Old 12-19-2006, 12:34 AM   #1
skokie
skokie's Avatar
Ididit column vs stock
I am looking at tilt columns and have made a call to Ididit. Im looking at $ 650
for a column that is 3 inches shorter than the stock one so I would not have to collapse the intermediate shaft and that price includes moving the neutral safety switch as well or for $ 450 I can get a rebuilt stock tilt.
What do you guys think?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 12-19-2006, 01:39 AM   #2
Fastfun
Fastfun's Avatar
Re: Ididit column vs stock
I went with a stock rebuilt tilt column that I purchased for $350.00 at the Pamona swap meet. I couldn't justify the cost of Ididit or Flaming River tilts.
Fastfun is offline   Reply With Quote
Old 12-19-2006, 02:26 AM   #3
shifty
Questionable
shifty's Avatar
I just spent around $450 total at Summit for two new Borgeson joints to replace the rag joints, a new DD bar to replace my mushy intermediate shaft and a universal Flaming River tilt column (tilt+telescope is $200 more). That's $100 more for mine than Fastfun paid for just a tilt column using the same old POS crappy rad joint and intermediate shaft. I paid less for my column than his (unpolished, needs paint, but ... I can get rattle can in my stock paint code for $30 online)
There was a big writeup on either CT or CCT magazine this month about how to replace your sloppy ragjoint setup in our trucks (1975, but it still applies) with an aftermarket column. What would you rather have? stock rebuilt, outdated, sloppy ... or nice, new, tight steering?
It's your call.
I have part numbers if you need them.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 12-19-2006, 02:44 AM   #4
brak
brak's Avatar
Flaming river tilt column is only $300 (non polished) for our trucks...
I'm lookin at them right now
I have a tilt column i just pulled from my truck, and will sell it to you cheap.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 12-19-2006, 03:08 AM   #5
ClassicRedneck05
ClassicRedneck05's Avatar
how much u sellin send PM
ClassicRedneck05 is offline   Reply With Quote
Old 12-19-2006, 03:12 AM   #6
shifty
Questionable
shifty's Avatar
Aftermarket columns are cheaper than rebuilds anymore, and the internals like the singal terminators ands tuff last a hell of a lot longer.
Old 12-19-2006, 12:29 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i like my $25 van unit, i hr of labor to modify it, and a $3 can of paint... but I'm a cheap b@stard.
Old 12-19-2006, 01:46 PM   #8
Hart_Rod
Hart_Rod's Avatar
It's your call.
Part #'s please, thanks.
Hart_Rod is offline   Reply With Quote
Old 12-19-2006, 01:55 PM   #9
cdowns
cdowns's Avatar
really not much differance in any of the columns as long as when you turn right the truck doesn't go left
Old 12-19-2006, 01:56 PM   #10
skchevota
skchevota's Avatar
It's your call.
Did you make a new colapsable slip joint on your new intermintent shaft.
If you dont have one and get in a major front collision you could be takeing your steering wheel in the chest!
skchevota is offline   Reply With Quote
Old 12-19-2006, 02:26 PM   #11
shifty
Questionable
shifty's Avatar
Flaming River makes a collapsible column if you want it. It's ~$155 more than the standard tilt column (~$325 standard, $475 collapsible?)
But this is the reality: Stock intermediate shaft is collapsible because the column is stationary (bolted to rag joint to everything). With my setup using U-joints, the column will give in one direction or another. All that aside, if I get in a collsion bad enough that the steering box is going to get hit, the steering wheel slamming into my chest is the least of my concerns! I mean, seriously...think about it. These trucks really have no safety features and I still have yet to find a 67-72 in the junkyard that's taken a head-first hit with the steering column rivet is busted (i.e. column collapsed). I understand the feeling of security some might get from it, but .... I just don't think it's necessary (hopefully I never eat my words or my steering wheel).
I guess I look at it like this: In the event of a possible accident, using the aftermarket column, I have more control over my truck to avoide the accident. I'd rather have more control with newer, safer equipment than to have the collapsible column "safety feature"
Old 12-19-2006, 02:32 PM   #12
shifty
Questionable
shifty's Avatar
Flaming river column is part # FR20007 (35" long by 2" diameter?)
This is what member greasemonkey shared, and I bought:
The shaft from the column is a 1" DD shaft, the intermediate shaft is 3/4" DD, and the steering box is 3/4" 36 spline. So you need two ujoints: 1" DD to 3/4" DD, and 3/4" DD to 3/4" 36 spline. I used one Flaming River ujoint, Summit part # FLA-FR2517DD and one Borgeson joint BRG-013449; I used the Borgeson because the Flaming River joint of 3/4" to 3/4" 36 spline did not fit on my steering box splines (why I don't know, it was just too tight). The shaft was a Flaming River FLA-FR1850, you just cut it to fit. The ujoints are a simple bolt on, no welding needed.
So, all those parts:
Column (1): FR20007
Borgeson (1): FLA-FR2517DD
Borgeson (1): BRG-013449
DD Shaft (1): FLA-FR1850
You might also pick up a copy of Custom Classic Trucks or Classic trucks for their full writeup on this - it's really informative, gives part #'s and explains everything you need to know when measuring and welding, and also covers the perks of swapping to this setup.
The two U-Joints should technically buckle in a collision - if you really want added safety, you can set it up like an aftermarket import and throw in a third U-joint to allow for flex in the case of a collision.
Old 12-19-2006, 04:57 PM   #13
jkaylor68gmc
jkaylor68gmc's Avatar
I have the chrome tilt Retro-Fit column from Ididit in my '68 GMC and it is awesome. it only took about an hour, plugged the wires right in and cut the Borgeson linkage. It worked great. If you have any questions on the install check out the November/December Truck Builder Tech article. I shot the whole install.
jkaylor68gmc is offline   Reply With Quote
Old 12-19-2006, 07:31 PM   #14
jfalesi
Junior Member
If you're talking non-shift columns, yeah, aftermarkets aren't that expensive. But those aftermarket automatics are too rich for my blood. So I bought one of these. Pretty good deal, but backordered.
http://www.brothersonlinestore.com/p...number=RTSC72A
-Jamie
jfalesi is offline   Reply With Quote
Old 12-20-2006, 01:43 AM   #15
brak
brak's Avatar
According to Flaming river, the columns made specifically for our trucks are:
#FR20003 - 35" - Paintable Mill Finish stainless Tilt Column - 1"DD, 1.75" dia.
#FR20003SS - 35" - Polished stainless Column - 1"DD, 1.75" dia.
as found HERE
FR20007 is the universal column, which aparently works fine (as demonstrated by shifty), but for the same price, i think i would go with the vehicle specific one.
Old 12-20-2006, 12:10 PM   #16
shifty
Questionable
shifty's Avatar
as found HERE
Brak - pretty sure the stock column on our trucks is 2" in diameter. The FR column you linked "for our trucks" is 1.75" diameter.
If you look at the details for the part you just linked it also says THAT PART IS UNIVERSAL TOO.
You could go with the vehicle specific one. The vehicle specific one for our trucks was out of stock when I went in, and I wasn't satisfied with the connector (it was flat).
You can criticize me on it all day long, but you know what? I want to go with what WORKS. This worked and was a direct swap-in for another member. I'm doing a swap that's not really typical in my truck, and I am so freaking sick of ordering parts that "should fit" or are "made for my truck" and had them not fit somehow. I wasn't going to go through it with $450 in steering column parts when another member has already shown his setup that works.
Old 12-21-2006, 09:52 AM   #17
jkaylor68gmc
The ididit column trly isn't that expensive considering it is a direct fit peice. For the chrome tilt column and install kit it was about $1000 bucks or so but it went directly in. It fits great and took no time to put in. I think quality and a direct fit speak for themselves.
Old 12-21-2006, 10:02 AM   #18
jfalesi
Junior Member
Thanks for the info, I'll keep that in mind if the stock tilt rebuild doesn't work out. I have no experience with rag joints, steering shafts, etc. so I don't yet know what I'm in for...
Old 12-21-2006, 10:09 AM   #19
ortegamotor
ortegamotor's Avatar
i like my IDIDIT it went right in and i think it was one of the best selling points when i sold my truck.you rewally get what you put in to it.Tony
ortegamotor is offline   Reply With Quote
Old 12-21-2006, 12:54 PM   #20
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
The Flaming River is a little higher quality-stainless, not steel or aluminum. They look like they belong in our trucks. Look at the shift arm. The best on the market...it fits our stock tilts too!
We have these made for us, just for our trucks. We have some improvements done and the shaft is splined so you can use the stock intermediate shaft for savings, or the ujoint shaft rod if wanted.
PICKMUP is offline   Reply With Quote
Old 12-21-2006, 01:10 PM   #21
Hart_Rod
Hart_Rod's Avatar
Price??
Old 12-21-2006, 01:36 PM   #22
71chevylowrider
71chevylowrider's Avatar
I Love my polished tilt ididit, I've seen some on evilbay for half of what they cost new.
71chevylowrider is offline   Reply With Quote
Old 12-22-2006, 01:42 AM   #23
brak
brak's Avatar
I wasn't trying to criticize you, I was just posting information for the benefit of this thread, referenced the fact that the other column has been used successfully by you and another member, and then stated which one i am going to choose.
sorry if it came across that way
Old 12-22-2006, 01:46 AM   #24
skokie
skokie's Avatar
Ok I called Flaming River and Ididit and got prices.
Both are going to e auto columns with nuetral safety switch and non polished for painting. Both are 33 inch long splined shaft
Flaming river $694.00
Ididid $675.00
68 build thread
Old 12-22-2006, 01:47 AM   #25
skokie
skokie's Avatar
BTW 71chevylowrider what is the year make and model of those seats?
68 build thread
