#26 |
![]() Join Date: Jul 2006
Re: Ididit column vs stock
All other BS aside, I bought the bare steel floor shift IDIDIT tilt column... I didn't want the hassle of finding a DECENT on that would still need some work and then the pain of sanding it down, and, and,and...
IDIDIT tells you right on their site that they use alot of refurbed parts on their columns...I don't care...the have a gret reputation for quality and all the hassle it saved my was worth the $300 I paid..Plus it comes with the billet dress up kit. I like the look of the painted column anyhow so it worked out that the one that worked bes for me was the cheapest one ...
Project Family Values Build Thread Vehicles/Projects: -1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon... Pleasure in the job puts perfection in the work. -Aristotle |
#27 |
Wow, there sure is a lot of money being poured into these trucks.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. Last edited by Southpa; 12-22-2006 at 05:52 AM. |
#28 |
Designated A-hole!
![]() ***Disclaimer*** This is all my opinion and not meant to stir anything up. ![]()
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#29 | |
Questionable
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#30 |
Questionable
PS - talk to member PICKMUP, $649 sounds awful expensive. See what kinda prices he's got. I know the ones with the column shift are more pricey, but ... $649 sounds way too pricey.
#31 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#32 |
"Trucks with Class"
Send me a PM and I will give you much better prices on the ones I still have "in stock". I still have a couple. New replacements will cost me more as price increases are showing up from all manufacturers on metal & plastic parts.
I have a lot of these built and have some really good prices. |
#33 |
Good timming as I was just thinking I need to get my column in order for mock up. My question is what are you guys doing for auto column trany linkage. I am running a 700R4 AOD and want a cable type set up if it is out their. My 3/4 length headers and 3" exhaust get in the way of teh stock rod set up. Also what about the shift indicator for AOD's? Right now I have a van tilt that when last used (7yrs ago ) worked fine but I am not set on using it. But I do want a painted column not polished.
Any cable linkage kits out their? Thanks Kevin LFD Inc. |
#34 |
lokar has a cable setup
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 12-24-2006 at 02:29 AM. |
#35 |
Nice, is anyone running this on their truck? Any feed back as to wow well it work's or adjusts for the detents? Now what about a shift inticator for a 4spd AOD?
Thanks Kevin EDIT~~ I went to their site and they also have a solid rod set up that might work as well for our trucks and their shift indicators are all LED type. I want to find a column mount that looks stock but has all 4 forward gears. Last edited by Rokcrln; 12-24-2006 at 11:54 AM. |
#36 |
Questionable
I love Lokar products. Everything I've ever bought from them was nothing but top quality. I can't comment on that product shove, but I have no doubt that it is kickass.
#37 | |
Digging up an old thread....
I have Lokar's solid rod setup. Its works, but I still haven't got it adjusted where the trans detents are the same as the ones in the column. I might try the cable setup next, or just buy a floor shifter....
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
