Were will the 6" springs set it? Anybody got some pics? I am running a 295/40/20 rear tire.
03-07-2006, 09:43 PM | #2 | |
The LuvShack Garage
Re: Has anyone used a set of 6" rear lowering springs?
WOW, I want pic's when they are installed, I am also gonna run 20's on the rear of my 2wd Blazer, I am gonna c-notch and do bags, but that is later on down the road, I might get a set also if it looks good, btw, a couple of ???'s How wide are your 20's, and what is the BS? and is it c-notched or not?
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
03-07-2006, 10:04 PM | #3 | |
03-07-2006, 10:06 PM | #4 |
The LuvShack Garage
Thanks for the info, I also want to run a 20 x 10 out back, what are you
running up front? I am considering a 18 x 8, may have to be 18 x 7 (bags)
03-07-2006, 10:38 PM | #5 | |
03-07-2006, 10:41 PM | #6 |
The LuvShack Garage
Do you have any pic's of your rig as it sits ???
03-07-2006, 10:56 PM | #7 | |
03-07-2006, 10:58 PM | #8 |
The LuvShack Garage
I got your tire sizes, when you measure your BS for me would you also
get me your tire height from the ground to the top edge of the thread.
03-07-2006, 11:05 PM | #9 | |
Thanks, Kade |
03-07-2006, 11:07 PM | #10 |
The LuvShack Garage
Thanks Kade, no mini tub for me, w/ the air ride and c-notch she is gonna
bottom out pretty hard, grabbing meat is not really an issue w/ her, cya
03-07-2006, 11:15 PM | #11 | |
WTB this ad
http://www.1010tires.com/TireSizeCalculator.asp |
03-07-2006, 11:37 PM | #12 |
The rake of it (and the Blazer) looks great the way it is but I bet it handles funny.
Shane
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
03-07-2006, 11:42 PM | #13 | |
03-07-2006, 11:46 PM | #14 |
The LuvShack Garage
I like that pic, so that has been lowered a lil since the top pic?
03-08-2006, 08:41 PM | #15 | |
[ATTACH][ATTACH][ATTACH][/ATTACH][/ATTACH][/ATTACH]
03-08-2006, 09:02 PM | #16 |
The LuvShack Garage
So what is the total drop? 6 out back and ? out front
03-08-2006, 09:44 PM | #17 | |
03-08-2006, 09:53 PM | #18 |
The LuvShack Garage
So up front it's 2.5 spindles and -1 coil on the coils or about 4"
03-08-2006, 10:16 PM | #19 | |
03-09-2006, 01:48 PM | #20 |
I don't think 6" springs will get you there. I have 4' with 2" blocks for a total of 6" and I don't have a c-notch and have NEVER bottomed out. With the 6" drop I still have between 1.5"-2.00" before the axle would hit the frame.
Here's a pic below. I think if you want to go as low as you show in the pic you will need a 6" spring, c-notch and a block (or go with an airbag setup). Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
03-09-2006, 04:49 PM | #21 |
The LuvShack Garage
So what is that drop a 4/6, 5/7, 6/8 on yours Roger
03-09-2006, 05:38 PM | #22 |
Mine is actually a 3/6. I need to go down more in the front and I have plans on putting 17's or 18's on it. Well, I REALLY need to put it on bags, I really like the 2wd's down low, I think I'm about as low as I could get without the c-notch. When I go to bigger wheels I will be notching it... ohhh, it never ends....
Rg
03-09-2006, 08:41 PM | #23 | |
03-09-2006, 09:39 PM | #24 | |
The LuvShack Garage
03-09-2006, 10:36 PM | #25 |
On my 70 truck, I used ECE's 6" drop springs with a 2" block and bolt-in c-notch. The axle tubes sit right in the opening of the notch, right at the bottom of the old frame. My back tires are almost exactly 29" tall. I know it's not a blazer but....
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
