laying frame question
I just z'd my 71 C-20 4 inchs in the front, and plan on bagging it all around. Assuming I run a 27 or 28 inch tire, will I lay frame without drop spindles? I am trying to keep my 8 lug wheels and I am unable to find drop spindles for this application
Thanks Andy |
Re: laying frame question
i zed my 85 4 inchs up front but also running 29 inch tires with 3 inch drop spindels so u might have to get them unless u run a smaller tire
thanks, I guess I will still hunt for spindles then
It'd be alot cooler if you did
It will be close but I don't think it will lay out.
this is a pick of 69 with stock spin zd 2.5 in on 29 in tire
http://www.cardomain.com/ride/2461088 |
Is that layed out? it is hard to tell from that angle
it lays all the way it teaters on the crossmember i have to cut that down a lil it should be able to lay 20s with 30 ser tires as it is but once i put the drop spin on it it will lay out on 22s
Z'd 2.5 and you layin rocker?? or is that pic deceiving.
the z is only 2.5 in had to do some work with crossmembers and frame rails to get rocker down and had to notch for trailing arms
and the bottoms of the lower a arms were droped so the bag would sit down into the arm
Got any pics of the lower control arms?
the wheels and tires that ar silver are a smaller diam when i put the black 17 with same diam of 20s i was going to run it raised it up about 1/4 in from laying all the way out so now i am going with drop spin to get back down and hopefully be able to lay out on 22s
#13 |
Outlandish Trends - FL
Wow, neat idea. So you cut out the spring pocket of the LCA, lowered it and then re-welded it back together? Do you have any more pics of that? Sounds like an inexpensive way to gain an inch or so.
![]() By the way, I'm diggin' that yellow. ![]()
-Bret 67 short-fleet sold! |
#14 |
this is the only one i have on computer but i can get some more for you and show more detail its prety much the same idea as putting in droped lower arms
#15 |
Early Classic Ent. Sells 3/4 ton drop spindles.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#16 |
they convert it to 6 lug though (at least thats what the saleman said to me) I am trying to retain 8 lug, there is one place that sells them but they said if i run a wider then stock wheel the spindle may break, thats not the kind of quality i'm looking for. I am going to bag it first and see where she sits. I may just modify the control arm also
#17 |
Señor Member
The real benefit of doing this is that you get a "squared" bag setup. There's only a small benefit to the actual drop since, when you lower the pocket, you're just reducing your ground clearance. Very quickly, the ground clearance problem outweighs the drop you get from the bag mount being lower.
#18 |
there is only a 3/8 plate welded on bottom of a arm so at the most only 3/8 inch of ground clearance is lost but being in same line as wheel there is prety much no way possable for the lower arm to hit ground especial with z in frame cause that raises cross member and lower arms for clearance and makes fram rails the next lowest part of truck besides driveline hoop in center crossmember hear is a pic laied out and you can see nothing sticks below a arm where plated
#19 |
eBay home | Pay | Register | Sign in | Site Map | Community | Help
Search eBay Motors Advanced Search Back to list of items Listed in category: eBay Motors > Parts & Accessories > Car & Truck Parts > Suspension & Steering > Lower Kits & Parts 1973 - 1991 CHEVY C20,C30,C35 SPINDLE DROP 3" Item number: 7964053784 Buyer or seller of this item? Sign in for your status Watch this item in My eBay | Email to a friend View larger picture price: US $229.95 No payments for up to 6 months ? Apply -------------------------------------------------------------------------------- Shipping costs: US $40.00 Other (see description) Service to United States Ships to: United States, Canada Item location: Phoenix, AZ, United States Quantity: 7 available History: Purchases -------------------------------------------------------------------------------- You can also: Email to a friend | Sell one like this Listing and payment details: HideShow Payment methods: PayPal, Money order/Cashiers check See details Meet the seller Seller: www-slammerskustoms-com( 162) Feedback: 98.8% Positive Member: since Dec-31-04 in United States Read feedback comments Ask seller a question Add to Favorite Sellers View seller's other items: Store | List Visit seller's Store: Slammers Kustoms Contact the seller instantly Buy safely 1. Check the seller's reputation Score: 162 | 98.8% Positive Read feedback comments 2. Learn how you are protected Shop without sharing your financial details Learn more Description (revised) Slammers Kustoms Visit my eBay Store:Slammers Kustoms Search my eBay Store: Fits 73-91 C20,C 30, C35 P/U. Most applications cast at BELL FOUNDRY Los Angeles. USE DROP SPINDLES ON STANDARD O.E. OFFSET WHEELS ONLY. Spindles are new. Will give you a 3" in. drop in front. 2wd only. 8 Hole lug pattern. -------------------------------------------------------------------------------- On Apr-17-05 at 22:12:16 PDT, seller added the following information: Spindles may interfere with stock wheel and tire combo. If so larger wheel and tire combo will be needed or modifications to suspension may be needed. -------------------------------------------------------------------------------- On May-19-05 at 11:53:13 PDT, seller added the following information: Must specify bolt on or clip on rotor assy when ordering. -------------------------------------------------------------------------------- FREE Counters and Services from Andale Shipping, payment details and return policy Ships to United States, Canada Country: Show all available Shipping and Handling Each Additional Item To Service US $40.00 + $40.00 United States Other (see description) Country: Show all availableUnited States Quantity: Shipping and Handling Each Additional Item To Service US $40.00 + $40.00 United States Other (see description) -------------------------------------------------------------------------------- Shipping insurance Not offered -------------------------------------------------------------------------------- Seller's payment instructions Upon receipt of payment item will be shipped within 48 hours. Shipping price includes handling charge and is non-negotiable. Not responsible for lost, stolen, or damaged items. No return policy! Please allow 7-10 days for delivery. Prices subject to change without notice. -------------------------------------------------------------------------------- Sales tax Seller charges sales tax for items shipped to: AZ* (8.100%). * Tax applies to subtotal + S&H for these states only Payment methods accepted Money order/Cashiers check Ready to buy? help 1973 - 1991 CHEVY C20,C30,C35 SPINDLE DROP 3" price: US $229.95 Your Quantity: x You will confirm in the next step. Purchase this item now without bidding. Learn about Buy It Now. What else can you do? Back to list of items | Ask seller a question | Report this item | Printer Version Seller assumes all responsibility for listing this item. About eBay | Announcements | Security Center | Buyer Services & Protection | Policies | Site Map | Help Copyright © 1995-2006 eBay Inc. All Rights Reserved. Designated trademarks and brands are the property of their respective owners. Use of this Web site constitutes acceptance of the eBay User Agreement and Privacy Policy. |
#20 |
sorry for such long post .im technologically stupid but theyr supposed to fit your 8 lug rotors
#21 |
its states standard offset only, they are most likely the same as the ones I found. If a spindle can't take a positive or negative offset and its suppose to be a 3/4 ton spindle, the manufacter is making an inferior product in my opinion I rather not lay frame then put on a possible future failure
#22 |
i wasnt sure what the deal was with them i was just "shopping" and thought id pass the find along
#23 |
I appreciate the gesture, thanks. If you run into anything else, please let me know The search will continue
#24 |
hear are some closer views of the lower arms
#25 | |
Señor Member
Note also that the LCA is not "in same line as wheel" as you indicate above. The picture you posted indicates otherwise.
