#26 |
its just $$$$$
Re: 72 2wd blazer build
The notch is where the bag mounts, its actually just in front of the axle.
#27 |
Ahhhhh . . ..... I should have looked closer @ the pic. Notched to maintain the same ride height @ a slightly higher air pressure for a better ride?
#28 |
its just $$$$$
This might help.................
#29 |
its just $$$$$
Alright so I FINALLY got my rearend back together and back under the frame. Installed the new urethane bushings in my "custom"
#30 |
its just $$$$$
Here are a couple more, to give you a better view of the tubular trailing arms. You can also see the exhaust passages that I made in the trailing arm crossmember.
#31 |
![]() Join Date: Aug 2005
killer!
#32 |
Happy to be here
![]() Join Date: Mar 2000
Looks good. What ya gonna do for rear brakes?
#33 |
its just $$$$$
I was thinkin about not having any
![]() nah, I have some crossdrilled rotors on order to match the front. |
#34 |
Excellent work, that is going to be one bad ass Blazer.
#35 |
its just $$$$$
I finally got the body back on the frame.
I wanted to coat the bottom of the tub with something that would seal everything and kind of deaden everything a little. I ended up going with Raptor Liner spray in bed liner material. It is a urethane based spray on, I guess time will tell how well it works. It seems nice, I am contemplating coating the inside of the tub as well. The frame is coated with POR 15, the bottom of the tub is bedliner, and it has new poly body mounts, so hopefully it will last a while. You can also see some progress on the firewall in these pics. Last edited by bagged74; 08-13-2006 at 09:55 PM. |
#36 |
Sweeeeeeeeeeeeet!
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#37 |
looks real sweet... great work also...
Meticulous Fabrications Milford Michigan |
#38 |
Happy to be here
Nice going buddy. Keep the progress shots coming. Goodguys is right around the corner...
#39 | |
Village Idiot....
#40 |
its just $$$$$
I made a little more progress. I got the front power steering box and centerlink all installed(it much easier to push around the shop now..lol) I also got the motor mounts and tranny crossmember fabbed up.
I know, I know,.......... I will get some new pics. |
#41 |
look awsome.....
#42 |
Starting to look like a propper 2wd again
![]() Kevin LFD Inc. |
#43 |
very nice work. I need to build a shop in my back yard one day...
#44 |
its just $$$$$
in these pics you can see the the notch in relation to the floor. you can also see the shock mounts. You may also notice that my frame is nasty because it got rained on while it was outside.
#45 |
it looks sweet i need to start one for the progress on mine i am all out of order on my pics i need to go back when i started and get them in order
the work looks great cant wait to see more
http://www.cardomain.com/ride/2461088 |
#46 |
computer illiterate
i sure could use the piece you cut out of the floor
72 2wd blazer 72 swb 4x4 |
#47 |
its just $$$$$
#48 |
outta the car velocityboy
Amazing. That looks so good.
#49 |
computer illiterate
sounds great il pm you my addy for a quote
#50 |
A guy with a truck
Bagged- Got a few questions for you:
- How big is your step notch? standard 8"? Are you using all of it? - I see you have 4x4s on the axle to roll around; how close is the pinch weld from touching the ground if you pull them out and dump the front? - How high does the notch protrude into the bed area? What are your plans for it? Back seat? Thanks -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
