#26 |
Re: unusual options
Yeah,I went through that on my old`70 CustomCamper/30 when I put chrome Budds on it.
#27 |
Re: unusual options
SLOMO, please correct me if i'm wrong here but is that a factory 3/4 shortbed with coil spring rear chassis? Dana60?
1967 K30 Napco 292/SM420 original paint 30k miles 1968 K60 Napco 396/5spd. dbl frame 52" michelins 1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks 1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr 1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison. |
#28 |
Old Duffer
![]() Join Date: Mar 2003
Re: unusual options
Yesser, it has the rack body (9 1/2') and the single leaf over-load spring on each side. I bagged the rear, but left the over-loads on in case I lost a bag. That way it would settle to the over-load, but I could still drive it home.
I'm thinking it's the Dana 60 (round cover, and you have to remove the axle to service the brakes,) but I have yet to find an identifier on it. When I changed the bearings I had the old ones in-hand, and the shop measured them to order the new ones.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
#29 |
its all about the +6 inches
Re: unusual options
That's an Eaton, on one of the photos, (bare frame in back) if you look real carefull, you can see one of the bolts that holds the third member into the housing. Dana isn't like that.
slomotion, short bed?? What's the wheelbase on that? |
#30 |
Old Duffer
Re: unusual options
Longhorn, you may very well be right about the third member, I don't know. There's a ring of bolts on the forward side of the pig to take out the ring and pinion, and there's a ring of bolts on the back-side to take off the back cover. All I know for sure is, it's a gaummy son of a gun!
The wheel base is 127" which is only 6-7" longer than my '80 short-step. The only reason I refer to it as a short bed is because every other rack body I've compared it to has been longer and this one hasn't been shortened. Later
