Old 12-21-2006, 07:17 PM   #26
Shane
Shane's Avatar
Re: laying frame question
Ya might want to address those sharp edges on those weld beads so close to the bag. That's a puncture looking for a place to happen.
Shane is offline   Reply With Quote
Old 12-21-2006, 09:05 PM   #27
pharcyde05
pharcyde05's Avatar
AHHH i understand
and i ment that that i wasent changing the bottom of the lower arm by more than 3/8 in
and buy zing the frame that adds some of the ground clearance back hear is another view
now that makes the lowest part the frame rails
(that rusty pice of metal is just there temp holding the trans up till i get the crossmember in there )
pharcyde05 is offline   Reply With Quote
Old 01-02-2007, 12:57 AM   #28
bskylerj
bskylerj's Avatar
Originally Posted by pharcyde05 View Post
the z is only 2.5 in had to do some work with crossmembers and frame rails to get rocker down and had to notch for trailing arms
and the bottoms of the lower a arms were droped so the bag would sit down into the arm
Will you have to modify your inner fenders and how much into the bed?
bskylerj is offline   Reply With Quote
Old 01-03-2007, 05:01 PM   #29
pharcyde05
pharcyde05's Avatar
yes the inner fenders are removed and the fender has to be trined also depending on tire size it may also require hood hinge relocation
there are differant ways to do bed some just tub and raise what needs to be raised
i raised the entire bed floor and rear fender wells
Old 01-03-2007, 06:21 PM   #30
Kevin45
Kevin45's Avatar
Hey Pharcyde05....you had better get that brake line changed around. It's got quite a bit of strain on it. They don't like to bend 90 degrees too many times.
Kevin
'93 Silverado Reg. Cab Shortbox
.060 over 350 Quick and fun!!!
Kevin45 is offline   Reply With Quote
