Old 04-22-2006, 07:41 PM   #26
kevncar
Active Member
kevncar's Avatar
Re: 67 SWB build thread
Managed to spend a little time on the truck today. Mocked up the power steering box to get ready to dimple the frame. I also notched the frame to accept the motor mount towers. I'll smooth out the cuts more once I mock up the motor and see what kind of clearance I'll need for the headers. I tried to take some good pictures of the frame before clearancing for the PS box and how some talked of the box hitting the radiator support bracket. I clipped the corner off the bracket to clear.
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 04-22-2006, 09:10 PM   #27
Deuce
Deuce's Avatar
I was told when cutting a frame to drill holes on the corners to prevent the 90* cuts from cracking?? Don't know if it's true but it makes sense?? Get the new parts installed and post some more pics!!
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 04-22-2006, 10:19 PM   #28
Frankentruck
You are absolutely correct. A frame builder taught me that many years ago. He always recommended when possible to drill holes at your corners then make the cuts. You can always clean up the cuts with a grinder.
In the case where the cuts have already been made a carbide bit in a die grinder will make quick work of a 90* corner.
1971 C-10 SWB
408 SBM Stroker
TKO 5 Speed with road race ratios
Setting the suspension up for the twisties.
Frankentruck is offline   Reply With Quote
Old 04-22-2006, 11:20 PM   #29
byrd
Union Electrician
byrd's Avatar
Where did you get the sanding disc, are you using air or electric grinder?
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 04-23-2006, 01:59 AM   #30
kevncar
Active Member
kevncar's Avatar
I actually work in the structural steel industry (buildings) and you are absolutely correct about the corners. If made to a corner, it's a excellent place for a crack to start. I actually didn't cut all the way to the corner. I cut just short of it and then grinded a very tight radius in the corner. It doesn't really matter though. I am just trying to get the motor in so I can see what else is going to need to be narrowed for header clearance and things. I plan on cutting much more out, more like the smooth arched cut the factory put in the 68-72s. The 67 frames don't have the narrowed frame.
As for grinding discs, the majority of the cleaning was done with a "Sandblaster" grinding wheel that I bought at Lowe's which fits on my 4-1/2" angle grinder. (electric)
Works great and seems to be lasting a very long time considering the really sharp edged stuff I've been cleaning. I've heard claims you can strip an enitre car with one of these things. I think it's quite possible.
As for cutting and aggressive grinding, it's stuff a buddy gave me, a cut-off disc and some kind of metal grinding disc.
Kevin
72 Chevelle
67 C10...454/TH400
Old 04-23-2006, 03:17 AM   #31
Flat 67
Junior Member
Flat 67's Avatar
Originally posted by Kevncar.
I now have the bed and front clip off, and am debating taking the cab off. If I could find a good big window cab, it's coming off in a heartbeat. The 350 and four speed have been pulled and sold and I have a 454/TH400 to replace them with.
Kevncar,
Are you still looking for a big window cab? I saw one in a junkyard today and it's only a few miles down the road from where you are........Flat 67
Flat 67 is offline   Reply With Quote
Old 04-23-2006, 10:21 AM   #32
Hart_Rod
Hart_Rod's Avatar
Good thread, keep the pics coming!
Hart_Rod is offline   Reply With Quote
Old 04-23-2006, 10:50 AM   #33
LONGHAIR
Before you get much more intense............it would be a very good idea to put an empty block on those mounts. Modifications like that can bite you if you don't check things as you go..............do ask me how I know this.
I probably would have tried it before even cutting what you have
LONGHAIR is offline   Reply With Quote
Old 04-24-2006, 01:28 AM   #34
kevncar
Active Member
kevncar's Avatar
Thanks for the heads up longhair. That's exactly what I'm getting to. I just got those mounts in and now I need to get the manual trans crossmember out, and I'm going to drop the motor and tranny in and see how everything fits. The thing about the cuts that I've made is...I'd have to cut the frame even if I went with the stock BB mounts. If you look at any 68 and later frame, the top flange is narrowed already. They didn't do that on the 67s. I plan on making the cuts more like the factory cuts later, after I know how much I need to take out for header clearance and everything. See the following picture for an example of the factory cut.
Flat67, hit me with a PM on the cab, I'm still looking. What year was it? I think I have a guy locally here on the hook, but you never know. Thanks
Kevin
72 Chevelle
67 C10...454/TH400
Old 04-29-2006, 07:21 PM   #35
Flat 67
Junior Member
Flat 67's Avatar
Kevncar......check your PM's for a good deal on a cab.
Flat 67
Old 04-29-2006, 08:19 PM   #36
67_CST
I agree that the small window is worth keeping. It was a one year only feature and looks really "vintage" to me. Heck, I looked for several years to find a decent small window cab so that I could build my "dream 67". I finally found a solid small window cab and it is just awaiting the rest of the parts now.
67_CST is offline   Reply With Quote
Old 09-29-2007, 09:24 PM   #37
67Step
67Step's Avatar
How did you dimple the frame for the power steering pump?
1970 Chevy Stepside, 350/ 350 Turbo
1967 Chevy Shortbed, 454 CI, 700R4, currently work in progress. Check out the build up at http://www.cardomain.com/ride/2933497/1.
http://67-72chevytrucks.com/vboard/s...d.php?t=264458
1957 Chevy 3100 Stepside Truck. All original for now.
67Step is offline   Reply With Quote
Old 09-30-2007, 07:10 PM   #38
kevncar
Active Member
kevncar's Avatar
A buddy came over with his torch and we heated the frame and bumped it out with a hammer and dolly. It isn't the prettiest, but the box is on there.
Kevin
72 Chevelle
67 C10...454/TH400
Old 09-30-2007, 07:37 PM   #39
I moved this to our build area for you. Glad you are making progress withit.
Old 10-06-2007, 09:50 AM   #40
sergio rios
whats wrong with the small window,,,they are cool i got one too i love it..........
meloyelo
sergio rios is offline   Reply With Quote
Old 03-06-2010, 08:22 PM   #41
kevncar
Active Member
kevncar's Avatar
Kevin
72 Chevelle
67 C10...454/TH400
Old 03-06-2010, 08:31 PM   #42
kevncar
Active Member
kevncar's Avatar
Kevin
72 Chevelle
67 C10...454/TH400
Old 04-11-2010, 07:48 PM   #43
67chevy1series
67chevy1series's Avatar
hey i didnt no you had a thread or was amember of 67 72 chevy/gmc .com i used to live real close by it was vann terrace st on the corner my dad had a 68 chevy burb and has a 70 chevy 4by4 used to be a flat bed but we moved i used to see ur 67 around until you started progress now im doing a 67 to swb fleet
67chevy1series is offline   Reply With Quote
Old 05-03-2010, 02:30 PM   #44
Newtz67
Newtz67's Avatar
Hey where you been? Time to get that truck on the road! Haha. I've learned a lot from your thread concerning the motor mounts! Thanks!
Newtz67 is offline   Reply With Quote
Old 09-30-2010, 05:59 PM   #45
67chevy1series
x2
