its just $$$$$
72 2wd blazer build
This is my thread to cover the build of my 72 2wd blazer. I purchased this Blazer from a board member in the Dallas area early this year. It was in a general state of disrepair. It hadn't been driven in some time. The interior was non-existent, and what was there was not correct for the truck.
I was happy to get it none the less. heres what she looked like when I picked her up Last edited by bagged74; 06-06-2006 at 12:22 AM. |
its just $$$$$
Re: 72 2wd blazer build
I got it roadworthy and started driving in a little. I put on a new set of tires and did some minor mechanical repair. Then I decided it was time for an altitude adjustment. I got some 3" drop spindles and cut a coil off the front springs. The guy that I bought the blazer from gave me some drop springs for the rear so I put those in also.
its just $$$$$
Of course after I got it lowered I had to get some bling on there. I got a good deal on some 20" Coys Rodders and Falken tires. The fit is not perfect, but the looked better than the rally wheels that were on it before.
I also added a flushmount fuel filler door because I cant stand the look of the gas cap on the quarter panel. |
its just $$$$$
The truck was originally a low option 6cyl/3 spd truck. Somewhere along the line it had been converted to a 350/4spd. The 350 runs good, but the Saginaw 4spd is a little noisy. I guess that doesnt matter though since it is now sitting in the shop floor. This is what she looked liek under the hood when I got it.
its just $$$$$
Soon after i got to this point I decided to tear it down to fix the rockers and patch a couple of places in the floor. Well this got a little out of hand and the body is now on the rotisserie. I have sandblasted the whole underside of the tub. I also sandblasted the windshield frame and dash for good measure. I put some epoxy primer on it today. I will get some pics of this up soon.
its just $$$$$
Well the poor old frame was needing some attention. I used about 6 cans of over cleaner and several hours with the pressure washer to get it this clean. Sandblasting will clean it up nicely though.
FUEL CELL GURU
Lookin' sweet. What is wrong with the fit of the wheels??
its just $$$$$
too much backspacing on the rear. they are too far up under the fender for me. It fits perfect on the front though.
FUEL CELL GURU
http://www.ezaccessory.com/Wheel_Ada.../5500-5500.htm
I used these on the back of my Blazer. I had the same problem. I used the 1.5" version. VERY well made. Would be cheaper than a new set of wheels and just as safe. Later, mark |
Happy to be here
![]() Join Date: Mar 2000
Progress is good. Keep it up buddy...
Village Idiot....
Glad to see you step off the deep end
#12 | |
Outlandish Trends - FL
-Bret 67 short-fleet sold! |
#13 |
its just $$$$$
I really wanted to get the stance right on this one. Its pretty easy to get the front down low, but the back is always a pain. I knew a bolt in notch or a regular "c notch" wasnt going to cut it. I bought an 8pc step notch kit and proceded to bend and cut it to fit the contours of the rear frame. I know some of you "original" guys are probably gonna throw rocks at me......but I did cut a big hunk out of a factory 2wd frame.
Once I got the notch in I ran into another problem.......trailing arms hitting the frame. Luckily I had 10ft of 2x3 1/4" wall tubing, so I made some new trailing arms. This still did not completely fix the situation in the rear. I didnt want to mount the bags over or in front of the axle because I have dreams of having some sort of exhaust system in that area. so I decided to notch the trailing arms for the bag mounts. this gave me the clearance I needed and let me mount the bag approximately in the stock spring location. Last edited by bagged74; 07-02-2006 at 10:07 PM. |
#14 |
its just $$$$$
This leaves me with the frame sitting level at 2.5" off the ground. I really want it a tad lower in the front so.........now I have to decide if I want to section the crossmember, or Z the frame, or leave it alone.
#15 |
Wow, that is gonna be one sick little Blazer once it's done. I've had 3 Blazers but all 4X4's, always a soft spot in my heart for those 2wd Blazers. Keep on posting pics, no matter how insignificant you may think they are
![]() Wish I had the funds and the lower back (blown L5/S1) to do my 69 that way...Little bit at a time I guess. ![]() Mike |
#16 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Sweet Progress!
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#17 |
any new progress...looks tits man keep up the awsome work...
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
#18 |
its just $$$$$
I turned the frame upside down tonight and finished the welding. I also made some exhaust passages in the trailing arm crossmember. Tomorrow I will start painting some stuff. And I promise to take some new pics.
#19 |
Any luck on the pics of your rotisserie for me?
#20 |
its just $$$$$
Dang man, Im sorry I completely forgot. I will take some tomorrow. I been running like
#21 |
No problem, also how did you clean up the bottom side of the Blazer, sand blast or just sanded everything?
#22 |
its just $$$$$
sand blasting is the only way to go. I did the whole bottom side in about 1.5 hrs.
#23 |
its just $$$$$
Progress has been slow. Between work, trying to spend a little time with the family and the dang HOT weather I havent gotten much done lately. I have everything painted and the front suspension put back together. I found some carnage inside the rearend so now that is setting me back a little.
Here are a couple of pics my new front rotors and the trailing arms that I built. |
#24 |
Looks good, keep the pics coming. Thanks for the pics by the way!
#25 |
What's the reason for the 'notch' where the rear-end would be positioned?
