#26 |
River life......
Re: What oil filter are you using?
I run NAPA gold/silvers in my DD (tacomas) I will run the same in my jimmy after the first oil change.
#27 |
Active Member
We run NAPA gold on all the company trucks as well as my own, only problem I've had is when I get dyslexic with the numbers and get the wrong one!
Never try to teach a pig to sing; it wastes your time and annoys the pig! ![]() ![]() My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
#28 |
I run nothing but k&N oil filters. I also block the bypass fitting the filter screws to. This way the oil has to go thru the filter. I run mobil 1 15/50 full synthetic oil. The engine is a BBC 496. Oil pump was bluprinted and all clearances brought to min spec. when eng fires up i have 70psi oil pressure when engine reaches 180 degrees f it stays right at 50-55 psi hot and idling in gear. The k&N filters are pricey but i have had the cheap filters blow right off of the block or split a seam. I have way to much money invested in the eng to rely on a walmart special.
#29 |
For those with too much time on their hands:
http://minimopar.knizefamily.net/oilfilterstudy.html
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
#30 |
Firefighter
Yes the Wix 51794 is a 2 quart filter that has longer length than the 51061 Wix. AC delco is a PF 932 2 quart
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() Last edited by BLACK AND BLUE 67-72; 03-29-2006 at 05:38 PM. |
